I installed the fork of Node.js for Windows 7 & the latest yt-dlp for Windows 7.
I used the YouTube that Bencuri posted:
https://www.youtube.com/watch?v=ZfObjX-E_g4
I like to use --list-formats & select the one I want.
For this one I started with the m3u8 that was largest & looked like the "best" choice.
As nicolaasjan posted it was smaller that the size it listed.
The m3u8 showed the total size as: 1.10GiB
Media info showed the Video size as: 765 MiB
The Audio size as:40.5 MiB
These sizes are comparable to Audio 140-1 & Video 137 in the --list-formats.
The only better Audio is OPUS at 43.24MiB if you wanted to use OPUS.
This is only a slightly larger Audio file.
You can use these codes directly with yt-dlp in command .
This is the m3u8:This is the best non OPUS:Code:yt-dlp -f 96-1 https://www.youtube.com/watch?v=ZfObjX-E_g4
Using OPUS:Code:yt-dlp -f 137+140-0 https://www.youtube.com/watch?v=ZfObjX-E_g4
Using the code I use that is the same as Bencuri's:Code:yt-dlp -f 137+250-1 https://www.youtube.com/watch?v=ZfObjX-E_g4
yt-dlp chooses the 399 video code instead of the 137 video code as "bestvideo".Code:yt-dlp -f bestvideo[ext=mp4]+bestaudio[ext=m4a]/best[ext=mp4] https://www.youtube.com/watch?v=ZfObjX-E_g4
399 is 405.95MiB
137 is 765.37MiB
It chooses the Spanish 140-1 as bestaudio. Which is fine if that is what is wanted.
The file is named: Celia: 1x03 - ĦEl verano! | RTVE Archivo [ZfObjX-E_g4].mp4
Results 31 to 39 of 39
@cholla
As I said, with node you shouldn't see these m3u8 formats:
Code:[debug] Command-line config: ['-vF', 'https://www.youtube.com/watch?v=ZfObjX-E_g4'] [debug] User config "C:\Users\User\AppData\Roaming\yt-dlp\config.txt": ['--rm-cache-dir', '--console-title', '--js-runtimes', 'node', '-o', '~/Desktop/%(title)s.%(ext)s', '-S', 'res:1080,vcodec:vp9,acodec:opus', '--embed-thumbnail', '--add-metadata', '--convert-thumbnails', 'jpg', '--ppa', 'ffmpeg:-metadata synopsis=""', '--force-ipv4', '-N', '6', '--sponsorblock-remove', 'all'] [debug] Encodings: locale cp1252, fs utf-8, pref cp1252, out cp1252 (No VT), error cp1252 (No VT), screen cp1252 (No VT) [debug] yt-dlp version nicolaasjan/yt-dlp@2025.12.21.064937 (win_exe) [debug] Python 3.14.2 (CPython AMD64 64bit) - Windows-7-6.1.7601-SP1 (OpenSSL 3.0.18 30 Sep 2025) [debug] exe versions: ffmpeg N-122272-g224b3ff82a-WIN7 (fdk,setts), ffprobe N-122272-g224b3ff82a-WIN7, phantomjs 2.5.0 [debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2025.11.12, curl_cffi-0.13.0, mutagen-1.47.0, requests-2.32.5, sqlite3-3.50.4, urllib3-2.6.2, websockets-15.0.1, yt_dlp_ejs-0.3.2 [debug] JS runtimes: node-20.19.2 [debug] Proxy map: {} [debug] Request Handlers: urllib, requests, websockets, curl_cffi [debug] Plugin directories: none [debug] Loaded 1853 extractors Removing cache dir C:\Users\User/.cache\yt-dlp .. [debug] [youtube] [pot] PO Token Providers: none [debug] [youtube] [pot] PO Token Cache Providers: memory [debug] [youtube] [pot] PO Token Cache Spec Providers: webpo [debug] [youtube] [jsc] JS Challenge Providers: bun (unavailable), deno (unavailable), node, quickjs (unavailable) [youtube] Extracting URL: https://www.youtube.com/watch?v=ZfObjX-E_g4 [youtube] ZfObjX-E_g4: Downloading webpage [youtube] ZfObjX-E_g4: Downloading tv client config [debug] [youtube] Forcing "main" player JS variant for player 50cc0679 original url = /s/player/50cc0679/player_es6.vflset/en_US/base.js [youtube] ZfObjX-E_g4: Downloading player 50cc0679-main [youtube] ZfObjX-E_g4: Downloading tv player API JSON [debug] [youtube] ZfObjX-E_g4: Detected a 6s ad skippable after 5s for tv [youtube] ZfObjX-E_g4: Downloading android sdkless player API JSON [youtube] [jsc:node] Solving JS challenges using node [debug] [youtube] [jsc:node] Using challenge solver lib script v0.3.2 (source: python package, variant: minified) [debug] [youtube] [jsc:node] Using challenge solver core script v0.3.2 (source: python package, variant: minified) [debug] [youtube] [jsc:node] Running node: 'C:\Program Files\mpv\node.EXE' --experimental-permission --no-warnings=ExperimentalWarning - [debug] Sort order given by user: res:1080, vcodec:vp9, acodec:opus [debug] Sort order given by extractor: quality, res, fps, hdr:12, source, vcodec, channels, acodec, lang, proto [debug] Formats sorted by: hasvid, ie_pref, res:1080(1080.0), vcodec:vp9(9), acodec:opus(12), quality, fps, hdr:12(7), source, channels, lang, proto, size, br, asr, vext, aext, hasaud, id [SponsorBlock] Fetching SponsorBlock segments [debug] SponsorBlock query: https://sponsor.ajay.app/api/skipSegments/fa9c?service=YouTube&categories=%5B%22filler%22%2C+%22intro%22%2C+%22music_offtopic%22%2C+%22preview%22%2C+%22hook%22%2C+%22outro%22%2C+%22interaction%22%2C+%22selfpromo%22%2C+%22sponsor%22%5D&actionTypes=%5B%22skip%22%2C+%22poi%22%2C+%22chapter%22%5D [SponsorBlock] No matching segments were found in the SponsorBlock database [info] Available formats for ZfObjX-E_g4: ID EXT RESOLUTION FPS CH | FILESIZE TBR PROTO | VCODEC VBR ACODEC ABR ASR MORE INFO ------------------------------------------------------------------------------------------------------------------------------------------------------------ sb3 mhtml 48x27 0 | mhtml | images storyboard sb2 mhtml 60x45 0 | mhtml | images storyboard sb1 mhtml 120x90 0 | mhtml | images storyboard sb0 mhtml 240x180 0 | mhtml | images storyboard 139-drc m4a audio only 2 | 15.44MiB 49k https | audio only mp4a.40.5 49k 22k [es-US] Spanish (US) original, low, DRC, ANDR-S, m4a_dash 139-0 m4a audio only 2 | 15.44MiB 49k https | audio only mp4a.40.5 49k 22k [en-US] English (US) (default), low, ANDR-S, m4a_dash 139-1 m4a audio only 2 | 15.44MiB 49k https | audio only mp4a.40.5 49k 22k [es-US] Spanish (US) original, low, ANDR-S, m4a_dash 140-drc m4a audio only 2 | 40.96MiB 129k https | audio only mp4a.40.2 129k 44k [es-US] Spanish (US) original, medium, DRC, TV, m4a_dash 140-0 m4a audio only 2 | 40.96MiB 129k https | audio only mp4a.40.2 129k 44k [en-US] English (US) (default), medium, TV, m4a_dash 140-1 m4a audio only 2 | 40.96MiB 129k https | audio only mp4a.40.2 129k 44k [es-US] Spanish (US) original, medium, TV, m4a_dash 249-drc webm audio only 2 | 15.83MiB 50k https | audio only opus 50k 48k [es-US] Spanish (US) original, low, DRC, TV, webm_dash 250-drc webm audio only 2 | 18.41MiB 58k https | audio only opus 58k 48k [es-US] Spanish (US) original, low, DRC, TV, webm_dash 249-0 webm audio only 2 | 17.70MiB 56k https | audio only opus 56k 48k [en-US] English (US) (default), low, TV, webm_dash 250-0 webm audio only 2 | 22.78MiB 72k https | audio only opus 72k 48k [en-US] English (US) (default), low, TV, webm_dash 249-1 webm audio only 2 | 15.63MiB 49k https | audio only opus 49k 48k [es-US] Spanish (US) original, low, TV, webm_dash 250-1 webm audio only 2 | 18.32MiB 58k https | audio only opus 58k 48k [es-US] Spanish (US) original, low, TV, webm_dash 251-drc webm audio only 2 | 32.67MiB 103k https | audio only opus 103k 48k [es-US] Spanish (US) original, medium, DRC, TV, webm_dash 251-0 webm audio only 2 | 43.24MiB 137k https | audio only opus 137k 48k [en-US] English (US) (default), medium, TV, webm_dash 251-1 webm audio only 2 | 32.44MiB 103k https | audio only opus 103k 48k [es-US] Spanish (US) original, medium, TV, webm_dash 394 mp4 192x144 25 | 21.88MiB 69k https | av01.0.00M.08 69k video only 144p, TV, mp4_dash 160 mp4 192x144 25 | 19.48MiB 62k https | avc1.4d400b 62k video only 144p, TV, mp4_dash 278 webm 192x144 25 | 24.32MiB 77k https | vp9 77k video only 144p, TV, webm_dash 395 mp4 320x240 25 | 43.18MiB 136k https | av01.0.00M.08 136k video only 240p, TV, mp4_dash 133 mp4 320x240 25 | 41.22MiB 130k https | avc1.4d400d 130k video only 240p, TV, mp4_dash 242 webm 320x240 25 | 37.18MiB 118k https | vp9 118k video only 240p, TV, webm_dash 396 mp4 480x360 25 | 82.96MiB 262k https | av01.0.01M.08 262k video only 360p, TV, mp4_dash 134 mp4 480x360 25 | 84.29MiB 266k https | avc1.4d4015 266k video only 360p, TV, mp4_dash 18 mp4 480x360 25 2 | 188.16MiB 595k https | avc1.42001E mp4a.40.2 44k [es] 360p, TV 243 webm 480x360 25 | 74.73MiB 236k https | vp9 236k video only 360p, TV, webm_dash 397 mp4 640x480 25 | 134.37MiB 425k https | av01.0.04M.08 425k video only 480p, TV, mp4_dash 135 mp4 640x480 25 | 140.00MiB 442k https | avc1.4d401e 442k video only 480p, TV, mp4_dash 244 webm 640x480 25 | 115.42MiB 365k https | vp9 365k video only 480p, TV, webm_dash 398 mp4 960x720 25 | 236.42MiB 747k https | av01.0.05M.08 747k video only 720p, TV, mp4_dash 136 mp4 960x720 25 | 241.87MiB 764k https | avc1.4d401f 764k video only 720p, TV, mp4_dash 247 webm 960x720 25 | 210.84MiB 666k https | vp9 666k video only 720p, TV, webm_dash 399 mp4 1440x1080 25 | 405.95MiB 1283k https | av01.0.08M.08 1283k video only 1080p, TV, mp4_dash 137 mp4 1440x1080 25 | 765.37MiB 2419k https | avc1.640028 2419k video only 1080p, TV, mp4_dash 248 webm 1440x1080 25 | 401.99MiB 1271k https | vp9 1271k video only 1080p, TV, webm_dash -
I noticed that it was because of the video selection parameter that I added for the command that resulted in the download of the lower bitrate video. If I use this command below, I get the mp4 with the highest bitrate downloaded:
This is without the node that you referred to. Adding the node is still ahead for me.Code:yt-dlp -o "out/%%(title)s.%%(ext)s" %url% -t mp4
The AV1 AVC issue about which is better: I do understand the point prioritizing the AV1, but there is difference and it may depend on a personal preference which is better. It may also be the case that if the viewer does not know about the difference, they will not notice anything. However I realized my recent Vegas version cannot open AV1 videos, so better to grab the mp4. This way the issue is not relevant at the moment for me.
So at the moment this is my script, this asks for the link, and downloads the highest bitrate video and audio:
Code:download.bat @Echo Off set /p url=Enter video url: @Echo On yt-dlp -o "out/%%(title)s.%%(ext)s" %url% -t mp4
This is what it said before I installed:node.js
[debug] JS runtimes: none
After I installed one of the suggested versions for Windows 7 I got this:
[debug] JS runtimes: node not recognized then the version.
I would have posted a copy of the message but I already uninstalled that version.
I have not given up & plan to try another node version.
If that fails I will probably wait a while since I'm not having any problems downloading from YouTube currently.
Except what probably would not download anyway.
Protected copyrighted videos. -
Did you try version 20.19.2?
It works here:
Code:[debug] Command-line config: ['-v'] [debug] User config "C:\Users\User\AppData\Roaming\yt-dlp\config.txt": ['--rm-cache-dir', '--console-title', '--js-runtimes', 'node', '-o', '~/Desktop/%(title)s.%(ext)s', '-S', 'res:1080,vcodec:vp9,acodec:opus', '--embed-thumbnail', '--add-metadata', '--convert-thumbnails', 'jpg', '--ppa', 'ffmpeg:-metadata synopsis=""', '--force-ipv4', '-N', '6', '--sponsorblock-remove', 'all'] [debug] Encodings: locale cp1252, fs utf-8, pref cp1252, out cp1252 (No VT), error cp1252 (No VT), screen cp1252 (No VT) [debug] yt-dlp version nicolaasjan/yt-dlp@2025.12.31.054119 (win_exe) [debug] Python 3.14.2 (CPython AMD64 64bit) - Windows-7-6.1.7601-SP1 (OpenSSL 3.0.18 30 Sep 2025) [debug] exe versions: ffmpeg N-122272-g224b3ff82a-WIN7 (fdk,setts), ffprobe N-122272-g224b3ff82a-WIN7, phantomjs 2.5.0 [debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2025.11.12, curl_cffi-0.13.0, mutagen-1.47.0, requests-2.32.5, sqlite3-3.50.4, urllib3-2.6.2, websockets-15.0.1, yt_dlp_ejs-0.3.2 [debug] JS runtimes: node-20.19.2 [debug] Proxy map: {} [debug] Request Handlers: urllib, requests, websockets, curl_cffi [debug] Plugin directories: C:\Users\User\AppData\Roaming\yt-dlp\plugins\bgutil-ytdlp-pot-provider\yt_dlp_plugins [debug] Loaded 1848 extractors Removing cache dir C:\Users\User/.cache\yt-dlp .. -
@ nicolaasjan,
I must be doing the install incorrectly.
I keep getting this message when i try to install node-v20.19.2-x86.msi .
This application is only supported on Windows 8.1,
Windows Server 2012 R2, or higher. -
Oh, I used the portable zip file (node-v20.19.2-win-x86.zip) and extracted to C:\bin\node.
Then added that folder to the environment variables (PATH):
In an elevated command prompt enter:
Or, if you like the GUI way:Code:setx /m PATH "%PATH%;C:\bin\node"
https://www.computerhope.com/issues/ch000549.htm#windows7Last edited by nicolaasjan; 31st Dec 2025 at 13:40.
@ nicolaasjan,
Thanks for all the help.
You sent me the correct link for nodejs.
I just did not download it correctly.
I started over & the second time it worked.
The node-v20.19.2-x86.msi put these entries in the Enviromental Variables: C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin
I extracted the node.js-windows-7-main.zip to its' own folder on my Desktop.
I then used the node-v20.19.2-win-x86.zip that was in the blue 20 folder.
I installed it from the extracted files from that folder.
I also use a portable yt-dlp.
I will now use two yt-dlp folders the new one that uses node & the older version that have the internal Javscript interpreter.
This will allow me to see the pre-merged m3u8 formats when I want them.
The debug report now looks like this:
Code:Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\User\Desktop\Vedit\yt-dlp>yt-dlp -vU --js-runtimes node --list-formats https://www.youtube.com/watch?v=ZfObjX-E_g4 [debug] Command-line config: ['-vU', '--js-runtimes', 'node', '--list-formats', 'https://www.youtube.com/watch?v=ZfObjX-E_g4'] [debug] Encodings: locale cp1252, fs utf-8, pref cp1252, out utf-8 (No VT), error utf-8 (No VT), screen utf-8 (No VT) [debug] yt-dlp version nicolaasjan/yt-dlp@2025.12.31.054119 (win7_x86_exe*) [debug] Python 3.14.2 (CPython AMD64 32bit) - Windows-7-6.1.7601-SP1 (OpenSSL 3.6.0 1 Oct 2025) [debug] exe versions: ffmpeg N-119166-g1e5c65f539-WIN7 (fdk,setts), ffprobe N-121473-gdc39a576ad-WIN7 [debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2025.11.12, mutagen-1.47.0, requests-2.32.5, sqlite3-3.50.4, urllib3-2.6.2, websockets-15.0.1, yt_dlp_ejs-0.3.2 [debug] JS runtimes: node-20.19.2 [debug] Proxy map: {} [debug] Request Handlers: urllib, requests, websockets [debug] Plugin directories: none [debug] Loaded 1848 extractors [debug] Fetching release info: https://api.github.com/repos/nicolaasjan/yt-dlp/releases/latest Latest version: nicolaasjan/yt-dlp@2025.12.31.054119 yt-dlp is up to date (nicolaasjan/yt-dlp@2025.12.31.054119) [debug] [youtube] [pot] PO Token Providers: none [debug] [youtube] [pot] PO Token Cache Providers: memory [debug] [youtube] [pot] PO Token Cache Spec Providers: webpo [debug] [youtube] [jsc] JS Challenge Providers: bun (unavailable), deno (unavailable), node, quickjs (unavailable) [youtube] Extracting URL: https://www.youtube.com/watch?v=ZfObjX-E_g4 [youtube] ZfObjX-E_g4: Downloading webpage [youtube] ZfObjX-E_g4: Downloading tv client config [debug] [youtube] Forcing "main" player JS variant for player 50cc0679 original url = /s/player/50cc0679/player_es6.vflset/en_US/base.js [youtube] ZfObjX-E_g4: Downloading player 50cc0679-main [youtube] ZfObjX-E_g4: Downloading tv player API JSON [debug] [youtube] ZfObjX-E_g4: Detected a 15s ad skippable after 5s for tv [youtube] ZfObjX-E_g4: Downloading android sdkless player API JSON [youtube] [jsc:node] Solving JS challenges using node [debug] [youtube] [jsc:node] Using challenge solver lib script v0.3.2 (source: python package, variant: minified) [debug] [youtube] [jsc:node] Using challenge solver core script v0.3.2 (source: python package, variant: minified) [debug] [youtube] [jsc:node] Running node: 'C:\Program Files\nodejs\node.EXE' --experimental-permission --no-warnings=ExperimentalWarning - [debug] Sort order given by extractor: quality, res, fps, hdr:12, source, vcodec, channels, acodec, lang, proto [debug] Formats sorted by: hasvid, ie_pref, quality, res, fps, hdr:12(7), source, vcodec, channels, acodec, lang, proto, size, br, asr, vext, aext, hasaud, id
How to make my Win7 OS bootable on modern PC?
By Aludin in forum ComputerReplies: 11Last Post: 4th Mar 2024, 11:21 -
MKVToonix status for Win7 or Win10
By loninappleton in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2023, 18:09 -
Youtube-dl-gui on Win7 and Win10
By Axel Slingerland in forum Video Streaming DownloadingReplies: 9Last Post: 6th Jan 2022, 08:41 -
Help with yt-dlp
By Loryanam2 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Jan 2022, 12:57 -
Elgato HD60 pro & WIN7 playout without game capture soft
By dA_KiDMaN in forum Capturing and VCRReplies: 0Last Post: 22nd May 2021, 06:15
