Hi. I have some DVD's of data files. Some of the DVD's are scratched, and I need to see if I can fix them by buffing out the scratches. Are there any software titles that show a visual display of a disc so I could buff out scratches in a particular area of the disc?
I don't know of any software that displays areas of a disk that have scratches. Try using your eyes with a magnifier lens.
Extraordinary claims require extraordinary evidence -Carl Sagan -
First I have never had much success at buffing out scratches on a disc.
Some do & I probably do not have the right equipment.
Here is an alternative & will give some insight as to where the disc is damaged.
Try ISOPuzzle.
If it reads the whole disc to an .ISO then mount the .ISO in a virtual drive & burn a new data disc.
If it does not read the whole disc you will see red areas on the progress bar.
I have not found any documentation on this but I believe the scratches that are causing problems are in the area on the disc that corresponds to the red areas.
So if you see the red area in the middle the scratched or damaged area is in the middle.
ISOPuzzle can be set to read the disd forever So it will keep trying until you stop it.
It can also use all of your optical drives on the same .ISO.
You can even copy the .ISO & .FLG file to a different computer to use that computers optical drives.
"Unable to load the file" error in Visual Studio Code
By blanc in forum ComputerReplies: 1Last Post: 24th Nov 2025, 10:12 -
Miscellaneous visual issues
By Dreamer in forum FeedbackReplies: 6Last Post: 6th Jun 2022, 15:48 -
DaVinci Resolve File and Folder Locations
By Inky22 in forum EditingReplies: 4Last Post: 2nd Mar 2022, 08:59 -
4K MOV File to Bluray Disc
By techguy817 in forum Newbie / General discussionsReplies: 4Last Post: 27th Jan 2022, 14:08 -
In VSDC FREE, How to pop up random words in random screen locations?
By EricBalir in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2021, 11:10
