Hi guys. I have a cable operator who also offers access to its iptv channels via Android app. I've managed to determine the logic of obtaining mpd (m3u8) links but the problem is they are protected by x-play-auth header. The header changes with every channel change and so far I've managed to play them using a python script with streamlink in Windows but I have to manually enter the channel number. Is there any way I can set up a proxy to serve the links with appropriate header so that I can use mpd (m3u8) list in TiviMate for example? The working way so far is:
Code:streamlink --http-header x-play-auth="hash-xxxyyyzzzddd..." "https://xxx.yyy.ddd/channel/index.m3u8" best
Hello, first of all you can use the m3u or xtreamcode file in python to download just the live stream, series or video from python I did it in vb.net to download movies or series.
I need it for streaming because its legal ott. The streams don't have DRM but they are protected with x-play-auth header.
With some research, here's a version of how to get the x_play_auth of the channel plus using the TiviMate app:
HTTP request1) Login / session creation
2) Request “play channel” API
3) API response returns:
- play_url (m3u8)
- x-play-auth
4) Request M3U8 with x-play-auth header
API responsePOST /api/play
Authorization: Bearer <access_token>
Content-Type: application/json
"channel_id": 101,
"device_id": "android_tv",
"profile": "ott"
Python example (generic){
"play_url": "https://xxx.yyy.ddd/channel/index.m3u8",
"x_play_auth": "hash-xxxyyyzzzddd",
"expires_in": 30
Code:import requests API_PLAY = "https://api.xxx.yyy.ddd/play" def get_x_play_auth(channel_id, access_token): headers = { "Authorization": f"Bearer {access_token}", "Content-Type": "application/json", "User-Agent": "AndroidTV" } payload = { "channel_id": channel_id, "device_id": "android_tv", "profile": "ott" } r = requests.post(API_PLAY, headers=headers, json=payload) r.raise_for_status() data = r.json() return data["x_play_auth"] x_play_auth = get_x_play_auth(101, ACCESS_TOKEN)Check the Android app network trafficCode:streamlink --http-header x-play-auth=<token> <m3u8> best
- Look for endpoints named:
- /play
- /stream
- /watch
- /channel
- Inspect JSON responses or headers
The token is returned, not computed. -
I've made a python script which lists channels and enables me to type in a channel number and the channel plays fine using the streamlink command. What I'm looking for is to be able to have a full list of channels in tivimate instead of having to type in channel numbers.
You expose a static M3U playlist to TiviMate, and your Python code:
Architecture (what actually works)receives channel requests
generates x-play-auth
launches Streamlink (or proxies HLS)
returns the stream
Static M3U playlist for TiviMate
Create playlist.m3u:
Python proxy using Streamlink#EXTM3U
#EXTINF:-1 tvg-id="101",Channel 1
http://YOUR_PC_IP:8080/ch/101
#EXTINF:-1 tvg-id="102",Channel 2
http://YOUR_PC_IP:8080/ch/102
#EXTINF:-1 tvg-id="103",Channel 3
http://YOUR_PC_IP:8080/ch/103
..etc- starts Streamlink when TiviMate requests a channel
injects x-play-auth
streams back to TiviMate
Code:from fastapi import FastAPI from fastapi.responses import StreamingResponse import subprocess import time app = FastAPI() CHANNEL_URL = "https://xxx.yyy.ddd/channel/index.m3u8" def get_x_play_auth(channel_id): # YOUR existing working logic return generate_token(channel_id) @app.get("/ch/{channel_id}") def play_channel(channel_id: int): auth = get_x_play_auth(channel_id) cmd = [ "streamlink", "--http-header", f"x-play-auth={auth}", CHANNEL_URL, "best", "-O" # output to stdout ] proc = subprocess.Popen( cmd, stdout=subprocess.PIPE, stderr=subprocess.DEVNULL ) def stream(): try: while True: data = proc.stdout.read(8192) if not data: break yield data finally: proc.terminate() return StreamingResponse( stream(), media_type="video/MP2T" ) Run it: uvicorn proxy:app --host 0.0.0.0 --port 8080 - starts Streamlink when TiviMate requests a channel
Thank you.
With your pointers and the help of Copilot AI, I was able to accomplish what I needed.
[Release] Nv.auth.Vers2.2.2, DRM and Windows 7
By G.T.X.R in forum Video Streaming DownloadingReplies: 14Last Post: 8th May 2026, 12:37 -
Need Help With Header Info
By Damundai in forum Video ConversionReplies: 3Last Post: 18th Jul 2025, 17:25 -
Need help getting header from site
By jjpasta in forum Video Streaming DownloadingReplies: 11Last Post: 11th Jul 2024, 20:46 -
header problem
By ffilfernandes in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2023, 04:09 -
Streams behind HTTP AUTH cannot be retrieved?
By dsm in forum Video Streaming DownloadingReplies: 3Last Post: 3rd Sep 2023, 10:52
