I have an Intel i5 3210M CPU with Intel HD4000 in my laptop. Is there any speed up options for this setup when encoding my video projects to MP4? I have used x264.exe so far. As I know that one automatically chooses all the threads available (my machine has 4). But maybe this is false. If false, what is the parameter to set the number of threads to be used? I also read somewhere, that this coder has an opencl parameter as well, but as I know it does not support Intel HD4000, so I cannot make use of that.
Could the conversion time be reduced compared to x264.exe if I used ffmpeg with this setup? I have never used the ffmpeg CLI, I have no clue what speed up options are available there.
you can use a faster preset in either case. For example, in x264.exe
Code:--preset "veryfast"
quality loss vs encoding speed depend on bitrate - if your goal is to provide maximum quality and at the same time lowest possible bitrate then you need to sacrifice time - a lot of time - this is primary rule of encoding since 40 years or more...
If you can accept higher bitrate then you have possibility to speedup encoding.
You can also try instead pure software encoder to use Intel hardware/hybrid mode encoding - try https://www.videohelp.com/software/QSVEnc or QSV in ffmpeg (not sure if your CPU support Vulkan but seem there are some work to offer Vulkan accelerated encoding in ffmpeg recently so it is possible to use 'h264_qsv' and 'h264_vulkan' in recent ffmpeg builds, also DirectX accelerated encoding is available: 'h264_d3d12va').
You need to assume that hw accelerated encoders need slightly higher bitrate (10..30%) to deliver same quality as pure software encoders but speed gain can be enormous - it is up to you to operate within area limited by 3 points: encoding speed, bitrate, quality. -
To be more exact, on the speed up what I am talking about I meant something like what Vegas uses. If it would be possible to replicate it. Vegas has a rendering option called Sony AVC, if you use that one and not the Main Concept AVC option, it does the encoding much much faster. You can select the encoding hardware resource on the rendering panel, if you set it to automatic (the other two are CPU or GPU only), you get the encoding speed increase. That would be great if something like that could be replicated in a CLI. As I mentioned using the GPU is not possible with x264.exe with my hardware (at least not with the versions that I tired).
I don't know anything about the mechanism how the speed up is achieved in Vegas, but it can do it. I guess it uses OpenCL + CPU, doesn't it? -
I have the same Intel CPU in my notebook. The CPU has a GPU (HD4000) by Intel, which can encode videos in h264 with hardware acceleration.
It is much faster than encoding with your CPU. For a preview video it is okay. If you want more quality, the only way is software encoding with x264.
Your CPU has 2 cores, which can use 4 threads. The hardware encoding with gpu is much faster, but produce less quality than encoding with x264.
A good tool for conversion is handbrake from www.handbrake.fr. It supports software and gpu hardware encoding for Intel, NVIDIA and AMD GPUs.
A very useful tool with powerful options for video quality and also good for beginners.
https://www.videohelp.com/software/HandBrake -
So your goal is intra coding - you can substantially speedup encoding by eliminating large set of time consuming operations - but bitrate in such case growing also significantly thus quality is hold.
Let say this is your goal:
https://en.wikipedia.org/wiki/AVC-Intra?useskin=vector
https://resources.avid.com/SupportFiles/attach/FAQ_AVC-Intra.pdf
I used in past something like:
ffmbc is for of ffmpeg focused on broadcast technologies https://github.com/bcoudurier/FFmbcCode:@ffmbc -i %1 -vcodec libx264 -crf 1 -profile HIGH422 -preset ultrafast -tune fastdecode -x264opts "keyint=1:constrained_intra=1:cabac=0:ref=0:sliced_threads=0:threads=4:psy=0" -f mpegts -psnr %1.trp
but ffmbc is quite old and outdated then yo may consider to use ffmpeg with something like:
This is not pure intra as it use P frames anyway but you can force pure intra by setting 'keyint=1', also you may change profile to more optimal from your source perspective (like 422).Code:@setlocal @REM Where to Find ffmpeg @set FF=%CD% @set PATH=%FF%;%PATH% @rem set /p qpval=Enter QP value (e.g 16, reasonable range 8 - 24, lower = higher quality and higher bitrate): @set qpval=16 @echo QP value is: %qpval% @SET x264opts="qp=%qpval%:qpmin=4:level=4.1:ref=0:bframes=0:no-chroma-me=1:subme=2:open_gop=0:keyint=2:sliced_threads=0:slices=-1:bluray_compat=1:pic_struct=1:aud=1:force_cfr=1:cabac=0:threads=auto:no_psnr=1:no_ssim=1:colorprim=bt709:transfer=bt709:colormatrix=bt709:stitchable=1:constrained_intra=0:no-psy=1:scenecut=0:no-deblock=1:aq-mode=0:ipratio=1.1" @ffmpeg.exe -y -hide_banner -v 32 -i "%1" -an -c:v libx264 -preset:v ultrafast -tune:v fastdecode -profile:v high444 -x264opts %x264opts% -x264-params %x264opts% -f mpegts "%~n1_.ts" @pause
Also x264 support avc intra - there are at least two options to control this kind of encoding:
You can use ffmpeg with this options.Code:--avcintra-class <integer> Use compatibility hacks for AVC-Intra class - 50, 100, 200, 300, 480 --avcintra-flavor <string> AVC-Intra flavor ["panasonic"] - panasonic, sony
https://superuser.com/questions/1675504/ffmpeg-and-avc-intra-class-100-1080p-59-94-60p
As i don't use Vegas then i can't say what type of HW acceleration is used but generally you have three possibilities:
- pure HW encoder - dedicated HW block performing encoding - this is usually part of graphic unit - Intel for example offered this under name QSV,
- pure software but using genera GPU processing (trough OpenCl or similar)
- hybrid mode using some CPU power, perhaps some GPU and dedicated HW block - usually this approach delivers higher quality but also speedup is lower than two earlier mentioned methods.Last edited by pandy; 6th Jan 2026 at 12:17.
These codes that you shared, where do you enter them? I have not seen this kind of coding for ffmpeg.
The ones for x264: do I need to enter them as a parameter for the encoding command?
Unfortunately in Vegas, it only says GPU acceleration, and my GPU is selected, but no more info there. In the rendering panel, you can choose: Automatic, GPU/CPU only, and 2 QSV options.
In connection with the goal: I forgot to mention, that if I could speed up a simple render through Debugmode Frameserver, that would already be a big leap ahead. So no avisynth script running, just rendering the video edited in Vegas, with the same or similar specs as the video source. For example, the recent video has these specs:
Code:General Complete name : C:\Users\bencuri\Videos\Celia\new\Celia R6.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 847 MiB Duration : 56 min 20 s Overall bit rate : 2 103 kb/s Frame rate : 25.000 FPS Writing application : Lavf58.29.100 Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 56 min 20 s Bit rate : 1 968 kb/s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.051 Stream size : 793 MiB (94%) Writing library : x264 core 155 r2901 7d0ff22 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC Audio ID : 1 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 56 min 20 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 51.6 MiB (6%) Default : Yes Alternate group : 1
Need Help Figuring Out FFmpeg’s Default Options
By DeadSkullzJr in forum Video ConversionReplies: 1Last Post: 17th Dec 2024, 09:23 -
ffmpeg tiff compression algorithm options?
By ForSerious in forum Video ConversionReplies: 2Last Post: 27th Feb 2024, 11:21 -
ffmpeg: What are the most compatible encoding options?
By Rekrul in forum Video ConversionReplies: 10Last Post: 1st Sep 2022, 07:07 -
Help with options while switching from x264 to x265
By sienipulla in forum Video ConversionReplies: 2Last Post: 9th Oct 2021, 09:08 -
ffmpeg losing subtitle track converting MP4 to MP4
By the_steve_randolph in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2021, 17:42
