I have a few mpeg files which i'd like to put to VCD and have them fade out/in to each other. Is there a program which can do it as simply as fading in audio using Cool Edit?
http://forum.vcdhelp.com/viewtopic.php?t=90953
Open your MPEG-1 in VirtualDub. You will need to reencode again which may affect the quality.
If it is MPEG2 try a workaround using AviSynth with mpeg2dec.dll or DVD2AVI. -
Ulead Video studio 6 can make this..... without losing quality....
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
Originally Posted by OO
Every lossy conversion will result in a quality loss.
Good MPEG2 capable editors can do this, only reencoding the fade. Adobe Premiere and certainly Ulead MediaSTudio Pro 6.5 can do this without reencoding the entire clip.
I am not sure if lesser MPEG2 editors like Ulead Videostudio 6 rerender the entire clip. -
If the input settings match the output settings VideoStudio 6 will only render/encode the transition effect between the clips not the whole video file.
When opening "New Project" just select, "Template from an Existing Video File."
However, this assumes all the MPEG files you're transitioning together are all identical, otherwise it will re-encode all to whatever you set as your output file as one video file.Evil flourishes when good men do nothing.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
