    Apr 2024
    Somewhere on Earth
    A concurrent video Downloader that downloads private and embedded Vimeo videos.
    ## Usage
    python3.12 vimeo-private-video-dl.py "JSON_Playlist_URL" "output_file_name"
    you need to pass output name with video extension example .ts, .mkv. .mp4
    To get the Vimeo JSON playlist, open your browser and press F12. Switch to the Network tab then load the video page. In the filter box, type "playlist". Right-click on that request, copy the value plus then click Copy URL.
    Windows Guide:
    To use this tool download FFmpeg from https://www.gyan.dev/ffmpeg/builds/ After downloading, extract the archive, open the extracted folder and go to the /bin/ directory. Copy ffmpeg.exe, ffprobe.exe, into your Python script folder then run the Python script.
    Linux Guide
    Install FFmpeg using
    apt install ffmpeg
    [Attachment 90153 - Click to enlarge]
    Github: https://github.com/devnexusprime/vimeo-private-video-downloader
    Huge thanks to this forum! I’ve learned lot about video decryption here, and in return, Im contributing this small Python script.
  2. thanks for the sharing.
    May 2005
    PAL User
    Keep your nose out of Private videos.
  4. nice work there!
  5. is it diffent than downloading with yt-dlp? you only need to change ".json" to ".mpd" in the url to make yt-dlp grab this
