with simulator L3, you get Error 2079 Device not supported
with real device L3, you get Error 2074 Please open in Android app
change the ua, you get Error 2074 Please update app from Play Store
try streamfab, you get Error 2069 Open in updated Google Chrome
after all this, my IP get banned and get Error 2113 Authentication failed
Results 1 to 15 of 15
the only option i know works at the moment is TubeDigger in Monitor Browser/Rec Mode and you need to change in Settings -> Advanced> Encoder for difficult videos: H264 Veryfast for higher output plus you need updated version of TubeDigger not available on the site yet
No reason to change to 'H264 Veryfast' as hardware H264/265 encoders do job fine.
That option was suggested ONLY because to record that useless malformed test video
Updated version of TubeDigger can be installed from here
If video has 2K resolution, by default will be selected 1080p to reduce CPU and GPU load.
For 2K recording: select it in video resolution box, click 'OK' and page will reload in Firefox.Last edited by TubeDigger; 5th Feb 2026 at 23:53.
Ok sorry for offtopic
Could you please try to add support for https://fastevo.com/ ? -
Rec Mode/Monitor Browser mode only capture audio and WidevineProxy2 will not work because they have better protection and decryption keys are always incorrect because their system is fucked up so the only option would be to implent the same thing you did with VdoCipher protection if it's possible
here is more info
https://forum.videohelp.com/threads/414092-Help-with-new-type-of-drm-video?highlight=f...vo#post2787810
and
https://forum.videohelp.com/threads/416316-[Release]-WidevineProxy2-Extension-Bypass-HMAC-1-timetokens-Lic-wrapping/page24#post2784610 -
there is test video here https://fastevo.com/ 3:28 main page i'm using FireFox incognito
Restart Firefox several times or reboot your computerthere is test video here https://fastevo.com/ 3:28 main page i'm using FireFox incognito
I am trying to disable Firefox caching on the fly, but unfortunately they don't always listen to me.
Perhaps type in Firefox address bar 'about:config' and disable there such variables:
browser.cache.disk.enable and browser.cache.memory.enable
Regarding lags: it records fine for me even using x6 speed,
probably do not perform heavy CPU tasks during recording as
online videos watching or web surfing (watch offline video is fine). -
Does anyone know any website that uses fastevo, removing that eschatological website that has ever been commented on (darkangel)
Vdocipher decryption key retrieval
By Diazole in forum Video Streaming DownloadingReplies: 101Last Post: 13th Jun 2025, 13:45 -
New vdocipher DRM
By aqzs in forum Video Streaming DownloadingReplies: 27Last Post: 2nd Apr 2025, 16:50 -
help with vdocipher
By Silv3r in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Dec 2024, 08:56 -
AES 128 Key, How do i decrypt or find the key?
By GirlsGill in forum Video Streaming DownloadingReplies: 12Last Post: 12th Feb 2024, 08:03 -
No downloader working without key. now getting base64 key string is tough.
By akshaysic in forum Video Streaming DownloadingReplies: 6Last Post: 14th Jan 2023, 10:33
