I'm really struggling to get QTGMC's EzDenoise to work. In the plugins folder of AvisynthRepository/AVS260, I stripped out everything bar what was needed for QTGMC() to run. I then got the 32 and 64-bit versions of libfftw3f-3.dll and renamed each FFTW3.dll, putting the 32 bit dll in the SysWow64 folder and the 64 bit dll in the system32 folder. Next, I put fft3dfilter.dll into the plugins folder. Thinking that was it, I ran a script with QTGMC(InputType=1, EzDenoise=1.0, Preset="medium") and got this error message:
Evaluate: Unrecognized exception!
(Zs_RF_Shared.avsi, line1614)
(Zs_RF_Shared.avsi, line1614) ## yes, it was repeated
(QTGMC.avsi, line 794)
Line 1614 of Zs_RF_shared.avsi begins:
input.FFT3DFilter(sigma=sigma, beta=beta, bw=bw, bh=bh, bt=bt, ow=ow, oh=oh, ….....
The whole of line 794 of QTGMC.avsi is:
noiseWindow.sneo_FFT3D( u=ChromaNoise ? 3 : 2,v=ChromaNoise ? 3 : 2, sigma=Sigma, bt=noiseTD, ncpu=FftThreads )
Is the issue to do with the naming of FFT3DFilter / FFT3D?
Whatever the problem what would be the cure? My sincere and grateful thanks.
Hi Alwyn. I'm confident I have the 'library files' in the right places. Tried yours, no change.
Hi Sharc. I have Avisynth+ 3.7.0 (64-bit) installed as well as 2.6.0 (32-bit). The 3.7.0 loads EzDenoise with no problem. The perfectionist in me just wants 2.6.0 to do the same.
As an experiment, I ran my 32-bit MeGUI with the 'Always use the included avisynth' checked. My thinking being that I'd be totally bypassing all the files in the 'Avisynth Repository' (where my 2.6.0 and 3.7.0 reside). Not so, for some reason: I still got an error referencing Zs_RF_Shared.avsi and QTGMC.avsi from the Repository. Only this time the error was called System exception - Access Violation.
Can run QTGMC but not EzDenoise
By pooksahib in forum Video ConversionReplies: 1Last Post: 19th Dec 2025, 11:40 -
QTGMC can't run on multiple cores
By InfiniteErosion in forum RestorationReplies: 5Last Post: 26th Feb 2024, 18:18 -
Best Deinterlacing like QTGMC
By Jay123210599 in forum Newbie / General discussionsReplies: 10Last Post: 4th Dec 2023, 20:40 -
Help with QTGMC AVIsynth
By indyracingfan in forum Capturing and VCRReplies: 18Last Post: 22nd Nov 2023, 18:21 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01
