Can someone grab this for me? Requires Czechia IP. Thanks so much
https://www.ceskatelevize.cz/porady/1065818155-pupendo/
You are in luck,
my other half was pestering me for the same movie few days back ....
https://gofile.io/d/Mc5dXY
ivysilani is not part of the services used by Unshackle / Twinvine / Devine / Freevine so you will need:
- Webbrowser add-on [Vineless] (https://github.com/Ingan121/Vineless "Play protected contents without a real CDM.")
- L3 CDM file in WVD format [WVD file] (https://forum.videohelp.com/threads/417425-Real-Device-L3-Cdms " Real Device L3 Cdms.")
- [N_m3u8DL] (https://github.com/nilaoda/N_m3u8DL-RE "Cross-Platform, modern and powerful stream downloader for MPD/M3U8/ISM.")
- [SHAKA-PACKAGER] (https://github.com/shaka-project/shaka-packager "A media packaging and development framework for VOD and Live DASH and HLS applications, supporting Common Encryption for Widevine and other DRM Systems.")
{packager-xxxxxxx} needs to have a file name saved as "shaka-packager"
- [MKVToolNIX] (https://mkvtoolnix.download/downloads.html "Set of tools to create, alter and inspect Matroska files under Linux, other Unices and Windows.")
- [ttconv - Timed Text Conversion] (https://pypi.org/project/ttconv/ "Library for conversion of common timed text formats.")
You could filter for required details in F12 (Chrome will keep the filters saved even after restart)
/license|subti|token/
Subtitles are not part of the manifest so, if also need they are to be downloaded manually.
curl -kL -o sub.vtt "https://ctfs.ceskatelevize.cz/subtitles1746037296/44/faf1/44faf192-0042-4ae0-a523-6107036fe61b.vtt"
tt convert -i sub.vtt -o sub.srt
ttconv convert -i sub.vtt -o sub.srt
N_m3u8DL-RE \
"https://ivys-nw-cdn.o2tv.cz/cdn/uri/get/?token=ab99.....88ef&userId=ab99......88ef&content Id=61924494878444648&streamType=dash&quality=1080p &contentType=vod®ion=1&expiry=1766....&drmOnly= true&qualityCount=5&encryption=wv" \
-H "Accept: */*" -H "Origin: https://player.ceskatelevize.cz" -H "Referer: https://player.ceskatelevize.cz/" -H "Sec-GPC: 1" -H "User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 15.6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/144.0.7219.88 Safari/537.36" \
--key 00000000000000000000000000000000:ca28326f27a6e9756 85e7bcf0d760d0c \
--decryption-engine SHAKA_PACKAGER --no-log -mt -M format=mkv:muxer=mkvmerge -sv=best -sa=all -ss=all \
--mux-import path=sub.vtt:lang=ces:name="Čeština VTT" \
--mux-import path=sub.srt:lang=ces:name="Čeština SRT" \
--save-name Pupendo.2003.1080p.iVysilani.Web-DL.AAC2.0.H.264
Need help downloading
By Angel_Cyclops in forum Video Streaming DownloadingReplies: 36Last Post: 19th Feb 2025, 06:00 -
Downloading an HLS stream: ONLY in sync when downloading with ffmpeg. Possi
By royjeon215 in forum Video Streaming DownloadingReplies: 6Last Post: 21st Jan 2024, 02:56 -
Help for downloading
By talms in forum Video Streaming DownloadingReplies: 8Last Post: 27th Jan 2023, 06:04 -
Help me downloading this :(
By Elias22 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Jan 2023, 11:59 -
Need Help Downloading this
By daigo99 in forum Video Streaming DownloadingReplies: 16Last Post: 20th Jul 2021, 18:58
