Results 1 to 14 of 14
    May 2023
    Italy
    I have this mkv, when I import media in DaVinci nothing happens.
    Before splitting it with MKVToolNix it was imported but only as audio track (even in Premiere). How can I convert it without losing quality and keeping the audio mapping (two 5.1 and one mono)? I tried .mov but the channels are seen as single mono tracks in DaVinci. I don't care about subtitles.
    https://www.swisstransfer.com/d/0531a040-9b33-4a9d-8716-540d59d904fc
    May 2005
    PAL User
    Does the attached MPG open in Resolve?
    May 2023
    Italy
    It’s not imported.
  4. Originally Posted by Filippo View Post
    mpeg2 in mkv is not supported in DaVinci Resolve
    Remux your mkv to m2ts (without subtitles).
    You can do this with clever FFmpeg-GUI.
    Try the attached file in Resolve first.
    May 2023
    Italy
    Thank you, it is imported but without any audio.
  6. Originally Posted by Filippo View Post
    Davinci Resolve seems to be very selective with the codecs it supports.
    Version 16 only supports the following audio codecs:
    wav – Uncompressed PCM 16/24/32-bit
    mp3 – Constant bit rate
    aac – CBR, VBR, average CBR, VBR, average
    flac
    You could upgrade to v18.5. That also supports ac3.
    Or you could convert the audio tracks to pcm or flac (both lossless). You can also do this conversion with clever FFmpeg-GUI.
    Then mux the new audio tracks with the mpeg2 video track to m2ts.
    May 2023
    Italy
    flac
    I’m using last version 20.3, I’ll try some conversion and report here. It’s just that I’m aiming to do a losess conversion at least for audio.
  8. Originally Posted by Filippo View Post
    Try this one:
    May 2023
    Italy
    Try this one:
    Thanks, this is imported, I've already tried .mov but the audio is messed up: Instead of having two 5.1 and one mono it imports all as mono tracks.
    .mkv (ac3 audio):
    [Attachment 91306 - Click to enlarge]
    .mov
    [Attachment 91307 - Click to enlarge]
  10. Originally Posted by Filippo View Post
    Perhaps you have activated an option to split multi-channel audio into individual channels. Please check this.
    May 2023
    Italy
    Without touching the settings:
    .mkv (mpeg2video, ac3) audio is mapped correctly but no video
    HTML Code:
    Input #0, matroska,webm, from 'output.mkv':
      Metadata:
        encoder         : libebml v1.4.5 + libmatroska v1.7.1
        creation_time   : 2026-02-23T21:02:33.000000Z
      Duration: 00:00:12.28, start: 0.080000, bitrate: 5145 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 10.064000
          Metadata:
            title           : Capitolo 01
      Stream #0:0(eng): Video: mpeg2video (Main), yuv420p(tv, top first), 720x576 [SAR 16:15 DAR 4:3], 25 fps, 25 tbr, 1k tbn, start 0.080000
        Metadata:
          BPS             : 5229809
          DURATION        : 00:00:10.080000000
          NUMBER_OF_FRAMES: 252
          NUMBER_OF_BYTES : 6589560
          SOURCE_ID       : 0100E0
          _STATISTICS_WRITING_APP: [url=https://www.videohelp.com/software/MKVToolNix]mkvmerge[/url] v91.0 ('Signs') 64-bit
          _STATISTICS_WRITING_DATE_UTC: 2026-02-23 21:02:33
          _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
        Side data:
          cpb: bitrate max/min/avg: 7000000/0/0 buffer size: 1835008 vbv_delay: N/A
      Stream #0:1(ita): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s, start 0.096000 (default)
        Metadata:
          title           : Surround 5.1
          BPS             : 448000
          NUMBER_OF_FRAMES: 315
          NUMBER_OF_BYTES : 564480
          SOURCE_ID       : 0180BD
          _STATISTICS_WRITING_APP: mkvmerge v91.0 ('Signs') 64-bit
      Stream #0:2(ita): Audio: ac3, 48000 Hz, mono, fltp, 192 kb/s, start 0.096000
        Metadata:
          title           : Mono
          BPS             : 192000
          NUMBER_OF_BYTES : 241920
          SOURCE_ID       : 0182BD
      Stream #0:3(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s, start 0.096000
        Metadata:
          BPS             : 384000
          NUMBER_OF_BYTES : 483840
          SOURCE_ID       : 0181BD
    .mov (mpeg2video, ac3) audio is imported abut all channels as mono.
    HTML Code:
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'output.mov':
      Metadata:
        major_brand     : qt
        minor_version   : 512
        compatible_brands: qt
        encoder         : Lavf62.8.102
      Duration: 00:00:10.02, start: 0.000000, bitrate: 6301 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 10.016000
          Metadata:
            title           :
      Stream #0:0[0x1]: Video: mpeg2video (Main) (mp2v / 0x7632706D), yuv420p(tv, top first), 720x576 [SAR 16:15 DAR 4:3], 5229 kb/s, 25 fps, 25 tbr, 16k tbn (default)
        Metadata:
          handler_name    : VideoHandler
          vendor_id       : FFMP
        Side data:
      Stream #0:1[0x2](ita): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
        Metadata:
          handler_name    : SoundHandler
          vendor_id       : [0][0][0][0]
        Side data:
          audio service type: main
      Stream #0:2[0x3](ita): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, mono, fltp, 192 kb/s
        Metadata:
        Side data:
      Stream #0:3[0x4](eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 384 kb/s
        Metadata:
        Side data:
    I can remap the channels in Resolve but was looking to a less error prone workflow.
  12. Originally Posted by Filippo View Post
    Another try
    May 2023
    Italy
    Another try
    This has the same issue, but I've made a try using prores for the video and ac3 for the audio, it keeps the audio mapping and the video is there.
    Aug 2018
    Wrocław
    A better method is to split the video and audio into separate files and load both into Resolve.
    Video: ffmpeg -i output.mkv -c copy video.ts
    Audio: ffmpeg -i output.mkv -map 0:a -c copy audio.mp4
