MakeMKV produces read errors.
Results 31 to 38 of 38
So what if there are read errors?
What percentage of the read errors out of the total disk size? -
data2006, you got read errors with isobuster, makemkv, xreveal, and anydvd.
you've got read errors, on two different computers with two different operating systems.
you've been able to get a disc to read one day. and the next day/rip attempt it doesn't. and just produces errors ?
maybe the problems are the drive being used for ripping, the disc themselves. or something happening in the systems/ your computer(s)
you did mention a disc looking clean. but go ahead and clean it anyway. (it can't hurt)
and people have sometimes had problems with new discs being taken directly out if the shrink wrap. and sometimes cleaning has helped.
nothing to lose doing this. and probably not the problem. but let's try to eliminate all the issues we can think of.Last edited by geek gift; 14th Jan 2026 at 20:01.
You also need a compatible drive to rip the disc. Check makemkv website and see if your PC bluray drive is listed or not. Dvdfab is expensive but it is the best one currently. Sometimes you won't get the latest disc decryption keys in trial version. Blue cloner is another one but I don't know how well it can handle new discs.
I agree with the others the problem may be the optical drive.
If possible try another optical drive.
If another drive has errors then it is probably the disc itself. -
Hello,
I've now ripped a different Blu-ray of Once Upon a Time in the West.
I was able to successfully copy the main movie using MakeMKV.
So it seems something is wrong with my Shania Twain Blu-ray. Or the Blu-ray burner isn't compatible with this Blu-ray.
I only have one Blu-ray burner. I can't test another one.
Best regards
Heiko
New to Blu Ray Burning. How do you burn a 42gb Blu Ray ISO on a 8.5 DL DVD
By zipsick in forum Authoring (VCD/SVCD)Replies: 5Last Post: 24th Aug 2026, 22:22 -
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 20:04 -
ISO External Blu-Ray (or 4k blu-ray) burner drive for PC (Windows 11)
By derricomonico in forum Blu-ray RippingReplies: 3Last Post: 16th Sep 2024, 17:16 -
4. k Blu Ray
By biferi in forum Newbie / General discussionsReplies: 26Last Post: 1st Jan 2024, 15:20 -
1 blu ray movie 80gb in 2 blu ray of 40gb
By killbill831 in forum Authoring (Blu-ray)Replies: 2Last Post: 18th Oct 2022, 23:44
