I was wondering if anyone here had used VCD Cutter before and your opinnion on it verses other cutters. If you could let me know THANKS!!![]()
it's a nice program to bad it not suport SVCD (yet)
So TMPGEnc are better if u ask me ! :D -
If you want to use it to capture or cut mpeg, it works very good. If you want to merge two mpeg clips, it still isn't perfect.
Vcdcutter is nice. It seems to be totally frame accurate while cutting, while the same can't be said for TMPGenc, at least from my experience. Vcdcutter doesn't produce vcd compliant mpgs however. If you use it to cut you will need to demultiplex and remultiplex as a vcd in TMPGenc, which is kinda a pain.
I think bbmpeg is the best all around cutting program for both vcds and svcds.
Looking for AVI cutter
By rocks911 in forum EditingReplies: 2Last Post: 27th Jan 2012, 16:23 -
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 15:39 -
a video cutter
By Benygh in forum EditingReplies: 5Last Post: 3rd Nov 2009, 15:55 -
DVD Cutter
By akakiami in forum EditingReplies: 6Last Post: 23rd Oct 2008, 07:04
