Results 1 to 19 of 19
  1. I cannot download video like this: https://media.nws.edu/videos/honeck-mahler-4-12-14-2025-02-39-44
    Any idea?
    Thanks a lot
  2. Sorry, but it isn't a subscription service
  3. Code:
    N_m3u8DL-RE "https://vod-adaptive-ak.vimeocdn.com/exp=1766344076~acl=%2Fe23c3da6-1602-4670-8043-4e00b57d1ffe%2Fpsid%3D801c36c6e8cac5234dbb7ab5011380cb1e9568d5a851e94d872bcd832a585860%2F%2A~hmac=4eec96384bf06b3c14db1fb9177034aa77a83899adc94e396350eac6857ff023/e23c3da6-1602-4670-8043-4e00b57d1ffe/psid=801c36c6e8cac5234dbb7ab5011380cb1e9568d5a851e94d872bcd832a585860/v2/playlist/av/primary/sub/272176897-en-x-autogen/prot/cXNyPTE/playlist.m3u8?ext-subs=1&locale=en&omit=av1-hevc-opus&pathsig=8c953e4f~3CcwEuk3mHOpdMZEsKFKUWA6MOxtc_WhYX83UZup3fI&qsr=1&r=dXM%3D&rh=2ACB8s&sf=ts" --save-name "Honeck: Mahler 4 - 12/14/2025" --thread-count 16 --auto-select -mt --download-retry-count 999 -M mkv
  4. Thanks a lot, forget. Best regards from Paris
  5. I've created this program to help those who like classical music and would like to treasure these videos.
    The program is also a tribute to [ss]vegeta [https://forum.videohelp.com/members/177118-%5Bss%5Dvegeta]. Here is a person who has dedicated numerous hours and for many years helping people.
    Thanks [ss]vegeta for your continued service to teaching and helping others.
    This program has all it's dependencies built in. The user needs to know nothing about the technicalities and does not need to have any preinstalled software.
    URL for downloading the program [nws_downloader.exe]
    https://mega.nz/file/JpMR3TDR#eIzrBjO91kcQxNYbbCwXi5vR4ohMti_udgXWKk000v8
    Info on using the program
    1)Go to this URL
    https://media.nws.edu/browse
    [There is no need to sign up]
    2) right click on any stream of interest
    3) copy link address [The url is now stored on the Windows's Clipboard]
    for example
    https://media.nws.edu/videos/ytb20250115-stravinsky-scenes-de-ballet-mtt-flv-1
    OR the one required by the operator
    4) With the URL now stored on the Clipboard, double click the program [nws_downloader.exe] Icon
    The stream will be downloaded and saved in the Windows Download directory.
    Remember : If you love the New World Symphony Orchestra, which I'm positive that you will, please support them. They are a group of very talented young musicians. Kudos to them.
  6. That's marvelous, Gromyko. But it doesn't work, for exemple, with this : https://www.arte.tv/fr/videos/127027-000-A/johann-strauss-wiener-blut/
  7. nws_downloader.exe
    Dec 2021
    england
    drm free...
    N_m3u8DL-RE.exe "https://manifest-arte.akamaized.net/api/manifest/v1/Generate/5d212ca4-d335-4496-8ddd-d4d3120614f2/fr/XQ+KS+CHEV1/127027-000-A.m3u8" -M format=mkv
    [Attachment 90507 - Click to enlarge]
  9. My bad! Thanks a lot
  10. Originally Posted by forget View Post
    I know the request has been fulfilled, thanks to you and Gromyko for his amazing program. However, for learning purposes, I’d like to know how you obtained the M3U8 URL. I tried checking the Network tab, but I only found a JSON URL. I also used M3U8 sniffers, but I couldn’t capture anything. If you could share the method you used, I’d be grateful. Alternatively, if any other members know how to obtain the M3U8 URL, that would be very helpful
  11. Originally Posted by giampi View Post
    I needed help with "nws" site not "arte"
    and I tried video download helper extension and it didn't help at all
    thanks anyway giampi
  12. Thanks a lot, appreciate your help forget
  13. Originally Posted by Gromyko View Post
    What an honor! Thank you so much Gromyko! Love the icon, truly appreciate this! And thank you for noticing my efforts over the last few years!
    The application works perfectly and it's so easy to use!
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  14. Hello everyone,
    best wishes to all and good health.
    If you want, with Tampermonkey you can detect and decode m3u8 URLs. To simplify things, add a command with N_M3U8DL-RE.
    Here is a command to decode the characters: ?, =, &, / etc. in JavaScript
    decodeURIComponent(url)
    Here is a command to decode the characters: ?, =, &, / etc in Python
    s = "\\u0026"
    decoded = s.encode("utf-8").decode("unicode_escape")
    print(decoded)  # &
  15. Hello sesamap159, can you give me some more explications? I don't understand what to add to Tampermonkey.
    Thank you very much
  16. Hello Giampi,
    I mean, in the URL of the site you provided, your M3U8 link is encoded with Unicode characters to simplify things. To get the M3U8 URL decoded and avoid using Notepad to replace \u0026 with &, you can directly use the M3U8 detector with URL decoder to simplify the process. There's even an integrated command with N_M3U8DL-RE to download the video of your choice.
    As you can see from the website https://www.arte.tv in the previous discussion, you can create an m3u8 detector from tampermonkey to simplify things.
    [Attachment 90606 - Click to enlarge]
