Hi all.
I'm new to the forum, had two strokes over five years ago, and considering I haven't been to to this in YEARS. It may forever until I understood glossary, but hopefully you'll help.
Years ago I was an editor on Sony TV used. Now, the only things I've touched are VLC media, https://www.videolan.org/vlc/index.html and--you may guess it--Microsoft's older "Movie Maker." (Are there any around?)
I have am Ultra Blu-ray Disc Player and Windows 11. Add to that, a bunch of little kids' video nearly 40 years old, and quite a few of child professional video tapes.
Can you refer me to software I can handle? Also, is there a way to do the captions. I appreciate it.
(And by the way, WHY is it that people invent brilliant things and no manual? If I get a new car, there's ALWAYS a manual. What's up with that?)
Thanks,
30years
If by captions you mean to add subtitles to your videos then you can use Whisper.
If you have a good PC and Subtitles Edit installed then under Video you will see
Audio to Text (Whisper)
Select it and download any option to test
There are several options to use.
I personally use Whisper AI which is a command line (cmd) application without the need for Subtitle Edit. -
and there is a whole section below on how to do blue rays.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Thanks so much! Can you be specific for the section? (And URL?) Same thing for Whisper. Appreciate it.
jagabo, that's very good! I also think it's because programmers are building things GLOBALLY and their bosses aren't so important of writing a manual! (It makes me crazy...)
Thanks again! -
Do you have latest Subtitles Edit Installed?
What URL do you need?
Regarding Whisper on open AI here is a link. It is a really good read.
https://github.com/openai/whisper
If you can handle command line (cmd) then I recommend installing Whisper AI.
Otherwise use subtitle Edit.
What is you PC specifications? If you have a good CPU and GPU then you will get good and accurate results.
BTW whisper works on the audio but it handles the video as well.
What I mean by this is that if you want someone to create subtitles for you, then you can just send him only the audio if you prefer (privacy concerns?) -
The section that I was referring to is: Authoring (Blue-ray)
But..If you are new at this then I would start with simple DVD creation.
Some of us have decided that that is old tech and it's getting harder to find reliable DVD blanks.
I just create video files and store them on my hard drive. (and backups)Last edited by TreeTops; 27th Feb 2026 at 11:48.
@30years - can you clarify exactly what you are asking for? Your original post is very confusing. Are you looking for a video editor, or a way to produce Blurays from video files, or a way to produce DVDs from video files?
And you want a way to generate subtitles (captions), is that correct?
It's a lot easier for us to help you if we can actually understand what your desired end result is.
20 years with videohelp...thank you everyone!
By ricardouk in forum Off topicReplies: 13Last Post: 3rd Aug 2025, 16:49 -
AnandTech shuts down after 27 years.
By El Heggunte in forum Off topicReplies: 3Last Post: 1st Sep 2024, 23:35 -
Back to tapes backup after 12 years - some questions..
By jan3sobieski in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2024, 18:47 -
Digital8 LP vs SP...21 years later
By ybarra in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Jul 2022, 02:39 -
very Buggy if u loose password - back after 10 years
By melani in forum FeedbackReplies: 2Last Post: 25th Jan 2022, 21:56
