Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. Originally Posted by cholla View Post
    for Windows 7 32-bit.
    --js-runtimes node
    Which version of Node are you using and where did you find it ?
  2. You have to download the .zip with all the versions.
    The version I use is in folder v20.
    node.js version 20.19.2.0
    https://github.com/vladimir-andreevich/node.js-windows-7
  3. Originally Posted by cholla View Post
    This is the one I'm using but no way, I always get only 4 audio tracks.
    The only way for me to get all of the 78 audio tracks is to use the old version 2025.10.22
  4. @ Brazil,
    I have no idea why yt-dlp does the longer list on my PC.
    I have a lot of different software installed.
    Maybe it is using a file from some of them somewhere.
    I'm in the USA & if you are not that could be the difference.
    I believe I am getting 103 or 104 tracks.
  5. Originally Posted by cholla View Post
    In this case the older version wouldn't show me all of the audio tracks, which it does
    I guess there is something in recent versions which is not working on my computer for some reason but which works on yours
  6. @ Brazil,
    I don't know if this will help you it is the yt-dlp debug from my computer.
    You can tell if there are other differences from your computer.
    C:\Users\User\Desktop\Vedit\yt-dlp>yt-dlp -v --js-runtimes node --no-check-certificate --compat-options youtube-dl -F https://www.youtube.com/watch?v=KuZbjBqlZmY
    [debug] Command-line config: ['-v', '--js-runtimes', 'node', '--no-check-certificate', '--compat-options', 'youtube-dl', '-F', 'https://www.youtube.com/watch?v=KuZbjBqlZmY']
    [debug] Encodings: locale cp1252, fs utf-8, pref cp1252, out utf-8 (No VT), error utf-8 (No VT), screen utf-8 (No VT)
    [debug] yt-dlp version nicolaasjan/yt-dlp@2026.02.08.083006 (win7_x86_exe*)
    [debug] Compatibility options: abort-on-error, no-youtube-channel-redirect, no-certifi, no-attach-info-json, filename-sanitization, prefer-legacy-http-handler, no-live-chat, no-youtube-prefer-utc-upload-date, embed-thumbnail-atomicparsley, no-keep-subs, embed-metadata, no-playlist-metafiles, no-youtube-unavailable-videos, playlist-index, format-spec, list-formats, filename, format-sort, no-external-downloader-progress, no-clean-infojson, no-direct-merge, mtime-by-default, seperate-video-versions
    [debug] Python 3.14.3 (CPython x86 32bit) - Windows-7-6.1.7601-SP1 (OpenSSL 3.6.1 27 Jan 2026)
    [debug] exe versions: ffmpeg N-119166-g1e5c65f539-WIN7 (fdk,setts), ffprobe N-121473-gdc39a576ad-WIN7
    [debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2026.01.04, mutagen-1.47.0, requests-2.32.5, sqlite3-3.50.4, urllib3-2.6.3, websockets-16.0, yt_dlp_ejs-0.4.0
    [debug] JS runtimes: node-20.19.2
    [debug] Proxy map: {}
    [debug] Request Handlers: urllib, requests, websockets
    [debug] Plugin directories: none
    [debug] Loaded 1861 extractors
    [debug] [youtube] [pot] PO Token Providers: none
    [debug] [youtube] [pot] PO Token Cache Providers: memory
    [debug] [youtube] [pot] PO Token Cache Spec Providers: webpo
    [debug] [youtube] [jsc] JS Challenge Providers: bun (unavailable), deno (unavailable), node, quickjs (unavailable)
    [youtube] Extracting URL: https://www.youtube.com/watch?v=KuZbjBqlZmY
    [youtube] KuZbjBqlZmY: Downloading webpage
    [debug] [youtube] Forcing "tv" player JS variant for player a944b11f
            original url = /s/player/a944b11f/player_es6.vflset/en_US/base.js
    [youtube] KuZbjBqlZmY: Downloading android vr player API JSON
    [youtube] KuZbjBqlZmY: Downloading web safari player API JSON
    [debug] [youtube] KuZbjBqlZmY: Detected a 15s ad skippable after 5s for web_safari
    [debug] [youtube] KuZbjBqlZmY: Detected experiment to bind GVS PO Token to video ID for web client
    [debug] [youtube] KuZbjBqlZmY: Some web client https formats have been skipped as they are missing a URL. YouTube is forcing SABR streaming for this client. See  https://github.com/yt-dlp/yt-dlp/issues/12482  for more details
    [debug] [youtube] KuZbjBqlZmY: Some web_safari client https formats have been skipped as they are missing a URL. YouTube is forcing SABR streaming for this client. See  https://github.com/yt-dlp/yt-dlp/issues/12482  for more details
    [youtube] KuZbjBqlZmY: Downloading player a944b11f-tv
    [youtube] [jsc:node] Solving JS challenges using node
    [debug] [youtube] [jsc:node] Using challenge solver lib script v0.4.0 (source: python package, variant: minified)
    [debug] [youtube] [jsc:node] Using challenge solver core script v0.4.0 (source: python package, variant: minified)
    [debug] [youtube] [jsc:node] Running node: 'C:\Program Files\nodejs\node.EXE' --experimental-permission --no-warnings=ExperimentalWarning -
    [youtube] KuZbjBqlZmY: Downloading m3u8 information
    [debug] Sort order given by user: hasaud, lang, quality, tbr, filesize, vbr, height, width, proto, vext, abr, aext, fps, fs_approx, source, id
    [debug] Sort order given by extractor: quality, res, fps, hdr:12, source, vcodec, channels, acodec, lang, proto
    [debug] Formats sorted by: hasvid, ie_pref, hasaud, lang, quality, tbr, filesize, vbr, height, width, proto, vext, abr, aext, fps, fs_approx, source, id, res, hdr:12(7), vcodec, channels, acodec, size, br, asr
    [info] Available formats for KuZbjBqlZmY:
