    Aug 2018
    Wrocław
    What's the current best way to convert YUV to RGB using ffmpeg?
    Is -pix_fmt rgb48 enough(1), or should I still use "-sws_flags spline+accurate_rnd+full_chroma_int" (apparently it's already enabled by default)?
    A different filter? Zscale?
    It is important that the filter respects the encoding settings, e.g. BT601 limited range or BT709 full range.
    (1) "ffmpeg -avisynth_flags +all -i "input.avs" -c:v rawvideo -pix_fmt rgb48 -f nut
  2. ffmpeg using Avisynth script with z_ConvertFormat(........) ?
    http://avisynth.nl/index.php/Avsresize
    Aug 2018
    Wrocław
    Yes, I'm considering it.
    By the way, will regular ConvertToRGB48 be any worse?
  4. Originally Posted by rgr View Post
    It shouldn't. Maybe some rounding differences? I don't really know.
