I can't understand why N_m3u8DL-RE can't load N_m3u8DL-RE "https://tvseans.az/az/hls/2377/0/index.m3u8?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1N iJ9.eyJleHAiOjE3NjcwMjA0ODF9.PH0zxgU7IlrB2_S0723gW o6LVb_97wCsneZ9Z0jpnys" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36" --header "Cookie: _ga=GA1.1.2015003564.1766828401; _identity-frontend=471ab06b5a50cc59b994cced6b2506ca7ed716890 0e0e7c6fbbbba3df04a5b1fa%3A2%3A%7Bi%3A0%3Bs%3A18%3 A%22_identity-frontend%22%3Bi%3A1%3Bs%3A51%3A%22%5B346270%2C%22G pMhAmBJ8yBtTv93CLvGvYjkuICQ6Yti%22%2C2592000%5D%22 %3B%7D; _csrf-frontend=e5a0b74028c19589821a7c5769a8582d00b0e9f3b cca534c1e8251f9ddee491fa%3A2%3A%7Bi%3A0%3Bs%3A14%3 A%22_csrf-frontend%22%3Bi%3A1%3Bs%3A32%3A%22-jXkGl9-KuJ6G79MaiQmTN3HwdrPNXG_%22%3B%7D; _language=7f5cf297ed446f10eaeccd0de093e834ca0126d7 c47aae8b7f519cb387caefa3a%3A2%3A%7Bi%3A0%3Bs%3A9%3 A%22_language%22%3Bi%3A1%3Bs%3A2%3A%22az%22%3B%7D; advanced-frontend=4aeccdce7a1a475e3b721b1796d7346c; _ga_8D4GYGMNST=GS2.1.s1767020354$o7$g1$t1767020357 $j57$l0$h0" --header "Referer: https://tvseans.az/az/film/2377/atilmis/watch?player=1" --save-name "Abandon 2002" -M format=mkv
the content even though it's a recording and not a live broadcast, and this is the error Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index')
Results 1 to 30 of 31
To make it simpler:
Code:N_m3u8DL-RE "https://tvseans.az/az/hls/2377/0/index.m3u8?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1N iJ9.eyJleHAiOjE3NjcwMjA0ODF9.PH0zxgU7IlrB2_S0723gW o6LVb_97wCsneZ9Z0jpnys" --save-name "Abandon 2002" -M format=mkv
[Attachment 90503 - Click to enlarge] -
The problem stems from the m3u8 file; the video duration has a token time limit, resulting in a 00m00s format.
[Attachment 90504 - Click to enlarge] -
#EXTM3U
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="aac",NAME="Azərbaycanca", DEFAULT=YES,AUTOSELECT=YES,LANGUAGE="az", URI="https://cdn01.koroqlu.com/media/films/2019/11/191119-Abandon_Atilmish_az_en_ru_720p-2003/main/audio/az/index.m3u8"
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="aac",NAME="Русский", DEFAULT=NO,AUTOSELECT=YES,LANGUAGE="ru", URI="https://cdn01.koroqlu.com/media/films/2019/11/191119-Abandon_Atilmish_az_en_ru_720p-2003/main/audio/ru/index.m3u8"
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="aac",NAME="English", DEFAULT=NO,AUTOSELECT=YES,LANGUAGE="en", URI="https://cdn01.koroqlu.com/media/films/2019/11/191119-Abandon_Atilmish_az_en_ru_720p-2003/main/audio/en/index.m3u8"
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1989000,RESOLUTION=1280x720,CODECS= "avc1.66.30,mp4a.40.2",AUDIO="aac"
https://cdn01.koroqlu.com/media/films/2019/11/191119-Abandon_Atilmish_az_en_ru_720p-20...20p/index.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=889000,RESOLUTION=640x360,CODECS="a vc1.66.30,mp4a.40.2",AUDIO="aac"
https://cdn01.koroqlu.com/media/films/2019/11/191119-Abandon_Atilmish_az_en_ru_720p-20...60p/index.m3u8
- I only need the video and all three audio tracks. -
Have you tried using Stream Detector to download the video : https://www.videohelp.com/software/The-Stream-Detector
In copy stream url copy: select N_M3U8DL-RE -
This data - N_m3u8DL-RE "https://tvseans.az/az/hls/2377/0/index.m3u8?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1N iJ9.eyJleHAiOjE3NjcwMjA0ODF9.PH0zxgU7IlrB2_S0723gW o6LVb_97wCsneZ9Z0jpnys" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36" --header "Cookie: _ga=GA1.1.2015003564.1766828401; _identity-frontend=471ab06b5a50cc59b994cced6b2506ca7ed716890 0e0e7c6fbbbba3df04a5b1fa%3A2%3A%7Bi%3A0%3Bs%3A18%3 A%22_identity-frontend%22%3Bi%3A1%3Bs%3A51%3A%22%5B346270%2C%22G pMhAmBJ8yBtTv93CLvGvYjkuICQ6Yti%22%2C2592000%5D%22 %3B%7D; _csrf-frontend=e5a0b74028c19589821a7c5769a8582d00b0e9f3b cca534c1e8251f9ddee491fa%3A2%3A%7Bi%3A0%3Bs%3A14%3 A%22_csrf-frontend%22%3Bi%3A1%3Bs%3A32%3A%22-jXkGl9-KuJ6G79MaiQmTN3HwdrPNXG_%22%3B%7D; _language=7f5cf297ed446f10eaeccd0de093e834ca0126d7 c47aae8b7f519cb387caefa3a%3A2%3A%7Bi%3A0%3Bs%3A9%3 A%22_language%22%3Bi%3A1%3Bs%3A2%3A%22az%22%3B%7D; advanced-frontend=4aeccdce7a1a475e3b721b1796d7346c; _ga_8D4GYGMNST=GS2.1.s1767020354$o7$g1$t1767020357 $j57$l0$h0" --header "Referer: https://tvseans.az/az/film/2377/atilmis/watch?player=1" --save-name "Abandon 2002" -M format=mkv is from that program Stream Detector
https://tvseans.az/az/film/2377/atilmis/watch?player=1 -
Token with 2 minute expiry
https://tvseans.az/az/ajax/getcr
proxy.py
Code:import requests import time import re from flask import Flask, Response, request app = Flask(__name__) # CONFIGURATION # The Master URL without the token MASTER_INDEX = "https://tvseans.az/az/hls/2377/0/index.m3u8" TOKEN_API = "https://tvseans.az/az/ajax/getcr" HEADERS = {"Referer": "https://tvseans.az/", "User-Agent": "Mozilla/5.0"} cache = {"token": None, "expiry": 0} def get_token(): if cache["token"] and (time.time() - cache["expiry"] < 80): return cache["token"] try: r = requests.get(TOKEN_API, headers=HEADERS, timeout=5).json() cache["token"], cache["expiry"] = r['t'], time.time() print(f"[*] New Token Acquired: {cache['token'][:20]}...") return cache["token"] except: return cache["token"] @app.route('/index.m3u8') def master_index(): # Fetch the real master playlist token = get_token() resp = requests.get(f"{MASTER_INDEX}?token={token}", headers=HEADERS).text # Rewrite all URLs in the master playlist to go through this proxy # This catches both the Video index and the Audio index URLs rewritten = re.sub(r'(https?://[^\s]+)', r'http://127.0.0.1:5000/proxy?url=\1', resp) return Response(rewritten, mimetype='application/vnd.apple.mpegurl') @app.route('/proxy') def proxy_playlist_or_segment(): original_url = request.args.get('url') token = get_token() # Check if we are requesting a playlist (.m3u8) or a data segment (.ts) if ".m3u8" in original_url: resp = requests.get(f"{original_url}?token={token}", headers=HEADERS).text # Rewrite segments inside sub-playlists to point back here base_url = original_url.rsplit('/', 1)[0] + '/' lines = [] for line in resp.splitlines(): if line.endswith(".ts") and not line.startswith("http"): lines.append(f"http://127.0.0.1:5000/proxy?url={base_url}{line}") elif line.startswith("http"): lines.append(f"http://127.0.0.1:5000/proxy?url={line}") else: lines.append(line) return Response("\n".join(lines), mimetype='application/vnd.apple.mpegurl') else: # It's a .ts segment; stream the binary data req = requests.get(f"{original_url}?token={token}", headers=HEADERS, stream=True) return Response(req.iter_content(chunk_size=1024*64), content_type=req.headers.get('Content-Type')) if __name__ == '__main__': print("--- MASTER PROXY RUNNING ---") print("Point N_m3u8DL-RE to: http://127.0.0.1:5000/index.m3u8") app.run(port=5000, threaded=True)Code:N_m3u8DL-RE "http://127.0.0.1:5000/index.m3u8" --save-name "Abandon_2003" --thread-count 100 -M format=mkv
proxy.ps1
Code:$MasterUrl = "https://tvseans.az/az/hls/2377/0/index.m3u8" $TokenApi = "https://tvseans.az/az/ajax/getcr" $Port = 5000 $Listener = New-Object System.Net.HttpListener $Listener.Prefixes.Add("http://127.0.0.1:$Port/") $Listener.Start() $Cache = @{ Token = $null; Expiry = 0 } function Get-FreshToken { $now = [DateTimeOffset]::Now.ToUnixTimeSeconds() if ($Cache.Token -and ($now - $Cache.Expiry -lt 80)) { return $Cache.Token } try { $resp = Invoke-RestMethod -Uri $TokenApi -Headers @{"Referer"="https://tvseans.az/"} $Cache.Token = $resp.t $Cache.Expiry = $now Write-Host "[*] New Token Acquired" -ForegroundColor Cyan return $Cache.Token } catch { return $Cache.Token } } Write-Host "--- PowerShell Master Proxy Active ---" -ForegroundColor Green Write-Host "Listening on http://127.0.0.1:$Port/index.m3u8" Write-Host "Press Ctrl+C to stop.`n" try { while ($Listener.IsListening) { $Context = $Listener.GetContext() $Request = $Context.Request $Response = $Context.Response $LocalPath = $Request.Url.LocalPath $QueryUrl = $Request.QueryString["url"] if ($LocalPath -eq "/index.m3u8") { # 1. Handle Master Playlist $token = Get-FreshToken $content = Invoke-RestMethod -Uri "$MasterUrl?token=$token" -Headers @{"Referer"="https://tvseans.az/"} # Rewrite all absolute URLs to go through our proxy $rewritten = $content -replace '(https?://[^\s\r\n]+)', "http://127.0.0.1:$Port/proxy?url=`$1" $buffer = [System.Text.Encoding]::UTF8.GetBytes($rewritten) $Response.ContentType = "application/vnd.apple.mpegurl" $Response.OutputStream.Write($buffer, 0, $buffer.Length) } elseif ($LocalPath -eq "/proxy" -and $QueryUrl) { $token = Get-FreshToken if ($QueryUrl -like "*.m3u8*") { # 2. Handle Sub-Playlists (Video/Audio) $content = Invoke-RestMethod -Uri "$QueryUrl?token=$token" -Headers @{"Referer"="https://tvseans.az/"} $baseUrl = $QueryUrl.Substring(0, $QueryUrl.LastIndexOf('/') + 1) # Rewrite relative .ts paths to absolute proxy paths $lines = $content -split "`r?`n" $newLines = foreach ($line in $lines) { if ($line -like "*.ts*" -and $line -notlike "http*") { "http://127.0.0.1:$Port/proxy?url=$baseUrl$line" } elseif ($line -like "http*") { "http://127.0.0.1:$Port/proxy?url=$line" } else { $line } } $buffer = [System.Text.Encoding]::UTF8.GetBytes(($newLines -join "`n")) $Response.ContentType = "application/vnd.apple.mpegurl" $Response.OutputStream.Write($buffer, 0, $buffer.Length) } else { # 3. Handle Binary Segments (.ts) try { $data = Invoke-WebRequest -Uri "$QueryUrl?token=$token" -Headers @{"Referer"="https://tvseans.az/"} -UseBasicParsing $Response.ContentType = "video/MP2T" $Response.OutputStream.Write($data.Content, 0, $data.Content.Length) } catch { $Response.StatusCode = 404 } } } $Response.Close() } } finally { $Listener.Stop() } -
Listening on http://127.0.0.1:5000/index.m3u8
Press Ctrl+C to stop.[*] New Token Acquired
ERROR: Invoke-RestMethod : Invalid URI: The hostname could not be parsed.
proxy.ps1 (39, 24): ERROR: At Line: 39 char: 24
ERROR: + ... $content = Invoke-RestMethod -Uri "$MasterUrl?token=$token" -Headers ...
ERROR: + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~
ERROR: + CategoryInfo : NotSpecified: (
[Invoke-RestMethod], UriFormatException
ERROR: + FullyQualifiedErrorId : System.UriFormatException,Microsoft.PowerShell.Com mands.InvokeRestMethodCommand
ERROR: -
Fix
Code:$ErrorActionPreference = "Stop" # 1. Clean Configuration $RawMaster = "https://tvseans.az/az/hls/2377/0/index.m3u8" $MasterString = [regex]::Replace($RawMaster, "[^a-zA-Z0-9\/\.\:\-]", "").Trim() $TokenApi = "https://tvseans.az/az/ajax/getcr" # --- REQUIRED HEADERS --- # Note: If you still get 401 errors, paste your browser Cookie below. $GlobalHeaders = @{ "Referer" = "https://tvseans.az/" "User-Agent" = "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" # "Cookie" = "PHPSESSID=your_session_id_here" } $Port = 5000 $Listener = New-Object System.Net.HttpListener $Listener.Prefixes.Add("http://127.0.0.1:$Port/") $Listener.Start() $Cache = @{ Token = $null; Expiry = 0 } function Get-FreshToken { $now = [DateTimeOffset]::Now.ToUnixTimeSeconds() if ($Cache.Token -and ($now - $Cache.Expiry -lt 80)) { return $Cache.Token } try { $resp = Invoke-RestMethod -Uri $TokenApi -Headers $GlobalHeaders -Method Get # Fixed Regex: Removed the invalid backslash before the underscore $Cache.Token = [regex]::Replace($resp.t, "[^a-zA-Z0-9\.\-_]", "").Trim() $Cache.Expiry = $now Write-Host "[*] Token Refreshed" -ForegroundColor Cyan return $Cache.Token } catch { Write-Host "[!] Token API Error: $($_.Exception.Message)" -ForegroundColor Red return $Cache.Token } } Write-Host "--- Master Proxy Active ---" -ForegroundColor Green Write-Host "Local URL: http://127.0.0.1:$Port/index.m3u8" try { while ($Listener.IsListening) { $Context = $Listener.GetContext() $Request = $Context.Request $Response = $Context.Response if ($Request.Url.LocalPath -eq "/index.m3u8") { $token = Get-FreshToken $ub = New-Object System.UriBuilder($MasterString) $ub.Query = "token=$token" $content = Invoke-RestMethod -Uri $ub.Uri -Headers $GlobalHeaders $rewritten = $content -replace '(https?://[^\s\r\n]+)', "http://127.0.0.1:$Port/proxy?url=`$1" $buffer = [System.Text.Encoding]::UTF8.GetBytes($rewritten) $Response.ContentType = "application/vnd.apple.mpegurl" $Response.OutputStream.Write($buffer, 0, $buffer.Length) } elseif ($Request.Url.LocalPath -eq "/proxy") { $targetBase = $Request.QueryString["url"] $token = Get-FreshToken $ub = New-Object System.UriBuilder($targetBase) $existingQuery = $ub.Query.Replace("?", "") $ub.Query = if ($existingQuery) { "$existingQuery&token=$token" } else { "token=$token" } if ($targetBase -like "*.m3u8*") { $content = Invoke-RestMethod -Uri $ub.Uri -Headers $GlobalHeaders $baseUrl = $targetBase.Substring(0, $targetBase.LastIndexOf('/') + 1) $lines = $content -split "`r?`n" $newLines = foreach ($line in $lines) { if ($line -like "*.ts*" -and $line -notlike "http*") { "http://127.0.0.1:$Port/proxy?url=$($baseUrl)$($line)" } elseif ($line -like "http*") { "http://127.0.0.1:$Port/proxy?url=$($line)" } else { $line } } $buffer = [System.Text.Encoding]::UTF8.GetBytes(($newLines -join "`n")) $Response.ContentType = "application/vnd.apple.mpegurl" $Response.OutputStream.Write($buffer, 0, $buffer.Length) } else { # --- FAST BINARY DOWNLOAD --- # Using a WebClient for better binary performance than Invoke-WebRequest try { $wc = New-Object System.Net.WebClient foreach ($key in $GlobalHeaders.Keys) { $wc.Headers.Add($key, $GlobalHeaders[$key]) } $data = $wc.DownloadData($ub.Uri) $Response.OutputStream.Write($data, 0, $data.Length) } catch { $Response.StatusCode = 500 } } } $Response.Close() } } finally { $Listener.Stop() } -
what about this?: https://www.tiktok.com/@aerofitsa/video/7558248540250705159
You can download TikTok videos using IDM : https://www.internetdownloadmanager.com/
yt-dlp --referer https://www.tiktok.com/ --add-header "Cookie: ttwid=1%7CuM0rklYgjxZTNxWsF17zesEEGfra2MjSNH3_6D4f rIk%7C1767171164%7C953d80f41bbd8a8f9b2d59fe84114b7 e66cb55daa6fe763bcd7e9cff56d89b0c; tt_csrf_token=D8scpWak-MoLx3w9xRnzoDDdEBHYZd9vcbfs; tt_chain_token=mGFC2/1z0ezmcXQFFjX41g==; msToken=HA-KbSvglAfeZduOsiENxGqzLVF75YCRZmNERMLp9dYKPhnjKuhDc e5ZIwbhHj0QvJr9DitqgyZGYAlMfvHLqH6pP-x3EFK8KrvU7O4NDVsAI1Ii29rwXfH9OZ8Bezgi_dZO2MsTsA== " "https://v16-webapp-prime.tiktok.com/video/tos/useast2a/tos-useast2a-ve-0068c002/ow9gIGlEREiAwJmP9rIQtBBnk0uiiBZtBQnevf/?a=1988&bti=ODszNWYuMDE6&ch=0&cr=3&dr=0&lr=all&cd= 0%7C0%7C0%7C&cv=1&br=2488&bt=1244&cs=0&ds=2&ft=I~d a4os3D12Nviq9Z.IxROyNJlBF-UjNS1opiX&mime_type=video_mp4&qs=0&rc=NGg3ZTM7aGZm OzM4Zzc3OUBpMzs5ZXc5cnN1eTMzNzczM0BhLV42NC5fXzAxLz AyYzI0YSNrLTVlMmQ0cHJgLS1kMTZzcw%3D%3D&btag=e00088 000&expire=1767344271&l=20251231165707C3FC5556DF96 B062A391&ply_type=2&policy=2&signature=b7a75947944 c9529577d799f343ac7dd&tk=tt_chain_token"
Deprecated Feature: Passing cookies as a header is a potential security risk; they will be scoped to the domain of the downloaded urls. Please consider loading cookies from a file or browser instead.
[generic] Extracting URL: https://v16-webapp-prime.tiktok.com/video/tos/useast2a/tos-useast2a-ve-0068c002/ow9gIG...tt_chain_token
[generic] ?a=1988&bti=ODszNWYuMDE6&ch=0&cr=3&dr=0&lr=all&cd= 0|0|0|&cv=1&br=2488&bt=1244&cs=0&ds=2&ft=I~da4os3D 12Nviq9Z: Downloading webpage
[info] ?a=1988&bti=ODszNWYuMDE6&ch=0&cr=3&dr=0&lr=all&cd= 0|0|0|&cv=1&br=2488&bt=1244&cs=0&ds=2&ft=I~da4os3D 12Nviq9Z: Downloading 1 format(s): mp4
[download] Destination: ow9gIGlEREiAwJmP9rIQtBBnk0uiiBZtBQnevf [?a=1988&bti=ODszNWYuMDE6&ch=0&cr=3&dr=0&lr=all&cd= 0|0|0|&cv=1&br=2488&bt=1244&cs=0&ds=2&ft=I~da4os3D 12Nviq9Z].mp4
[download] 100% of 6.57MiB in 00:00:03 at 1.66MiB/s -
I want to download from
using the program yt-dlp.exeCode:https://www.youtube.com/watch?v=d9eFHjTSR6Y
[Attachment 90555 - Click to enlarge]
position under code 96 (27.84Gib 5574k) but it does not load, instead a video under code 137 (11.38Gib 2278k) loads, and so on with all videos on this service. Question, why? -
Frieren.
Happy New Year!
nadya86.
yt-dlp -f 96 https://www.youtube.com/watch?v=d9eFHjTSR6Y
[youtube] Extracting URL: https://www.youtube.com/watch?v=d9eFHjTSR6Y
[youtube] d9eFHjTSR6Y: Downloading webpage
WARNING: [youtube] No supported JavaScript runtime could be found. Only deno is enabled by default; to use another runtime add --js-runtimes RUNTIME[:PATH] to your command/config. YouTube extraction without a JS runtime has been deprecated, and some formats may be missing. See https://github.com/yt-dlp/yt-dlp/wiki/EJS for details on installing one
[youtube] d9eFHjTSR6Y: Downloading android sdkless player API JSON
[youtube] d9eFHjTSR6Y: Downloading web safari player API JSON
WARNING: [youtube] d9eFHjTSR6Y: Some web_safari client https formats have been skipped as they are missing a url. YouTube is forcing SABR streaming for this client. See https://github.com/yt-dlp/yt-dlp/issues/12482 for more details
[youtube] d9eFHjTSR6Y: Downloading m3u8 information
WARNING: [youtube] d9eFHjTSR6Y: Some web client https formats have been skipped as they are missing a url. YouTube is forcing SABR streaming for this client. See https://github.com/yt-dlp/yt-dlp/issues/12482 for more details
[info] d9eFHjTSR6Y: Downloading 1 format(s): 96
[download] Sleeping 5.00 seconds as required by the site...
[hlsnative] Downloading m3u8 manifest
[hlsnative] Total fragments: 8581
[download] Destination: Magic's Biggest Secrets Revealed [d9eFHjTSR6Y].mp4
[download] 0.2% of ~ 15.62GiB at 1.00MiB/s ETA 06:25:27 (frag 15/8581)
General
Unique ID : 326500602048786899183171211230101573230 (0xF5A1BA87CC6FDEB304332FC4AE1F0E6E)
Complete name : E:\Magic's Biggest Secrets Revealed.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 12.0 GiB
Duration : 11 h 54 min
Overall bit rate : 2 409 kb/s
Movie name : Magic's Biggest Secrets Revealed
Description : World's Scariest Magic Tricks - http://bit.ly/24REkEJ / Unbelievable Psychic Magic - http://bit.ly/1UVM4jy / Mind-blowing Illusions - http://bit.ly/23cpZn7 / Tricky Slight of Hand - http://bit.ly/1UzYCgx / Death Defying Tricks - http://bit.ly/1UwlhOW / Amazing Escapes - http://bit.ly/24REU5r / Classic Magic Illusions - http://bit.ly/1txa4nB / Stupefying Vanishing Acts - http://bit.ly/1YsN98v / / Come to our channel every Thursday to see more magic tricks and how they are performed! / / Breaking the Magician's Code: Magic's Biggest Secrets Finally Revealed is a series of television shows produced by Nash Entertainment in which the closely guarded secrets behind classic magic tricks and illusions are exposed by the Masked Magician, aided by his beautiful assistants. / / The enormously popular TV specials and series featured the incognito magician performing large-scale illusions and a few smaller-scale close-up magic tricks... then revealing the secrets of how the tricks were done.
Writing application : Lavf60.16.100
Writing library : Lavf60.16.100
Comment : https://www.youtube.com/watch?v=d9eFHjTSR6Y
ErrorDetectionType : Per level 1
ARTIST : Magic Secrets Revealed
DATE : 20250308
GENRE : Entertainment
PURL : https://www.youtube.com/watch?v=d9eFHjTSR6Y
SYNOPSIS : World's Scariest Magic Tricks - http://bit.ly/24REkEJ / Unbelievable Psychic Magic - http://bit.ly/1UVM4jy / Mind-blowing Illusions - http://bit.ly/23cpZn7 / Tricky Slight of Hand - http://bit.ly/1UzYCgx / Death Defying Tricks - http://bit.ly/1UwlhOW / Amazing Escapes - http://bit.ly/24REU5r / Classic Magic Illusions - http://bit.ly/1txa4nB / Stupefying Vanishing Acts - http://bit.ly/1YsN98v / / Come to our channel every Thursday to see more magic tricks and how they are performed! / / Breaking the Magician's Code: Magic's Biggest Secrets Finally Revealed is a series of television shows produced by Nash Entertainment in which the closely guarded secrets behind classic magic tricks and illusions are exposed by the Masked Magician, aided by his beautiful assistants. / / The enormously popular TV specials and series featured the incognito magician performing large-scale illusions and a few smaller-scale close-up magic tricks... then revealing the secrets of how the tricks were done.
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
DURATION : 11:54:58.166000000
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -33 ms
Language : English
Default : No
Forced : No
DURATION : 11:54:58.193000000 -
download hls streaming (from dood)
By whs912km in forum Video Streaming DownloadingReplies: 4Last Post: 21st Nov 2022, 10:14 -
Download hls error with streamlink
By turexx in forum Video Streaming DownloadingReplies: 1Last Post: 20th Nov 2022, 15:43 -
Download HLS. error 400 to download keys
By naturalc in forum Video Streaming DownloadingReplies: 28Last Post: 28th Oct 2022, 08:13 -
Download HLS video
By Avish in forum Video Streaming DownloadingReplies: 4Last Post: 6th Aug 2022, 12:46
impressive
