Hello all, I've noticed that on some of my U-Matic captures seem to have what I'd describe as "chroma ghosting" where either the chroma lags behind the luma or there's some sort of frame blending occurring which can be seen at sharp scene transitions or during rapid movements. It's unclear to me if this is something inherent with edited U-Matic footage maybe? I only seem to see it on commercially produced tapes that were probably originally shot on film.
I've attached a very short clip where you can see the man's hand has multiple ghosts as it moves across her back. I am pretty confident that the tape itself was telecined as some frames do not have interlacing and it was pretty clearly originally shot on film.
Thing is, when I do IVTC, those ghosts are still there.
The sharp scene transition here might just be a "crossfade" so that might not really tell us much about the rest of the ghosting.
This happens to be from Roseanne Cash's Blue Moon and Heartache - There's a different capture of it here starting at 1:14 and the ghosting seems to be there as well, so I presume it somehow got into the master recording: https://www.youtube.com/watch?v=i07roS2Aio0&list=RDi07roS2Aio0&t=74s
Here's the IVTC'd capture I got, but you can still see it is pretty distracting and can't be "unseen":
https://www.youtube.com/watch?v=7I_dtMP1rWY&t=83s
Is it something that can be improved?
That mov is encoded progressively not interlaced, you might want to share a sample that preserves the original fields/format.
Handling what you attached, you can try Cdeblend.
Attaches a sample where I used TIVTC+Cdeblend.
Cu SelurLast edited by Selur; 5th Jan 2026 at 22:30.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Since the video is 4:2:2 chroma subsampled it shouldn't matter that it's encoded progressive rather than interlaced (each line has it's own chroma). The chroma blurring must have happened before it was encoded.
Interesting it shows as progressive - I basically just used an FFmpeg script to trim the original file, so that must have messed with the interlacing flag maybe. I had not heard of Cdeblend, so I will give that a look. Since other captures of the same content has it, must be in the master, but always curious about techniques to reduce "baked-in" issues. Thanks!
Odd chroma rainbow flickering on U-Matic capture
By aramkolt in forum EditingReplies: 4Last Post: 27th Jul 2025, 15:41 -
U-Matic Capture Experiments with Non-Traditional Capture Setup (SDI/ProRes)
By aramkolt in forum Capturing and VCRReplies: 10Last Post: 4th Apr 2025, 01:31 -
How do you fix this kind of motion blur or ghosting or what it might be
By speculumberjack in forum Video ConversionReplies: 2Last Post: 24th Apr 2024, 11:45 -
Is there anyway to fix this video? There is some ghosting / double frames
By stivan21 in forum RestorationReplies: 0Last Post: 18th Sep 2023, 23:33 -
Ghosting and Chroma Ghosting?
By JadHC in forum RestorationReplies: 5Last Post: 2nd Aug 2023, 22:44
