The source is a 15 second, 1920x1080@30fps static shot of someone sitting and talking. The playhead is on the first frame. I use roto brush to select the person and press "freeze" to analyze the footage. When it's done, I notice that there's just a few frames about halfway through that need some adjustments. Can I do something about that without having to wait for the whole thing to be re-analyzed? If I unfreeze the layer, AE just starts doing its thing again.
I saw a Youtube tutorial where someone made the selection in the first frame and then went frame by frame manually before freezing. Makes sense, I guess, although there's almost always something to correct after freezing anyway.
My workflow:
1. With playhead on the first frame, select whatever I need to rotoscope, then I make various adjustments in the Roto Brush & Refine Edge panel as needed.
2. Press the play button in the preview panel (or the spacebar) so that AE rotoscopes frame-by-frame automatically. If the rotoscope goes wonky, I go to that frame, make corrections, then I hit the play button (or spacebar) again so that AE makes the necessary corrections from that point forward.
3. After I get the rotoscoping correct THEN I hit the freeze button to lock down the matte to prevent recalculating.
You can unfreeze to make changes after freezing, then freeze again. -
A ram preview renders and stores frames in memory for smooth playback.
Freezing locks down the matte so that AE does not recalculate it.
7Plus Downloading (2025)
By bman6 in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2025, 17:48 -
tsMuxeR 2.7.0 (April 21, 2025)
By hardkid in forum Blu-ray RippingReplies: 2Last Post: 11th Dec 2025, 01:56 -
NBC Download [11/2025]
By zimmerma379 in forum Video Streaming DownloadingReplies: 6Last Post: 25th Nov 2025, 14:53 -
Is there anything better than a Dazzle DVC 103 in 2025?
By Ady25 in forum Capturing and VCRReplies: 11Last Post: 16th Jun 2025, 17:50 -
PBS subtitles in 2025
By beejaykas in forum SubtitleReplies: 3Last Post: 29th Jan 2025, 03:06
