I just released Ume Movie Editor - a video editing software that allows for fast and lossless editing of multiple files in one project, without the need to re-encode and without ballooning the file size. Free demo version is available.
Main features:
- Cut, resize, reorder and merge matching video files without losing quality.
- Fully editable subtitles and chapters.
- Easy to use interface with familiar controls: drag, drop, multiselect, undo, redo, autosave, keyboard and mouse shortcuts, zoom, pan etc.
- 10 times faster export speed than the fastest benchmarked competitor, details on the webpage.
- Available on desktop and mobile.
[Attachment 90845 - Click to enlarge]
[Attachment 90846 - Click to enlarge]
[Attachment 90847 - Click to enlarge]
[Attachment 90848 - Click to enlarge]
[Attachment 90849 - Click to enlarge]
[Attachment 90850 - Click to enlarge]
Does it re-encode if I don't cut on a key frame?
Extraordinary claims require extraordinary evidence -Carl Sagan -
Which makes it useless as a proper NLE.the GUI prevents cutting anywhere other than a key frame - it's a limitation by design.
And of course as soon as you apply a burnt-in subtitle (or more-commonly termed "title') you'll be doing a full recode and the encode speed drop drastically. -
It objectively is not useless. Everyone has their own use-case. Mine appeared when I had to edit a lot of vacation footage without losing quality, with added subtitles and chapters. The only way to do it was to juggle LosslessCut, SubtitleEdit, Notepad and MKVMerge. If I made any mistakes, it meant going back in the flow. That workflow was slow, painful and wasteful. That's why I created UME, which has all of these features in one package, speeding things up drastically. If your use-case is different, it might just not be a program for you, but that doesn't make it useless.
The subtitles added in UME are soft subtitles, which do not re-encode. If you meant adding a different kind of subtitles in some other program, then sure, but the same can be said about any other video manipulation in any other video program. -
I just released Ume Movie Editor 1.0.1, changelog below:
Common:
- Feature: Allowing more video extensions in the file picker.
- Feature: Quicker startup through an .ume file.
- Feature: Improved window handling on multi-monitor setups.
- Feature: Updated FFmpeg 8.0.1 -> 8.1
- Feature: Various library updates.
- Fix: Spamming "Delete" no longer creates pointless undo/redo stack entries.
- Fix: Fixed slight icon shift when video is playing.
MacOS:
- Feature: This is the first release with a MacOS port! Enjoy!
Linux:
- Feature: This is the first release with a Linux port! Enjoy!
Android:
- Feature: Significantly reduced the app size.
Looking for a video editor
By RBCC in forum EditingReplies: 3Last Post: 6th Jan 2025, 00:08 -
Video editor without re-encoding ?
By Nagasaki in forum Newbie / General discussionsReplies: 15Last Post: 29th Dec 2024, 23:10 -
About VSDC Video Editor!
By Valentin98 in forum Newbie / General discussionsReplies: 0Last Post: 13th May 2022, 01:51 -
Best video editor to start out with?
By rikard9 in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2021, 08:32 -
Question about Lossless Cut Editor
By FL-Artist in forum EditingReplies: 3Last Post: 6th May 2021, 14:19
