I am using TMPGEnc to convert divx movies to mpeg format and then burning them to a cdr using adaptec easy cd creator 4 but when i put them in the above dvd player it will load the disc and read how long the file is ( the display shows "vcd 1 55:16" for example) then when i play the display shows "vcd pb 0:00" which it remains at and the tv screen stays blue. I checked the dvd player on this site and it says it will play cdrs and vcds. I have tried changing the type of setting from ntcs, multi, and pal. Is there something in the player that I need to change or some setting to play with that would make it play correctly or some type of conversion that i need to try. Any help or suggestions would be apprecitated.
Thanks!
Results 1 to 1 of 1
Region Free Denon dvd 1000
By jhasty1210 in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2014, 09:31 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 13:02 -
anyone know how to unlock denon dvd-2500 regions
By similar in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 15:03 -
DENON DVD-1500 does not play any discs...
By jOlDMaN in forum DVD & Blu-ray PlayersReplies: 5Last Post: 7th Jan 2011, 06:18 -
Denon DVD-1940CI multi hack please :)
By talla in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jul 2009, 13:32
