Hey all, I ripped my 3D Blu-Ray disc using BD3D format (AVC+MVC). I then converted it to Frame Sequential using BD3D2MK3D. Following that, I upscaled each frame to 4k using Topaz AI. The resulting video is a frame sequential (left eye first) 3840x2160 video at 47.592fps.
I'm looking to take this video and convert it to Half SBS. Essentially, what needs to happen is;
- Extract even frames → Left eye
- Extract odd frames → Right eye
- Scale each eye to 1920×2160
- Stack them horizontally to create 3840x2160 frames
- Output at half the frame rate. Naturally, if the process is taking one left and one right frame and stacking them horizontally, the resulting frame rate should be ~23.796 fps since its using 2 input frames to create 1 output frame.
I've tried many different variations using FFMPEG and the result is never quite right. I figured I'd post here to see if anyone has any experience converting frame sequential to Half SBS. Any help would be awesome! Thanks
IMO, it is much simpler to upscale the video to UHD during the conversion of the original BD to Full-SBS (not frame-sequential!) with BD3D2MK3D. You should just add the resize command in the avisynth script __ENCODE_3D_MOVIE.avs generated by BD3D2MK3D before launching the conversion.
For example, replace this line:
left = SelectEven(interleaved)
with:
left = SelectEven(interleaved).LanczosResize(3840, 2160)
And, of course, do the same modification for the right view.
It's easier, much simpler, quicker and you will not lose quality due to the two encodings.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
Is it possible to shift a video with half a frame?
By Bencuri in forum EditingReplies: 28Last Post: 2nd Nov 2025, 22:14 -
How to convert full sbs to half top OU with ffmpeg?
By maysider in forum User guidesReplies: 25Last Post: 7th Feb 2024, 07:14 -
Easy way to convert "frame packed" 3D to SBS
By rsslcs in forum Blu-ray RippingReplies: 5Last Post: 26th Jul 2022, 16:09 -
Which SBS format is the same as a Frame Packed movie?
By ebruce in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2021, 08:23 -
Converting vhs-c tapes with 3d field sequential video from Toshiba 3d cam
By johnr4546 in forum Authoring (Blu-ray)Replies: 15Last Post: 2nd Sep 2021, 15:55
