I have a couple discs that are absent from the VUK database, and I would like like to read them with Xreveal. (Before someone ask: I'd rather not use MakeMKV, I want to rip correctly from the source.) I followed the tutorial on FindVUK but can't get any results.
First I tried with Passkey, but FindVUK is unable to detect it. I did find the Disc ID in Passkey's log, but not the VUK. I searched through the memory dump of Passkey, but the tutorial didn't exactly specify what the VUK is supposed to look like... Judging by the database it looks like it needs 3 different hex strings? I maybe found one but that's it.
So, I tried with regular DVDFab. The program starts and does nothing. I try to "add source" in the ripper menu of DVDFab and select my drive, and it does nothing. The source does not appear in DVDFab when selected. Do I need to make an ISO of the disc before it? The tutorial only says to insert a disc with DVDFab open, but FindVUK doesn't do anything by itself at that point.
Here's Passkey's report.
Info for drive [D:\] (Passkey 9.4.7.7)
Vendor: ATAPI, Product: iHBS112 2
Revision: PL06, Vendor specific: 2012/09/17 10:50
Drive region: 2 (RPC II), changes left: 4(user) / 4(vendor)
AACS v1, AGIDs: 2, revocation level: MKBv76+
Support: BUS_ENCRYPTION=NO BN_GENERATION=NO
Disc media: Blu-ray (BDMV)
Region Code is removed. (Region B, Region Mask '')
AACS protection (AACSLA) is removed. (MKBv19)
BD+ protection (Macrovision) is removed. (gen7)
BluPath: full disc copy/play is supported.
Main playlist: 00801.mpls
