  1. hi, i've been trying to add soft subtitles to movies in DVDstyler. I think it has to do something with the software because when I used Yuhan Media DVD it worked just fine, but I don't want to use it. In Dvdstyler I added subtitle file (tried with srt and sub) and after burning the movie whenever I turned the subtitles on they looked spaced out, like in the photo. I tried to do it with different sub files, movies, fonts and languages but nothing seems to work...
    Mar 2008
    There are some fine adjustments you can make in the program.
    The program only accepts txt based subs so you're at the mercy of what you can do there - messing with the source
    wont help as far i can see
