  1. Hi, i'm trying to download this but it's not working on yt-dlp nor ffmpeg
    - https://www.hellorayo.co.uk/podcasts/tims-listening-party
    - https://www.hellorayo.co.uk/podcasts/skin-tings
    you just have a profile or access on this country.
    Anyone have solution?
  2. Originally Posted by Sandi3025 View Post
    inspect your page ctrl+shift+i then go to networks tab then select all tab then search for mp3 then play the podcast you want to download then you will see the mp3 link and right click and copy url then download it via (IDM or YT-DLP or FFMPEG) all work fine
    for example i got this link
    yt-dlp "https://bauernordic-pods.sharp-stream.com/gb/3463/tlp_the_edge_pod_3d24ac40_normal.mp3" -o podcast01.mp3
    ffmpeg -i "https://bauernordic-pods.sharp-stream.com/gb/3463/tlp_the_edge_pod_3d24ac40_normal.mp3" -c copy podcast01.mp3
    I really don't know if there is an easier way than this, but wait for experts they may have better solutions
  3. thanks, but i can't play it because it says "It looks like you are trying to listen to us from outside of the UK. Due to legal reasons, our streams are not available where you are." and you need your postcode so, i don't live in the UK
  4. Originally Posted by Sandi3025 View Post
    use vpn and connect to UK then use any postcode from cedric8528's post
    urbanvpn is free + windscribe
  5. Which postal code do you suggest?
  6. Originally Posted by Sandi3025 View Post
    anything will work.. try
    SW1A 0AA
