Page 6 of 6
FirstFirst ... 4 5 6
Results 151 to 157 of 157
    Jan 2026
    Melbourne, Australia
    Originally Posted by aramkolt View Post
    Still giving me no "preview" difference on either side of the slider with ProRes files For trimming purposes, I think you also might want a mode to have the preview window be the full screen of the "after" so you can tell how you're trimming the left edge.
    The slider issue has come up before, it's on my radar. Thanks!
  2. Very nice and convenient GUI. A minor preview issue: With interlaced content and disabling any processing filters, the "Processed" frame on the right of the slider seems to lag one frame compared to the "Original" frame.
    Any chance that the SRestore filter will be added in future? It's very useful to fix (deblend) poorly framerate converted stuff.
  3. Banned
    Oct 2026
    London
    hii
  4. @StuartCameronCode I'm so incredibly excited to see this and I join this community in thanking you for this excellent tool! Please please please can you add MOV output as V210 uncompressed, available via FFMPEG? I realize FFV1/HuffYUV/FFVHuff are lossless, but AVI does not play well with Mac, and these codecs can't be used in Premiere/Resolve etc... which means they have to be transcoded as a second step to V210 anyway for use in pro workflows. And as a humble second note, Vapoursynth's ColorMatrix is specifically useful to convert Rec.601 to Rec.709 when starting with old analog SD footage and properly converting it for the modern Rec.709 world (so many people skip this step because they're "close enough"). Even when doing no further color correction, this simple color space conversion is so valuable, any way it could be added as an option, before upscaling?
  5. ^^^^
    +1 for the ColorMatrix/Colorspace request (by flagging and/or converting the Colorspace). It usually matters in the context of upscaling SD to HD for example.
  6. I use vapourbox to upscale my vhs/dvd capture. The footage is 720x576 mpeg2.
    I upscale the footage 2x and resize it to 1440x1080. At the end I add a border to make the footage 1920x1080.
    This al works but in the preview windows the processed footage aspect ratio looks squashed.
    In the final render the aspect ratio is oke
    Oct 2018
    Town Spa Pizza, United States
    Has anyone experienced render fails when having both Vapourbox and Hybrid installed? When I have both installed I get a crash on the same files.
