  1. Frank-0-Video Frank-0-Video's Avatar
    Jan 2009
    Alabama - United States
    Greetings ....
    It is informal understanding on my part that USB flash drives can be formatted as either FAT32 or NTFS. I further understand -- also informally -- that an NTFS formatted flash drive allows for files with sizes of greater than 4 GB, while a FAT32-formatted flash drive is limited to files under the 4 GB size.
    I have seen online advice on how to format a USB flash drive using the NTFS standard, and this includes a notation that (depending on your Windows 10/11 setup) one may need to first invoke a routine that will allow a FAT32-formatted flash drive to be re-formatted as NTFS.
    Now what about USB flash drives that you have been using (or about to use) without re-formatting? Is there a method to test each such drive to determine if it is formatted in FAT32 or NTFS mode ?
    One final inquiry -- with regard to any video or audio file 4 GB or greater in size -- will modern smart TV's be able to play such files -OR- will it be necessary to re-size such files ?? If by chance smart TV's can't handle audio and/or video files up to (or beyond) 4 GB in size, then what is the proper max size in this particular regard ???
    Thanx-A-Lotte, Frank-0-Video
    THE Ultimate TV Tuner Device - Picks up every broadcast-cable-satellite transmission since 1928!
  2. I have had good results with NTFS for TVs & settop players.
    They also use FAT32 OK. But as you said a size limit of 4GB.
    Some devices will only use FAT32 like my car stereo does.
    So you need to read the manual for each device & see what it accepts.
    Don't forget exFAT as another formatting option.
    This will give you the drive format type & allocation size.
    As well as the allocation options for each format.
    Usually use the larger allocation sizes for large files.
    In the command prompt. Run as Administrator if possible.
    Use diskpart.exe.
    In command type: diskpart
    Once you are in diskpart
    type: list volume
    type: select volume <VolumeNumber>
    type: filesystems
    Oct 2018
    Town Spa Pizza, United States
    I have used exfat only recently because it is my understanding it is cross compatible with Mac, PC and TV and it did work for the client.
