anyone can capture this?
https://www.bbc.co.uk/programmes/m002p1d6
Results 1 to 11 of 11
it not release air or already been on air yet
gmt 3.45pm
you have to wait after it finish -
amazing stew, I tried using N_m3u8DL-RE with this mpd
but the max res I got was 1280x720, just wonder how did you get the 1080p, if you can share that info I would be grateful because I wanna get the Mo Salah video and max I got was 720p.. any help would be great and thanks stew for helping othersCode:https://pub-c3-b5-thdow-bbc.live.bidi.net.uk/vod-dash-uk/usp/auth/vod/piff_abr_full_hd/ce2475-m002p1d5/vf_m002p1d5_606b52b7-9550-4b4f-b718-046477187759.ism/pc_hd_abr_v2_dash_master.mpd?at=AOhO420Zbbd9f2203d26a35da8d8a70ff375d02bb2d375c0647182d983180
Thanks man, get_iplayer did the job perfectly.
wonder if this modified version of yt-dlp is publicly available or its ur own
its really a wonder to see other devs tweaks and workarounds and try to understand the logic behind their thinking
will keep learning and improving.. thanks stew for the great help
it's just a small "hack", modification of yt-dlp's bbc extractor that i found in the old youtube-dl's discussions on github. it basically hardcodes some things, which means it'll fail if 1080p is not available. some older videos are only available in 540p and some web-only streams are in 720p. when you add this to yt-dlp and compile a new version, you can't update it as normal, so you have to keep two versions and only use this for bbc (until there's new features in core yt-dlp you want to use, or some bbc extractor updates)
since get_iplayer works, and fetches more metadata than yt-dlp, it's the better choice in most situations. -
BBC iPlayer help
By Lupine Assassin in forum Video Streaming DownloadingReplies: 22Last Post: 16th Jan 2026, 13:46 -
Getting BBC Iplayer mpds
By BerlinGen in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Jan 2025, 11:23 -
BBC iPlayer problem.
By bex147 in forum Newbie / General discussionsReplies: 15Last Post: 15th Mar 2024, 05:13 -
BBC iPlayer
By Ivan in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Feb 2024, 08:02 -
BBC iPlayer help needed
By Ebi in forum Video Streaming DownloadingReplies: 6Last Post: 19th Feb 2024, 17:33
