Results 1 to 21 of 21
  1. Capturing Memories dellsam34's Avatar
    Jan 2016
    I have few MKV files ripped from Blu-Ray using MakeMKV, I'm trying to strip them from the MKV container to basic h.264, I'm trying to work on them in a program that doesn't take MKV files. What's the easiest script in ffmpeg that can do it without altering the file integrity?
    Here is the Mediainfo:
    General
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 1.68 GiB
    Duration                                 : 6 min 58 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 34.4 Mb/s
    Frame rate                               : 23.976 FPS
    Writing application                      : MakeMKV 1.18.2 win(x64-release)
    Writing library                          : libmakemkv 1.18.2 (1.3.10/1.5.2) win(x64-release)
    Video
    ID in the original source medium         : 4113 (0x1011)
    Format profile                           : High@L4.1
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Format settings, Slice count             : 4 slices per frame
    Codec ID                                 : V_MPEG4/ISO/AVC
    Bit rate mode                            : Variable
    Bit rate                                 : 30.9 Mb/s
    Maximum bit rate                         : 39.0 Mb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.621
    Time code of first frame                 : 00:59:59:00
    Stream size                              : 1.50 GiB (90%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Original source medium                   : Blu-ray
    Audio #1
    ID in the original source medium         : 4352 (0x1100)
    Format                                   : DTS XLL
    Format/Info                              : Digital Theater Systems
    Commercial name                          : DTS-HD Master Audio
    Codec ID                                 : A_DTS
    Bit rate                                 : 1 989 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 93.750 FPS (512 SPF)
    Bit depth                                : 24 bits
    Compression mode                         : Lossless
    Stream size                              : 99.2 MiB (6%)
    Title                                    : Stereo
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio #2
    Format                                   : DTS
    Codec ID                                 : A_DTS
    Bit rate mode                            : Constant
    Bit rate                                 : 1 509 kb/s
    Bit depth                                : 24 bits
    Stream size                              : 75.3 MiB (4%)
    Title                                    : Stereo
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Text
    ID in the original source medium         : 4608 (0x1200)
    Format                                   : PGS
    Codec ID                                 : S_HDMV/PGS
    Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
    Duration                                 : 6 min 48 s
    Bit rate                                 : 15.5 kb/s
    Frame rate                               : 0.269 FPS
    Count of elements                        : 110
    Stream size                              : 771 KiB (0%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
  2. Try :
    clever-FFmpeg-GUI [Extract streams -> Raw Stream]
    or .. for many files .. a PowerShell/FFmpeg script that will extract the h.264 video streams from files:
    Get-ChildItem *.mkv | ForEach-Object {
    ffmpeg -i "$($_.FullName)" -c:v copy -an "$($_.BaseName)_converted.mp4"
    - Script will process all MKV files in the current directory
    - Each file gets a `_converted` suffix to avoid overwriting originals
    - The conversion is essentially a container change [not a re-encode]. The output is an `.mp4` container.
    - Make sure FFmpeg.exe is in your system path
    Mar 2008
    This program can extract elementary streams
    https://www.videohelp.com/software/MKVcleaver
  4. Capturing Memories dellsam34's Avatar
    Jan 2016
    I would prefer a script, But I will give those a try, if encoding less than or equal to real time that means it's doing something wrong.
    Jan 2016
    MKVcleaver is reporting this message: Mkvextrac.ex and/or Mkvmerge.exe was not found.
    Mar 2008
    You have to point the program to your mkvtoolnix location
  7. Capturing Memories dellsam34's Avatar
    Jan 2016
    Clever-ffmpeg is no no for me, it either extracts the streams individually or encode as a whole package which is not lossless and takes time.
    Jan 2016
    I see, I have to download this toolkit then.
  9. Capturing Memories dellsam34's Avatar
    Jan 2016
    Getting error while trying to install mkvtoolnix.
    Edit: Run as admin I was able to install it.
    Mar 2008
    That's good but it shouldn't be necessary, however, I used the portable version (as you can probably tell from my path name)
  11. Capturing Memories dellsam34's Avatar
    Jan 2016
    MKVCleaver is no no too, It just extracts all streams to separate files, that's not what I want. I want a single file like the original m2ts on the disc.
  12. Something like this?
    ffmpeg.exe -i "your_.mkv" -map 0 -c copy -bsf:v h264_mp4toannexb -f out.ts "new_.ts"
    Mar 2008
    You said at the top post
    "I'm trying to strip them from the MKV container to basic h.264"
    that's what this program does. It gives you the elementary stream, *.h264
    MKV is used because if accepts almost all variations of audio and video formats/codecs.
    You could try remuxing to mp4 in Avidemux, but I'm not sure whether the DTS audio is supported.
    Open the source in Avidemux, leave audio and video set to "copy" on the left, and set the output format
    (lower left) to mp4 muxer
    Or for remuxing to a *.ts or *.m2ts, you can try TSMuxer GUI
  14. Capturing Memories dellsam34's Avatar
    Jan 2016
    Something wrong with that script.
  15. Capturing Memories dellsam34's Avatar
    Jan 2016
    Yes but I want one file with audio, not muted video and a separate audio file.
  16. Capturing Memories dellsam34's Avatar
    Jan 2016
    When I try to open the file in TSmuxeR GUI it says TSmuxeR not found, The same error when I drag and drop the file into the program input field.
  17. Originally Posted by dellsam34 View Post
    Sorry, try
    ffmpeg -i "your.mkv" -map 0 -c copy "out.ts"
  18. Capturing Memories dellsam34's Avatar
    Jan 2016
    I think I may have tried that already and it didn't work, found in a google search, let me double check.
    Edit:
    It looks like it worked with a yellow message, But all the streams are there in one file:
    [mpegts @ 000001c1b1e44b40] Stream 3, codec hdmv_pgs_subtitle, is muxed as a private data stream and may not be recognized upon reading.
    Thank you.
  19. Originally Posted by dellsam34 View Post
    Edit:
    Thank you.
    Good. For more details see here:
    https://trac.ffmpeg.org/wiki/Map
    Mar 2008
    Download the the missing exe from here:
    https://github.com/justdan96/tsMuxer/releases/download/2.7.0/tsMuxer-2.7.0-win64.zip
    extract the file and put it in the same folder as the GUI component
  21. First I suggest you strip out you subtitles from your.mkv.
    They are not going to work anyway because ffmpeg can not convert hdmv_pgs_subtitles.
    At least not to a output.ts file.
    ffmpeg -i "input.mkv" -c:v copy -c:a copy -sn -avoid_negative_ts make_zero "out.mkv"
    Then the new "out.mkv" without subtitles will be the "input.mkv" in the code below.
    ffmpeg -i "input.mkv" -c:v copy -c:a copy "out.ts"
