Hi guys,
i'm not really experienced but at the moment I use StaxRip for reencoding videos from H264 to H265.
Now I would also remove watermarks,
i have seen InpaintDelogo is a script for AviSynth that i could use.
But i need help to get how to load into StaxRip and how to use it.
I'm not very confident by using AviSynth+
For a test i have open the video by using VirtualDub and it displays the video already without watermark !
Can't you encode avs scripts in StaxRip? VirtualDub is dated. I use MeGUI for encoding.
I don't know how to load, execute and apply the mask to the video :/
I just went through the process of setting up from scratch the delogo removal tool inpaintdelogo and vs-propainter and documented the steps in the following two posts.
Inpaintdelogo work pretty well and isn't too hard to setup.
https://forum.videohelp.com/threads/411732-Removing-Logo-Text-From-Videos/page2#post2789176
vs-propainter works very well but is more complicated to setup and use. It is also significantly slower.
https://forum.videohelp.com/threads/411732-Removing-Logo-Text-From-Videos/page2#post2789632Last edited by johnnyquid; 1st Feb 2026 at 20:12. Reason: Correct the Inpaintdelogo link. The vs-propainter link was duplicated.
both links show the same post that is about manually setting up vs-propainter, you might want to adjust the Inpaintdelogo link.
Help needed remove watermarks from video files using ai watermark softwares
By barry25 in forum Video ConversionReplies: 6Last Post: 27th Oct 2024, 19:08 -
ELI5/n00b Guide - Ripping DVDs
By SyCoREAPER in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2024, 11:31 -
Program to remove watermarks and logos
By Karn in forum EditingReplies: 3Last Post: 8th May 2024, 13:52 -
need help 3 questions remove blackbars and adverts and watermarks video
By barry25 in forum Authoring (DVD)Replies: 6Last Post: 28th Oct 2023, 12:26 -
Avisynth:remove logo flickering?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2021, 11:55
