Page 5 of 5
FirstFirst ... 3 4 5
Results 121 to 150 of 150
  1. Originally Posted by _Al_ View Post
    that message tells you repeatedly, that is is VFM filter that accepts 8bit only
    Ok, so that is to say that not all features (including inverse telecine - which I think is what VFM was doing here) work with 10 bit video such as ProRes422?
    Selur's Hybrid nor Staxrip seems to have the problem with IVTC'ing ProRes based on prior testing.
    Jan 2026
    Melbourne, Australia
    Ok kids, you can stop arguing - I added an IVTC / ProRes422 workaround in the latest 0.9.10 release.
    New release - v0.9.10!!!
    https://github.com/StuartCameronCode/VapourBox/releases
    Since I last updated on here we've now got:
    - Frame accurate seeking in the preview window*
    - Inline warnings about quality loss if filters require a lower bit depth
    - Frame rate fix for field-coded interlaced sources
    - Support for MacOS versions all the way back to 12.0 for Intel CPUs
    - Lots of other behind the scenes fixes and test suites to prevent regression bugs
    Please report any new issues to https://github.com/StuartCameronCode/VapourBox/issues so I can keep track of everything. Thanks everyone!
  3. Thanks for the update!
    Preview window works at least for crop, but the detelecine doesn't nor does the split screen aspect at least for me, see attached - says "no preview" on the left and right side still appears interlaced despite IVTC filter
    I can post a Google Drive link to a relatively short ProRes422 unprocessed (still interlaced) capture file if that'd be helpful.
    Thanks for all of your hard work, seems like a great interface, I just seem to still find roadblocks on the Mac ARM version at least.
Name:	Screenshot 2026-07-02 at 4.23.42 PM.png
    Jan 2026
    That'd be helpful if you could, thanks!
  5. has anyone had any issues with loading video ts folders into vapourbox? i can load individual vob files, but whenever i try to load a video ts folder it always "fails." tia if anyone has any suggestions.
  6. Originally Posted by StuartCameronCode View Post
    Here's a link to the video I was testing it with: https://drive.google.com/file/d/1tZktiQhx1KIkKllOre_Zb-Sm0ncvgYOf/view?usp=sharing
    It should be IVTC-able since it's a music video that would have been shot at film rates and is just a typical ProRes 10 bit capture. Thanks!
  7. Originally Posted by aramkolt View Post
    Your video is field blended. It can't just be IVTCed.
    Here an attempt of a fix (video only, first 1000 frames):
  8. Originally Posted by Sharc View Post
    Interesting - this came off of a U-Matic distribution copy of the music video which would have been used and entities like MTV. Basically all such U-Matic content I've come across does fine with IVTC, so wonder why this one ended up different?
  9. Originally Posted by aramkolt View Post
    My best guess: Because the source was not 24fps film but 25fps (ore some artwork mix) which got poorly framerate converted by fieldblending instead of applying proper pulldown.
    May 2005
    PAL User
    Super minor points, the program "Close" cross at the top right of the window only appears when I put my mouse pointer over the area. It would be good to have it visible all the time.
    The side-pointing arrow entices me to click on it. Nothing happens. I suspect it is indicating that there are more controls, which are at the bottom, so perhaps it should be a down-arrow and the controls panel then pops up immediately below the pipeline item? Or just remove the side-facing arrow altogether?
    [Attachment 93022 - Click to enlarge]
    Jan 2026
    Odd, I'll take a look. The program's not doing anything special to try to hide the close button, so... ? Will add it to my TODO list.
    This has bugged me too for a while but has been low enough down the list I haven't gotten to it. I'd personally like each section to expand and contract in-place rather than showing as another section disconnected below. I'll bump it up the list a bit, thanks.
  12. Originally Posted by jshohio View Post
    the error message i get whenever i try to load a video ts folder into vapoubox contains this line:
    application support/vapourbox/macos-arm64lib/libdvdread.dylib not valid for use in process: mapping process and mapped file (non-platform) have different team IDs.
    i'm hoping this might reveal what the underlying issue is.
    i have the latest edition of vapourbox and mac os 26.5.2
  13. Thank you for creating Vapourbox! I was looking for a high powered deinterlacer/denoiser for Mac OS and since the Hybrid app stopped working on Mac OS, I didn't know what to use until yesterday! I did a render on a video that was very noisey and once I figured out the parameters to use, the video came out extra clean. It got rid of all the noise and maintained the detail of the video. Im excited to include this in my upscaling workflow and I look forward to the potential updates and upgrades to be added to an already fantastic tool! Thanks again!
  14. I did a render the other day using Vapourbox and noticed some “shaking” along edges. I read that it needs “anti-aliasing” filter but I don’t know how to install it in Vapourbox. Can some explain to me like I’m 5 years old on how to do it? Any help will be much appreciated.
    May 2005
    PAL User
    "Shaking along edges" sounds like lack of a stabiliser of some type. Could you be more specific, or post a short capture showing it?
    Jan 2026
    Can you log this as an issue please on https://github.com/StuartCameronCode/VapourBox/issues please? I'm trying to keep everything in one place, as I'm not checking this forum very often at the moment.
    Jan 2026
    Hey everyone, I've had a busy weekend.
    New release - v0.9.11!!!
    This is a massive new release - there has been a big overhaul to the UI focusing on usability, especially for new users... and finally an actual app icon. Additionally there's a bunch of new filters and parameters you can play with, a bunch of bug fixes including a patch to fmtconv used by QTGMC affecting MacOS and Linux users (that was a deep dive!) that addresses reported chroma issues.
    Check out the release notes for all the details.
    Please report any new issues to https://github.com/StuartCameronCode/VapourBox/issues so I can keep track of everything. There's a new option in-app to report bugs & feedback that will link you to the same place.
    Thanks everyone!
  18. Member
    May 2005
    PAL User
    A question, each time we install a new version, a big download occurs. Are the old-download files deleted automatically?
    Jan 2026
    It'll only do the download if the tool bundle needs updating, which for the last few app updates has been required, but it's not always the case. It overwrites the existing installed bundle, so don't worry about having to delete the old one.
  20. Tool definitely has come a long way - Still doesn't preview 10 bit ProRes422 files though and crop settings I'm not sure exactly how you'd visualize pre and post since the slider can't slide all the way to the left, so you're kind of guessing how much to crop from the left side unless I'm missing something. Still just tried the Mac ARM version if that matters. Guessing this uses similar stuff under the hood as Hybrid and there's no issues with ProRes files there as far as I can tell.
    Thanks again for working on an alternative tool!
  21. I did also try it with a ProRes422 file just for the heck of it even though preview didn't work. It seemed to ignore my rescaling/upscaling setting and also didn't actually crop anything even though it was set to. The actual QTGMC deinterlace part seemed to have worked though, but not very usable as is if it ignores the rest of the settings for me anyway.
  22. Member
    Jan 2026
    Yeah I haven't still done much testing with ProRes422 beyond the initial import failure, that'll be next on my list to take a look at because it's pretty fundamental. And broadly speaking it runs the same filtering logic under the bonnet but how it's all plumbed together is a bit different to Hybrid so will have a different set of issues.
  23. Member
    Oct 2002
    Finland
    This is excellent software! I’m glad I found it. Old VHS captures can have dropped frames or irregular timestamps, which may cause the audio to drift out of sync during editing. Is there a way to convert them to a constant frame rate?
  24. Member
    Jan 2026
    New release - v0.9.12!!!
    Lots of stuff here - I've updated to the latest VapourSynth, incorporated a massive speed-up for Apple Silicon / ARM-based QTGMC processing, comprehensive ProRes 10bit support, lots of bug fixes...
    Thanks everyone!
  25. Member
    Jan 2026
    I haven't had this happen with my local setup, I'll leave this open to others to discuss.
  26. Member
    May 2005
    PAL User
    Stuart,
    I don't know if Vapourbox is supposed to de-interlace AVC (an odd combination, I know) but have a look at the files in this post:
    https://forum.videohelp.com/threads/421026-LG-V281-DVD-VCR-Combo-USB-Capture-Card-stra...e6#post2803330
    VB won't deinterlace them with QTGMC but VDub will.
  27. Originally Posted by Alwyn View Post
    Stuart,
    Interlaced AVC is not at all an odd combination btw., but the file which you refer to is plain crap.
  28. Member
    May 2005
    PAL User
    @Stuart, QTGMC itself (via AVISynth) deinterlaces it OK.
  29. Originally Posted by Alwyn View Post
    Well, no deinterlacer can deinterlace that .mkv file properly because the chroma of the 2 fields is flawed, means the chroma advances with every 2nd field (or with every 2nd "deinterlaced" frame) only which manifests as ugly chroma blends/lags/trails in the "deinterlaced" variant.
    No idea at which stage of the poster's (@buddy) workflow the chroma got mistreated. Maybe a capture issue, maybe a flawed 4:2:2 interlaced -> 4:2:0 interlaced conversion, plus wrongly encoded (and flagged) as progressive. Hence no point for VapourBox to "deinterlace" this.
    Edit:
    And btw. VapourBox deinterlaces properly interlaced AVC perfectly. No need to investigate or change anything IMO.
  30. Still giving me no "preview" difference on either side of the slider with ProRes files For trimming purposes, I think you also might want a mode to have the preview window be the full screen of the "after" so you can tell how you're trimming the left edge.
