In DaVinci Resolve I've imported a .mp4 with channel layout 5.1 L R C LFE Ls Rs verified in MediaInfo . But in Resolve it's recognized as 5.1Film and the mapping is L C R Ls Rs LFE.
The problem is that if I change the audio format in the clip attributes to 5.1, the channels are not mapped correctly because the C and LFE are in the wrong position, the channel order does no change place on format change, so the C waveform is always the 2nd channel and LFE 6th.
How ca nI make Resolve parse the file correctly or should I remap the channels manually?
channel 1 - L
channel 3 - R
channel 2 - C
channel 6 - LFE
channnel 4 - Ls
channel 5 - Rs
I had this same problem with 5.1 m2ts files from my Panasonic camera.
The audio is imported as six mono channels with incorrect channel mapping.
The solution:
After the video clips are imported to the Media Pool, select all the clips, right-click and select Clip Attributes...
In the Audio tab:
- Change Format to 5.1, Tracks to 1, click Add
- Delete the Mono tracks (click rubbish bin that appears when you mouse over each channel)
- Re-assign each Source Channel in the new 5.1 format to the correct mapping by clicking the down arrow on each Embedded Channel:
Left = Embedded Channel 1
Right = Embedded Channel 3
Center = Embedded Channel 2
LFE = Embedded Channel 6
Left Surround = Embedded Channel 4
Right Surround = Embedded Channel 5
Do this before dragging clips to the timeline.
Hope this helps.
Restore audio clip with speed in DaVinci Resolve
By Filippo in forum EditingReplies: 0Last Post: 26th Feb 2026, 14:04 -
how to transcode audio from a clip so that...
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2024, 14:31 -
AviSynth: Mixing Audio in a looped clip
By smike in forum EditingReplies: 0Last Post: 8th Dec 2022, 23:33 -
How to record audio clip from online video?
By mikehende in forum AudioReplies: 6Last Post: 19th Feb 2022, 11:24 -
[Avisynth] Gradually transition from clip A to clip B with a “wipe” effect
By abolibibelot in forum Video ConversionReplies: 6Last Post: 31st Oct 2021, 09:47
