  1. Anyone is using this capture card? My experience using the software bundled with the card is not very good. I always get frames dropped during capture, and I have no ways to make the scheduler work! Is there anyone that can make it? Or any recommendation on capturing software w/ a scheduler?
    Recently I turn to use VirtualDub, which is much better. The quality is far more than acceptable, hope there will be a scheduler very soon.
    Any reply is appreciated.
  2. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    pharaohc I hate say this but it dosen't sound like you own WinTV-PVR being this is a hardware base MPEG2 encode which dosen't drop any frames.
    You need check my web maybe that help you.
  3. SHS,
    No no I DO HAVE a WinTV PVR.
    Perhaps I need to specify that I am using the "remote controller" after clicking the "rc" of the bottom-left corner of WinTV2000.
  4. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    What wrong with the BIG RED REC BUTTON?.
  5. Alright let's forget the button.
    Now I would like to ask how I can split the capture file AUTOMATICALLY. This is a great problem to me as it stops capturing after the file size grows > 4GB, and of course, I am asking how WinTV2000 can do that.
    Thanks.
