Flawed test because you say so. Of course
Links to tests that don't provide any information about the settings? Poor. They definitely won't look through everything, too much noise.
So you didn't read anything. VirtualDub didn't drop a single frame, AmarecTV did. So you think it's the card's fault or maybe the system selects programs that it works well with? (BTW: and it wasn't even the card).
You won't be a diagnosticianIn addition, the fact that the nuber of dropped frames changes with the software has low credibility, showing in truth a weakness or a marginality of the capture (and record) system.
The capture module in VDub has been unchanged for ages -- the last changes were probably in version 1.6.x. You're creating your own matrix....In addition, VirtualDub2 is not recommended by many as capture software compared to previous versions, because introduced a regression in the capture engine. I myself experimented that with VDub2 and a old OS (Win7) and modern OS (Win11) using an IODATA GV-USB card capturing an average quality tape, where Vdub 1.9.11 was performing better in term of dropped frames and a/v synch (as I reported in one of my recent posts about GV-USB2).
Based on your diagnosis, your system seems to be malfunctioning. For me -- every version works perfectly (VirtualDub2 and above).
Yes, yes. Flawed because it is flawed. Final argument. Worth 0.As Sharc properly pointed out in the general approach we all have about our findings (me included), you are just focused on your (flawed) test, and simply do not see the real world.
Results 31 to 34 of 34
You’re so blind that you did not understand a word of what I wrote. Pearls before swine!
Yes, final argument: you’re wrong, I am rigth; it is so obvious from our posts and evidences (mines, yours are flawed). As always
But you're writing nothing. It's just unsubstantiated speculation, pure conjecture, unsubstantiated theorizing. I'm not asking for evidence because I know there won't be any. It's pure demagogy, the "I'm right because I'm right" kind of thing.
I know, I know -- when one thing works and another doesn't, the test was definitely bad. Why? Because it was bad
Or the system was bad
IO Data GV-USB2 Drivers
By Alwyn in forum Capturing and VCRReplies: 7Last Post: 7th Feb 2026, 22:26 -
Is my I-O Data GV-USB2 faulty?
By gaiablade in forum Capturing and VCRReplies: 9Last Post: 7th Jan 2026, 21:12 -
IO-DATA GV-USB2 croaked
By bigbadben in forum Newbie / General discussionsReplies: 6Last Post: 19th Oct 2023, 20:46 -
Proc-Amp settings (Hue, Color, Brightness and Contrast) during capture
By VideoYak in forum Capturing and VCRReplies: 0Last Post: 5th Sep 2023, 07:11 -
I-o DATA GV-USB2 default settings sample
By boolian2 in forum Capturing and VCRReplies: 31Last Post: 23rd Jun 2022, 20:59
