Hi. There is noticeable bobbing (look at the TV logo) of this NTSC video even after using QTGMC. Is there a way to get rid of that annoying frame bobbing?
Results 1 to 11 of 11
THere's a lot of duplicate frames, I'm not surprised it doesn't work well
try this
Code:bwdif(field=-2) # alternative to qtgmc srestore(frate=24)
There's a duplicate frame and the bobbing isn't fixed. A temporary solution I found on my own was to use:
and save a temporary video as lossless (Huffyuv) and load that temporary video and useCode:QTGMC(Preset="Slow", FPSDivisor=2, MatchPreset="Slow", Sharpness=0.5) SRestore(23.976)
to stabilize the video. There's still a bit of bobbing but it's way less noticeable. If a better solution is not suggested, I'll use this one. Btw I'm not 100% sure that's the right fps.Code:QTGMC(InputType=1, Preset="Fast", Sharpness=0.5)
That's good. Yeah I see the bobbing on the attempt I made. My pc too old to run qtgmc unfortunately
This convoluted method appeared to work, although I'm not sure I fully understand why, but a quick perusal didn't reveal any repeated frames. I'm pretty sure there's nothing to be lost by downscaling to 720p, but that's up to you.
Sample 1.
SeparateFields()
SelectEven()
nnedi3(dh=true)
QTGMC()
SelectEven()
CropResize(1280,720)
Sample 2 (possibly faster, but I did notice at least one duplicate).
QTGMC()
SRestore(30000.0/1001.0)
CropResize(1280,720)Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Or what about this?
QTGMC()
SelectEven()
Isn't the clip 29.97fps field shifted and a simple TFM() should be used?
QTGMC: Every 4th Frame wrong?
By Waver in forum RestorationReplies: 3Last Post: 5th May 2025, 12:59 -
QTGMC Choppy Frame Rate After Selecting Bob
By AdamJellicorse in forum RestorationReplies: 2Last Post: 19th Apr 2023, 22:18 -
QTGMC shimmer when deinterlacing a duplicate frame
By PRAGMA in forum RestorationReplies: 8Last Post: 16th Apr 2023, 09:13 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01 -
De-interlacing with QTGMC results in odd frame mismatching
By Cleen in forum RestorationReplies: 2Last Post: 27th Dec 2022, 18:34
