Results 1 to 10 of 10
  1. Hi everybody,
    I am a beginner with all these powerful tools and I tried with success to download some videos (both with N_m3u8DL-RE and yt-dlp)... but I actually have problems with Raiplay videos from Olympic Games events. Some are downloadable (with N_m3u8DL-RE), some aren't.
    In particular, I would need help with this one: https://www.raiplay.it/video/2026/02/Olimpiadi-Invernali-Milano-Cortina-2026---Hockey-...d87c6a8a7.html
    I don't understand if DRM protection is sometimes stronger, or if I do something wrong.
    Thanks a lot!
  2. Code:
    N_m3u8DL-RE "https://vod2-rai-it.akamaized.net/playlist-service/podcastcdn/drm_root/DRMNagra_Olimpiadi_Invernali_Milano_Cortina_2026_M_multiaudio/28522846_,1800,2400/manifest_mvnumber.mpd?hdnea=st=1771586587~exp=1771586737~acl=/*~hmac=2830270c648c9799c60b74453df08723d65e81504d73c6483f7406a94afa312e" --key dc5488871c435509b3de0265911f5891:c8112686f69d9602701aea2af78e5e82 -M format=mkv
  3. Originally Posted by cedric8528 View Post
    That's what I tried, but it gives me an error
    Dec 2021
    england
    what error?
    this one? Segment count check not pass, total: 700, downloaded: 699.
    add cmd --check-segments-count false
    N_m3u8DL-RE "https://vod2-rai-it.akamaized.net/playlist-service/podcastcdn/drm_root/DRMNagra_Olimpiadi_Invernali_Milano_Cortina_2026_M_multiaudio/28522846_,1800,2400/manifest_mvnumber.mpd?hdnea=st=1771586587~exp=1771586737~acl=/*~hmac=2830270c648c9799c60b74453df08723d65e81504d73c6483f7406a94afa312e" --key dc5488871c435509b3de0265911f5891:c8112686f69d9602701aea2af78e5e82 -M format=mkv --check-segments-count false
  5. Originally Posted by iamghost View Post
    no matter if I add or not the string you suggested. Same error, which is:
    Unhandled exception: System.IO.FileNotFoundException: mp4decrypt not found, please download at: https://www.bento4.com/downloads/
    at N_m3u8DL_RE.Program.<DoWorkAsync>d__3.MoveNext() + 0x21bf
    --- End of stack trace from previous location ---
    at System.CommandLine.Command.<>c__DisplayClass33_0.< <SetAction>b__0>d.MoveNext() + 0x51
    at System.CommandLine.Invocation.InvocationPipeline.< InvokeAsync>d__0.MoveNext() + 0x1d2
    Actually it got worse now than my previous attempts in the last days..... when at least download started, and in the end a message "failed" appeared.
    I am on Windows 10. My successful attempts on other links were through Command Prompt and not Powershell (if that matters).
    Just as a test, no problem with Mediaset Infinity (just to cite another italian platform).
    Should I have to install that "mp4decrypt" indicated?
  6. Originally Posted by iamghost View Post
    what error?
    Thanks! I finally managed!
    I missed installing ffmpeg.exe, mp4decrypt.exe and mkvmerge.exe in the same folder of N_m3u8DL-RE (I previously followed a youtube tutorial which did not mention the last two).
    After doing that, I was able to download the .mkv file.
    Thank you again!
  7. Can someone in Italy please help me download this?
    https://www.raiplay.it/programmi/italocalvinonellecitta
    Thanks in advance!
  8. Originally Posted by dzigelbaum View Post
    Thanks in advance!
    https://storage.to/GV6dlLDlG
