Clever FFmpeg-GUI.
Load your m2ts, click encode videostream, set the encoder, click adjustment, make you settings, you can also preview the result, and click encode.
If done, mux the streams to mkv.Last edited by ProWo; 11th Dec 2025 at 04:30.
It works fine. But there is one thing. Can I force it to 4 reference frames in x264 mode when I use the preset "slower"? You can do that in Handbrake. And if I don't, it automatically becomes 8. And it causes pixel errors, on my LG Oled tv. "Slower" gives a little better quality than "slow" does.
Convert-mkv-4k-to-UHD-Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 16Last Post: 5th Aug 2023, 04:55 -
Convert mkv 4k to UHD Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Aug 2023, 20:51 -
Full Bluray 3D ISO to 1:1 copy to mkv
By smounche in forum Blu-ray RippingReplies: 16Last Post: 15th May 2023, 14:00 -
Help with lossless conversion mkv to bluray with menu
By maltersxd in forum Authoring (Blu-ray)Replies: 20Last Post: 11th Jul 2022, 01:21 -
Problem with HSBS 3D mkv when converting from in-mux 3D bluray
By NetDragon in forum Video ConversionReplies: 0Last Post: 25th Jul 2021, 17:43
