I recently updated K-Lite Codec Pack and I noticed a weird behavior of MadVR. AVI videos with AVC compression (x264 or x264vfw) appear dull, washed out like having set saturation to half or less. I think it might has to do with my monitor profile, because they look normal if I switch from MadVR to Enhanced Video Renderer or I play them in VLC. I didn't change anything, my monitor is set to PC Levels (0-255), 8-bit native bitdepth and none in 3D format. In HDR section I chose Let MadVR decide. When playing .MP4 or .MKV with AVC compression or any other video file, including .AVI files with other compression they all look fine. If I switch from MadVR to EVR all videos, including .AVI with AVC compression look fine. I don't know how to fix this. Please help me, I prefer MadVR to EVR.
Thank you in advance.
PS: Please resist the urge to tell me it is not a good idea to put AVC video in .AVI container and use .MP4 or .MKV I already know that, but I frequently use VirtualDub to edit videos and .AVI is the only format it can save to. Besides, I don't like bugs, all videos played perfectly before updating to latest K-Lite codec pack. What changed now?
[Attachment 90917 - Click to enlarge]
[Attachment 90918 - Click to enlarge]
Why don't you try vdub2? It's a fork that started about 5 years ago and is still active.
It can save to those other formats :
https://www.videohelp.com/software/VirtualDub2Last edited by davexnet; 22nd Jan 2026 at 14:02.
My bad, I didn't say I am using VirtualDub2, not the original VirtualDub version. I know it can export to other formats, but I prefer to use the .AVI format as long as I can compress the video to AVC (x264vfw) or HEVC (x265vfw) or AV1 (xav1vfw) and many other formats. AVI 720p or 1080p videos compressed to AVC with MPEG or AC3 (Dolby Digital) sound are accepted in MultiAVCHD to produce an AVCHD disk without processing, so it doesn't degrade the quality. I don't have to convert them to .MP4 or .MKV first. So I open the HD video in VirtualDub2, edit it, compress to AVC and I am good to go. The reason I prefer VirtualDub2 is because it is easy to use, it is frame accurate and it has many filters I cannot find in other applications.
TMPGenc MPEG Smart Renderer 6 + Added tags on video
By kalemvar1 in forum EditingReplies: 7Last Post: 11th Nov 2025, 00:27 -
Mac Video Editor Similar to VideoRedo or TMPGenc Smart Renderer?
By Robert Simandl in forum MacReplies: 1Last Post: 6th Jul 2025, 18:29 -
Optimal Method For Dumping Audio, Video, and VBI In Near-Perfect Sync?
By JaycieErysdren in forum Capturing and VCRReplies: 2Last Post: 6th Sep 2024, 11:29 -
Is there a video player to pause/play 2 videos at once in perfect sync?
By imkira3 in forum EditingReplies: 18Last Post: 25th Jun 2024, 13:33 -
Enhanced Video Renderer not installed
By amirhamdi in forum Software PlayingReplies: 0Last Post: 21st Dec 2023, 09:09
