    May 2005
    PAL User
    Hello all, I'm trying to run a "file information" script to display various parameters of a file. This is the script I'm using:
    clip=LwLibavVideoSource("H:\Magix Info\Clement5\Magix IYUV 23.98.avi")
    # Get basic properties
    Width = clip.Width()
    Height = clip.Height()
    FrameRate = clip.FrameRate()
    Length = clip.FrameCount()
    #ColorFormat = clip.GetColorFormat() # For AviSynth+
    AudioSampleRate = clip.AudioRate()
    AudioChannels = clip.AudioChannels()
    # You can then use these variables for further processing or output to a file
    # For example, to display some information:
    Subtitle("Resolution: " + String(Width) + "x" + String(Height) + \
                     " | Framerate: " + String(FrameRate) + \
                     " | Frames: " + String(Length))
    Return clip
    When I attempt to open it in VDub2, I get this:
    [Attachment 91291 - Click to enlarge]
    The script looks Ok to me, including line 17 (the "Frames" line) but I'm no expert. I would be grateful if someone could point out the error of my ways.
    Thanks.
    Mar 2008
    Hi Alwyn
    clip=Subtitle(clip,"Resolution: " + String(Width) + "x" + String(Height) + \
    Return clip
    May 2005
    PAL User
    Good onya Dave, thanks a lot.
