Hello,
in adobe premier I put this video file which has 3 audio: Stereo Italian, 5.1 Italian Stero Japanese.
However, when I put it in Premiere, I see only 2 audio tracks, and if I solo each track, one is italian and the plays italian and japanese together at the same time. This happens even if I create a sequence by dragging the video on the new sequence button. I think it's a premiere error of interpretation because in MKVToolNix and ffmpeg the streams are 3, not 2. How can I fix this?
HTML Code:Stream #0:1(ita): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Metadata: title : Surround 5.1 BPS-eng : 448000 DURATION-eng : 01:28:36.512000000 NUMBER_OF_FRAMES-eng: 166141 NUMBER_OF_BYTES-eng: 297724672 SOURCE_ID-eng : 0180BD _STATISTICS_WRITING_APP-eng: [url=https://www.videohelp.com/software/MakeMKV]MakeMKV[/url] v1.18.1 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2025-10-09 16:41:52 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:2(ita): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: title : Stereo BPS-eng : 192000 DURATION-eng : 01:28:36.512000000 NUMBER_OF_FRAMES-eng: 166141 NUMBER_OF_BYTES-eng: 127596288 SOURCE_ID-eng : 0181BD _STATISTICS_WRITING_APP-eng: MakeMKV v1.18.1 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2025-10-09 16:41:52 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:3(jpn): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: title : Stereo BPS-eng : 192000 DURATION-eng : 01:28:36.512000000 NUMBER_OF_FRAMES-eng: 166141 NUMBER_OF_BYTES-eng: 127596288 SOURCE_ID-eng : 0182BD _STATISTICS_WRITING_APP-eng: MakeMKV v1.18.1 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2025-10-09 16:41:52 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
Results 1 to 14 of 14
Here is a 10 sec sample: https://drive.google.com/file/d/1zRXf1fpa2SlumPt_xqKru5M55gmQwKGc/view?usp=drive_link
this is how it looks in Premiere
[Attachment 90194 - Click to enlarge] -
Since I don't have Premier, I'm gonna take a guess that it either:
1- doesn't like the 6 Channels [possible channel mapping issue?], or
2- doesn't support ac3 @448 kb/s [possible bit rate limit?]
try:
1- reducing stream 1 to ac3, 6 ch, 192 kb/s first, and try it again in Premier
2- if that doesn't work, try re-mapping the 6-channels layout
you can do both in clever FFmpeg-GUI
Stream 0:0, Video, mpeg2video, 6536 kb/s, 720 x 576, 1.78, 25 fps, eng
Stream 0:1, Audio, ac3, 6 Channels, 448 kb/s, ita
Stream 0:2, Audio, ac3, 2 Channels, 192 kb/s, ita
Stream 0:3, Audio, ac3, 2 Channels, 192 kb/s, jpn
Stream 0:4, Subtitle, dvd_subtitle, ita
Stream 0:5, Subtitle, dvd_subtitle, ita
---> Chapters
[Attachment 90199 - Click to enlarge]Last edited by videoAI; 11th Dec 2025 at 04:58.
Could be a muxing issue.
Retry with both remuxed samples.Last edited by ProWo; 11th Dec 2025 at 05:06.
@Filippo
#1- Try mux-ing the file but only select video stream and the 5.1 audio stream.
Q: does premier display the 5.1 audio? if not ->#2
#2- Extract Audio 5.1 stream only into raw stream or m4a [or mka] container.
Q: does premier display the 5.1 audio? if not reinstall Premier -
I tried uninstalling/reinstalling/empty cache Premiere but without results. I'm using Autokroma plugin to import mkv, It is compatible with the 2025 version, I tried disabling it but Premiere would not import .mkv. I tried using both override and not override Adobe file import without success. Anyway I have this issue even with the supported .mp4 sample.
I agree with videoAI.
You might try opening the 5.1 file in Audacity.
Then exporting it as the same statistics for the file.
Then add this file to Premiere as the 5.1 channel file.
See if Premiere detects it & show audio on it.
This is one I did with Audacity.
Give it a try.Last edited by cholla; 11th Dec 2025 at 14:51.
Split PCM stream with 4 channels to individual aac mono streams
By Opera59 in forum AudioReplies: 5Last Post: 18th Mar 2025, 04:25 -
FFmpeg audio channels
By khaled22 in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2023, 15:32 -
How to change audio channels without re-encoding?
By Boxcart in forum AudioReplies: 27Last Post: 2nd Feb 2023, 19:58 -
Missing Channels on Atmos Audio
By Loup in forum Video ConversionReplies: 5Last Post: 18th Apr 2022, 03:35 -
Premiere CC 2019 and importing 5.1 audio as 6 mono channels
By Stile in forum EditingReplies: 0Last Post: 20th Apr 2021, 16:01
