Results 91 to 111 of 111
I've just pushed out a new v0.9.2 release of VapourBox!
Enjoy!
Based off feedback, here's the changes:
Film Restoration Filters
- DeScratch — Remove vertical scratches from scanned film (spatial, single-frame analysis)
- SpotLess — Remove dust, dirt, and temporal spots using motion-compensated median filtering
Chroma Fixes
- Chroma Shift (Y/C Delay) — Precisely align chroma planes with sub-pixel accuracy for analog sources
- Fixed method dropdown showing alongside individual checkboxes in Chroma Fixes
Bug Fixes
- Fixed preview template unconditionally marking clips as field-based, causing resize errors with some filters
- Fixed DeScratch compatibility with field-based clips and non-8-bit formats -
And v0.9.3 is out with a hot fix for a path issue when reading from physical DVDs.
It handles FFV1 lossless compression already, I've never used HuffYUV but it looks to be quite ancient. Any particular reason for that choice? It looks like ffmpeg handles it already so I can probably expose it without much drama in a future release.
If nobody else asks for it then leave it be and pursue what others may find a good addition. HuffYUV is a popular capture and processing codec in the VHS/ analog video to digital realm. There are a few versions, I think 32 bit 2.1.1 being the recommended I use but I'd have to recheck that.
Sure, but so are UTVideo in all its variants and options, Lagarith or the already included virtual lossless ProRes variants. Maybe we should not overload the tool, as it still claims to be more convenient and easier to use than some other more complex GUIs
IVTC could include more telecine patterns, SRestore could be added to deblend oddly frame converted stuff ... where do the wishes end?Last edited by Sharc; 10th Apr 2026 at 13:25.
I agree with not bloating the tool.
The developer will decide what if any changes are made.
For now I will sit back and watch because in a scrum betwixt a Cod, a Sharc, and a Crab, the Crab loses every time. -
Liking this tool a lot. It already covers most of the bases for filters, while not being bloated like Hybrid.
What about Santiag (or if there is something better...) for anti-aliasing? I was going to suggest a mosquito noise filter such as MosquitoNR, but I don't think it was ever ported to VapourSynth. -
I'll add them to my TODO list of things to suss out.
I've spent a bunch of time working on adding linux support as there have been a few requests for that, and it's all mostly working other than a few filter issues and what seems like some preview race condition stuff.
I've also got a fix for a path issue when ripping DVDs directly from source media on Windows, so I'll bundle up a bug fix release when I've got time for that.
I'm just glad people are finding this useful, thanks for the feedback everyone.
Greetings, new user here. First and foremost thank you for providing this tool, I just found it and already am liking it. But...
Im getting an error if I choose any of the NVENC encoders. I thought maybe it crashed or whatever maybe Windows is acting stupid again so I immediately tried NVENC with Staxrip and sure, all is working fine there. Im getting this error in VapourBox 'Decoder ffmpeg exited with error code -22'. Getting the same error on HEVC and x264. Vanilla, aka software, encoders for those work just fine. GPU is a measly T400 with 2GB of RAM (running on Win10 x64) but it works just fine in Staxrip/Hybrid.
Any ideas or suggestions are more than welcome.
Thank you. Cheers! -
Not every model of NVidia card will support NVEnc.
Check to see if your card will support it here:
https://developer.nvidia.com/video-encode-decode-support-matrix
also:
Google is your friend:
From Google:
The error code -22 in FFmpeg corresponds to EINVAL (Invalid argument), indicating that the command line parameters or codec settings provided to the encoder are incorrect. In the specific context of an NVIDIA Quadro T400, this error often manifests during hardware encoding attempts using NVENC (e.g., h264_nvenc) when specific parameters like bitrate, profile, or buffer sizes are mismatched or unsupported by the driver.
Common Causes and Solutions for Quadro T400
Driver Compatibility Issues:
Specific NVIDIA driver versions, such as 550.54.14, have been reported to cause NVENC failures on Quadro T400 and GTX 1650 cards, resulting in "Failed locking bitstream buffer: invalid param" errors.
Solution: Roll back to a stable driver version, such as 550.40.07, which has been confirmed to resolve this specific NVENC bug.
Invalid FFmpeg Arguments:
The -22 error can also result from incorrect FFmpeg command syntax, such as using an unsupported output format (e.g., -f vob in newer FFmpeg versions) or mismatched audio/video codec parameters.
Solution: Review the FFmpeg command for unsupported flags. For NVENC, ensure the profile (e.g., main or high) and level are compatible with the Quadro T400's capabilities.Last edited by tvd051955; 8th May 2026 at 08:56.
Well I am at least one interested in using this as an alternate to Hybrid.
But I cannot use this tool as it's not built for Intel based Macs but for ARM64.
There are many of still using their "legacy" Macs for "legacy" videos like VHS.
I capture on Mac (using Matrox MXO2) and process on Mac as mentioned already, Hybrid has not been updated for macOS for a while now and your tools looks promising.
I put in a request on your GitHub for an Intel build.
I tried building VapourBox myself but there are too many hurdles and errors in building it.
Your build scripts are not working for me. -
Mister Cod has been quiet regarding his wonderful app, hope all is fine.
Perhaps a bit more is coming but we won’t know until we see it. -
After a bit of a delay, there's a new 0.9.5 VapourBox release out (finally).
https://github.com/StuartCameronCode/VapourBox/releases
What's New
- New lossless codecs: HuffYUV and FFVHuff, selectable for AVI/MKV output (fast lossless intermediates alongside FFV1).
- macOS builds are now (finally) signed and notarized with a Developer ID — open without Gatekeeper warnings.
Fixes
- MP4/MOV output no longer fails on sources with image-based (PGS/VobSub) subtitles; only text subtitles are mapped to mov_text, image-based tracks are skipped.
- Output paths now use the platform separator on Windows (no more mixed D:\dir/file.mov).
- Preview now reports a clear error on un-analyzed files instead of a cryptic BlankClip: invalid width. -
Looks like the preview issues I've been having might be caused by lack of support for 10 bit color depth?
Here's the error I got with the newest version:
ERROR: Preview generation failed (exit code 1):
Preview: frame 3539 at 118.085s (fps: 29.97)
Decoding 11 frames starting at 117.901s (720x486 yuv422p10le)
Loaded template from: "/Applications/VapourBox.app/Contents/MacOS/../Resources/templates/pipeline_template.vpy"
Loaded template from: "/Applications/VapourBox.app/Contents/MacOS/../Resources/templates/preview_template.vpy"
Generated preview script: "/var/folders/n5/0j9jvgyd5z5cd2px3_7z65j00000gn/T/b75dc609-899e-4674-aece-5fc1754ac2e4_preview.vpy"
Error generating preview: vspipe failed: Script evaluation failed:
Python exception: VFM: input clip must be constant format YUV420P8, YUV422P8, YUV440P8, YUV444P8, or GRAY8
File "vapoursynth.pyx", line 3393, in vapoursynth._vpy_evaluate
File "vapoursynth.pyx", line 3394, in vapoursynth._vpy_evaluate
File "/var/folders/n5/0j9jvgyd5z5cd2px3_7z65j00000gn/T/b75dc609-899e-4674-aece-5fc1754ac2e4_preview.vpy", line 54, in <module>
clip = core.vivtc.VFM(clip, order=0,
File "vapoursynth.pyx", line 3129, in vapoursynth.Function.__call__
vapoursynth.Error: VFM: input clip must be constant format YUV420P8, YUV422P8, YUV440P8, YUV444P8, or GRAY8
[2026-06-01T13:27:26.056360] Starting preview generation for frame 3539
[2026-06-01T13:27:26.281394] Process exited with code 1, output size: 0 bytes -
New release!!!
The big one: VapourBox now runs on Linux, and macOS ships as a single universal build covering both Apple Silicon and Intel.
There's a growing backlog of other issues that I can now finally start chipping away at, this one's been a big time sink.
What's New
- Linux support (x86_64 + aarch64) — VapourBox is now cross-platform across macOS, Windows, and Linux. It ships as a portable tarball; the VapourSynth/FFmpeg dependency stack downloads automatically on first launch (to ~/.local/share/VapourBox/), same as the other platforms. The full filter set is available.
- macOS is now a Universal build — a single signed & notarized DMG runs natively on both Apple Silicon and Intel Macs (Intel support is new this release)..
Fixes
- Preview no longer breaks when toggling filters rapidly — fixed a race condition that could leave the preview stale or errored when filters were switched in quick succession.
- Clearer worker error reporting on Unix — process failures now report the terminating signal (e.g. SIGSEGV) instead of an opaque exit code. -
Super. Many thanks for making this Universal build.
Works very well.
There is an issue that I reported on your Github repo.
You quite nicely included options to select H/W encoders on the Mac for H.264 and H.265 (using Mac's videotoolbox H/W encoders).
You use FFMPEG'soption for videotoolbox encoder.Code:-q:v
However, FFMPEG has not implemented for Intel Macs as it's only for Apple Silicon Macs.
So the output fails with an error.
Would be great to have a solution to use H/W encode on Intel Macs.
looking for a broadcasting tool
By abdo1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2024, 20:37 -
2 recommendations: Tool for creating DivX and Tool for removing DVD menues
By schmutzbrust in forum Video ConversionReplies: 14Last Post: 24th Sep 2022, 21:04 -
Encoder tool?
By BlurayHD in forum Newbie / General discussionsReplies: 7Last Post: 21st Sep 2022, 20:21 -
Help for a recovery tool
By nifaf in forum Video ConversionReplies: 0Last Post: 3rd Jul 2021, 07:15 -
Tool for burn a BD disc?
By BlurayHD in forum Newbie / General discussionsReplies: 10Last Post: 3rd May 2021, 16:12
