  1. My avisynth comes from the Universal Avisynth Installer (not the old-fashioned manual installation method) and I have 32 and 64-bit versions activated. In the plugins folder of each is a folder: fftw-3.3.5-dll32 and fftw-3.3.5-dll64 respectively.
    From both, I've copied the libfftw3f-3.dll into its upper folder i.e. plugins and then copied/renamed it FFTW3.dll.
    I've copied FFTW3.dll (32bit) into SysWow64.
    I've copied FFTW3.dll (64bit) into system32.
    In each plugins folder (32 and 64-bit) I also have fft3dfilter.dll, mvtools2.dll and others.
    Now to my problem: when I open a script with my 64-bit MeGUI I can happily include the line
    QTGMC(InputType=1, EzDenoise=1.0, Preset="medium")
    But with 32-bit MeGUI (the one I use most) I only get as far as
    QTGMC(InputType=1)
    Any idea why I can't call EzDenoise with 32-bit MeGUI/avisynth? Many thanks.
  2. Issue calling EzDenoise with 32-bit MeGUI/Avisynth:
    Compatibility Issues
    The primary problem appears to be related to DLL dependencies, specifically the FFT3DF Filter.
    1. DLL Mismatch: You mentioned having trouble executing crucial DLLs like:
    - fftw3.dll
    - libfftw3f-3.dll
    2. Architecture Compatibility: When moving from 32-bit to 64-bit systems, plugin and DLL
    compatibility is problematic.
    Potential Solutions:
    DLL Placement
    - Ensure you're using the correct 32-bit versions of the required DLLs
    - Renaming libfftw3f-3.dll to fftw3.dll in the System32 folder might work
    Plugin Configuration
    - Double-check that all Filter dependencies are installed for the 32-bit version
    - Verify that the AviSynth plugins are specifically configured for 32-bit architecture
    Troubleshooting Steps
    1. DLL Compatibility Verification
    - Confirm you're using 32-bit versions of:
    * fftw3.dll
    * libfftw3f-3.dll
    - Verify these DLLs are specific for 32-bit Avisynth
    2. Plugin Configuration
    - Ensure FFT3DF Filter is correctly installed for 32-bit architecture
    Recommended Actions
    - Download fresh 32-bit versions of the required DLLs
    - Verify plugin compatibility with your MeGUI version
    - Consider renaming libfftw3f-3.dll to fftw3.dll in the System32 folder
