Results 1 to 1 of 1
    Feb 2026
    India
    How To Skip / Bypass Language Selection on HDMV Blu-ray (Beginner Guide)
    This guide explains how to remove the language selection screen on many HDMV Blu-ray discs while keeping everything working:
    ✔ Main Menu
    ✔ Warnings
    ✔ Movie playback
    ✔ Post-credit scenes
    ✔ Return to Menu
    ✔ Extras
    Important: This works for HDMV Blu-ray discs only.
    It does NOT work for BD-J discs.
    Step 1 – Confirm Your Disc Is HDMV
    [Attachment 91336 - Click to enlarge]
    Open the disc in BDedit.
    Go to:
    index.bdmv → First Playback Type
    If it says:
    HDMV
    You can continue.
    If it says BD-J → This guide will NOT work.
    Step 2 – Understand How Language Selection Works
    Most HDMV discs work like this:
    1) Disc starts
    2) GPR3 is set to 0
    3) Disc jumps to Title 0
    4) Title 0 shows language selection
    5) After choosing language, movie starts
    We will NOT delete anything.
    We will simply force the language in advance so the language screen never appears.
    Step 3 – Find The Correct Playlists
    Every Blu-ray is different.
    Before editing anything, you MUST correctly identify:
    • Main Movie playlist
    • Warning playlist
    • Main Menu playlists
    • Main Menu MovieObject
    Follow these steps carefully.
    A) Find the Main Movie
    Go to:
    Playlist → xxxx.mpls
    Sort by Duration.
    The longest playlist (example: 01:52:30) is usually the main movie.
    Example:
    00008.mpls → 01:52:30 ← Main Movie
    You would use:
    Play PL 8
    (Remove leading zeros.)
    B) Find the Warning Playlist
    Look for very short playlists (10–40 seconds).
    Typical examples:
    • Studio Logo
    • FBI Warning
    • Legal Notice
    Example:
    00003.mpls → 00:00:20 ← Warning
    You would use:
    Play PL 3
    C) Find the Main Menu Playlists
    Menus usually have:
    • One intro playlist
    • One looping playlist
    Example:
    00004.mpls → Menu Intro
    00005.mpls → Menu Loop
    Now open:
    MovieObject.bdmv
    Find which MovieObject plays these playlists.
    Example:
    MovieObject 006
    Play PL 4
    Jump Object 7
    MovieObject 007
    Play PL 5
    GoTo 5
    That means:
    Object 6 = Main Menu Entry
    Object 7 = Menu Loop
    Your startup must use:
    Jump Object 6
    NOT Jump Title.
    How To Confirm You Found The Correct Menu Object
    The correct Menu Object will:
    ✔ Play the menu intro playlist
    ✔ Then jump to another object
    ✔ That second object will loop a playlist (GoTo)
    Quick Identification Summary
    Main Movie → Longest playlist
    Warning → Very short playlist (10–30 sec)
    Menu Intro → Medium playlist used in MovieObject
    Menu Loop → Playlist that loops via GoTo
    Menu Object → Object that plays the menu intro playlist
    Important:
    Always verify inside MovieObject.bdmv which object plays your menu playlist.
    Do NOT guess.
    Playlist numbers and object numbers are different on every disc.
    If you correctly identify:
    • Main movie playlist
    • Warning playlist
    • Menu object number
    Then skipping the language selection can be done safely without breaking navigation.
    If it only plays once and exits, it is NOT the main menu.
    Step 4 – Modify MovieObject 000 (Startup Fix)
    [Attachment 91337 - Click to enlarge]
    Open:
    MovieObject.bdmv → MovieObject 000
    Replace its code with:
    Move GPR0, 0
    Move GPR3, 3 (Some discs use a different GPR register or value. Verify which register controls language if unsure.)
    Play PL 3
    Jump Object 6
    Break
    Explanation:
    Move GPR3, 3 → Forces English (most discs use 3 for English)
    Play PL 3 → Plays warning
    Jump Object 6 → Goes to Main Menu
    Use YOUR correct playlist and object numbers.
    Step 5 – Fix Post-Credit Return
    On certain discs, the movie ends by jumping back to Title 0 (language selection).
    Find Title 2 (post-credit controller).
    At the end you will see:
    Jump Title 0
    Change ONLY that line to:
    Jump Object 6
    (Use your menu object number.)
    Do NOT change all Jump Title 0 entries.
    Only change the one in the post-credit title.
    What You Should NOT Do
    Do NOT:
    ✖ Delete Title 0
    ✖ Delete Title 1
    ✖ Replace all Jump Title 0
    ✖ Remove GPR logic
    ✖ Jump directly to the movie playlist
    This will break menu navigation or extras.
    Final Expected Result
    After editing:
    Insert Disc
    → Warning
    → Main Menu
    → User selects Play
    → Movie
    → Post-credit
    → Return to Main Menu
    Language selection screen is gone.
    Everything else works normally.
    Testing Advice
    Test using:
    PowerDVD
    • Or a real hardware Blu-ray player
    Some players (VLC, some lightweight players) do NOT fully support Blu-ray navigation and may skip menus.
    Important Notes
    ✔ Works only for HDMV discs
    ✔ Does NOT work for BD-J
    ✔ Always keep a backup before editing
    ✔ Playlist and object numbers are different for every disc
    If the disc uses GPR branching inside Title 0 instead of simple Jump logic,
    you must replicate the same language value that Title 0 normally sets.
    If done correctly, this method safely bypasses the language selection without breaking Blu-ray navigation.
