  1. hi, I tried to download this and i use get_iplayer with vpn but it's not working and maybe it's not expired
    https://www.bbc.co.uk/programmes/m002pv5r
    Any help?
  2. yt-dlp will download it with a vpn
  3. maybe it isn't works
    PHP Code:
    >yt-dlp -vU https://www.bbc.co.uk/programmes/m002pv5r
    [debugCommand-line config: ['-vU''https://www.bbc.co.uk/programmes/m002pv5r']
    debugEncodingslocale cp1252fs utf-8pref cp1252out utf-8error utf-8screen utf-8
    [debug] [url=https://www.videohelp.com/software/yt-dlp]yt-dlp[/url] version stable@2025.12.08 from yt-dlp/yt-dlp [7a52ff29d] (win_exe)
    [debugPython 3.10.11 (CPython AMD64 64bit) - Windows-10-10.0.19045-SP0 (OpenSSL 1.1.1t  7 Feb 2023)
    debugexe versions: [url=https://www.videohelp.com/software/ffmpeg]ffmpeg[/url] 2025-08-04-git-9a32b86307-full_build-www.gyan.dev (setts), [url=https://www.videohelp.com/software/ffmpeg]ffprobe[/url] 2025-08-04-git-9a32b86307-full_build-www.gyan.dev
    [debugOptional librariesCryptodome-3.23.0brotli-1.2.0certifi-2025.11.12curl_cffi-0.13.0mutagen-1.47.0requests-2.32.5sqlite3-3.40.1urllib3-2.6.0websockets-15.0.1yt_dlp_ejs-0.3.2
    [debugJS runtimesnone
    [debugProxy map: {}
    debugRequest Handlersurllibrequestswebsocketscurl_cffi
    [debugPlugin directoriesnone
    [debugLoaded 1854 extractors
    [debugFetching release info: [url]https://api.github.com/repos/yt-dlp/yt-dlp/releases/latest[/url]
    Latest versionstable@2025.12.08 from yt-dlp/yt-dlp
    yt
    -dlp is up to date (stable@2025.12.08 from yt-dlp/yt-dlp)
    bbc.co.ukExtracting URL: [url]https://www.bbc.co.uk/programmes/m002pv5r[/url]
    [bbc.co.ukm002pv5rDownloading video page
    [bbc.co.ukm002pv5rDownloading playlist JSON
    [bbc.co.ukm002pv5qDownloading media selection JSON
    [bbc.co.ukm002pv5qDownloading MPD manifest
    WARNING
    : [bbc.co.ukFailed to download MPD manifestHTTP Error 403Forbidden
    WARNING
    [bbc.co.ukm002pv5qDownloading m3u8 information
    WARNING
    : [bbc.co.ukFailed to download m3u8 informationHTTP Error 403Forbidden
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    WARNING
    ERROR
    : [bbc.co.ukm002pv5qNo video formats found!; please report this issue on  [url]https://github.com/yt-dlp/yt-dlp/issues?q=[/url] , filling out the appropriate issue template. Confirm you are on the latest version using  yt-dlp -U
    Traceback (most recent call last):
    File "yt_dlp\YoutubeDL.py"line 1696in wrapper
      File
    "yt_dlp\YoutubeDL.py"line 1852in __extract_info
      File
    "yt_dlp\YoutubeDL.py"line 1911in process_ie_result
      File
    "yt_dlp\YoutubeDL.py"line 2924in process_video_result
      File
    "yt_dlp\YoutubeDL.py"line 1185in raise_no_formats
    yt_dlp
    .utils.ExtractorError: [bbc.co.ukm002pv5qNo video formats found!; please report this issue on  [url]https://github.com/yt-dlp/yt-dlp/issues?q=[/url] , filling out the appropriate issue template. Confirm you are on the latest version using  yt-dlp -U
  4. I'm using Mullvad VPN...
    [debug] Command-line config: ['-vU', 'https://www.bbc.co.uk/programmes/m002pv5r']
    [debug] Encodings: locale UTF-8, fs utf-8, pref UTF-8, out utf-8, error utf-8, screen utf-8
    [debug] yt-dlp version stable@2025.12.08 from yt-dlp/yt-dlp (linux_exe)
    [debug] Python 3.13.11 (CPython x86_64 64bit) - Linux-6.1.0-42-amd64-x86_64-with-glibc2.36 (OpenSSL 3.5.4 30 Sep 2025, glibc 2.36)
    [debug] exe versions: ffmpeg 5.1.8-0 (setts), ffprobe 5.1.8-0
    [debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2025.11.12, curl_cffi-0.13.0, mutagen-1.47.0, requests-2.32.5, secretstorage-3.5.0, sqlite3-3.51.1, urllib3-2.6.0, websockets-15.0.1, yt_dlp_ejs-0.3.2
    [debug] JS runtimes: deno-2.6.3
    [debug] Proxy map: {}
    [debug] Request Handlers: urllib, requests, websockets, curl_cffi
    [debug] Plugin directories: none
    [debug] Loaded 1854 extractors
    [debug] Fetching release info: https://api.github.com/repos/yt-dlp/yt-dlp/releases/latest
    Latest version: stable@2025.12.08 from yt-dlp/yt-dlp
    yt-dlp is up to date (stable@2025.12.08 from yt-dlp/yt-dlp)
    [bbc.co.uk] Extracting URL: https://www.bbc.co.uk/programmes/m002pv5r
    [bbc.co.uk] m002pv5r: Downloading video page
    [bbc.co.uk] m002pv5r: Downloading playlist JSON
    [bbc.co.uk] m002pv5q: Downloading media selection JSON
    [bbc.co.uk] m002pv5q: Downloading MPD manifest
    WARNING: [bbc.co.uk] Failed to download MPD manifest: HTTP Error 403: Forbidden
    [bbc.co.uk] m002pv5q: Downloading m3u8 information
    WARNING: [bbc.co.uk] Failed to download m3u8 information: HTTP Error 403: Forbidden
    [debug] Formats sorted by: hasvid, ie_pref, lang, quality, res, fps, hdr:12(7), vcodec, channels, acodec, size, br, asr, proto, vext, aext, hasaud, source, id
    [debug] Default format spec: bestvideo*+bestaudio/best
    [info] m002pv5q: Downloading 1 format(s): mf_cloudfront_nonbidi-340-1
    [debug] Invoking hlsnative downloader on "https://aod-hls-uk.live.cf.md.bbci.co.uk/usp/auth/vod/piff_abr_full_audio/3399d8-m002pv5q/vf_m002pv5q_1981d568-eb5e-4ce6-a4bc-8768d2453a65.ism/vf_m002pv5q_1981d568-eb5e-4ce6-a4bc-8768d2453a65-audio_eng=320000.m3u8"
    [hlsnative] Downloading m3u8 manifest
    [hlsnative] Total fragments: 563
    [download] Destination: 6 Music Artist Collection, David Bowie, David Bowie Changeling - Episode 1 [m002pv5q].mp4
    [download]   7.6% of ~ 144.13MiB at    5.41MiB/s ETA 00:25
  5. Originally Posted by cedric8528 View Post
    With Windscribe VPN
    https://gofile.io/d/jzq0W9
