Results 1 to 19 of 19
    Aug 2008
    Greece
    Hi.
    Is there any newer program than "Tencoder" that
    01. Continue supported
    02. Support windows7
    03. Can convert ALL audio files into ac3 with all directory and name structure?
    A LOT OF THANKS FOR YOUR TIME AND YOUR ANSWERS.
  2. ffmpeg in a batch file.
    Aug 2008
    Greece
    First of all this DONT has gui and I don't believe it can do what taencoder can do
    Aug 2008
    Greece
    Anyone any other suggestions?
    Mar 2008
    Why don't you keep using Tencoder?
    Aug 2008
    Greece
    If you read my previews post you know
    Feb 2006
    free or paid ??? found with AI - To convert all audio files into AC3 format while preserving the original directory and file name structure, use a robust batch converter like
    Switch File Converter, fre:ac, or Pazera Free Audio Extractor. These tools allow you to drag entire folders, select AC3 as the output format, and maintain folder structures for efficient batch processing.
    Recommended Tools and Methods
    Switch File Converter: Drag and drop entire folders, select output format as ".ac3", and convert in bulk.
    fre:ac (Free Audio Converter): A powerful open-source converter that supports complex file structures, Unicode tags, and multi-core encoding.
    Pazera Free Audio Extractor: Highly recommended for converting audio/video to AC3 while keeping folder hierarchies.
    Switch audio File Converter has a free trial for up to 30 files - https://www.youtube.com/watch?v=jreUk-Bt3Yo
    Pazera is free but appears to be getting no more updates
    https://www.freac.org/ seems to be the best - https://github.com/enzo1982/freac
    Aug 2008
    Greece
    Please READ what I have write to this topic. At first post I mention about the tenconder stop supporting like the 2nd program(pazera...) you suggest.
    I want a program to simply put mkv files and convert all audios inside the mkv into ac3 and the results file was mkv with the same name and folder structure.
    Mar 2008
    Yes, the programs are old not supported but in general don't they still work?
    I'm not aware of any modern replacements. Did you search the software section of this site?
    Aug 2008
    Greece
    For example the tenconder doesn't support dts-ex and more new dts forms so....
  11. Member ricardouk's Avatar
    Mar 2005
    Portugal
    I love it when a plan comes together!
    Aug 2008
    Greece
    Do you even see what you suggest?????
    The box4 you suggest STOP SUPPORTING FROM 2019 SO......
  13. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Be gratefull someone replies, its what i use to remux mkv's while just converting the audio, have you tried it?
    Aug 2008
    Greece
    I know how to do it with 2 programs
    01. Clever ffmpeg
    02. Mkvtoolnix
    I want to use only ONE program do all these not more than one.
    Aug 2008
    Greece
    Isn't there one program to do all these
  16. TEncoder is a GUI front end for ffmpeg. There are dozens of other GUI front ends for ffmpeg. Many of them support batch processing and are actively being developed. But many will not support Win7 because they use GUI libraries that no longer support Win7.
    Aug 2008
    Greece
    If there is dozens then please suggest me some?
    And i want something be like tencoder so simpe and so effective but even with the latest audio codecs.
  18. I use ffmpeg directly so I'm not familiar with many GUI front ends for it. Maybe one of these:
    https://www.codeitbro.com/blog/best-free-ffmpeg-guis-for-windows
