Results 1 to 1 of 1
    Dec 2025
    Philippines
    Trying to make my own BGVs for one of my own SD card karaoke players, specifically my HDT Premier-98sd.
    Tried to convert a video to the intended parameters using ShanaEncoder and put it to my player as BGV, but it led to an error - while a song is playing and my own BGV repeats, the video skips a lot.
    These are the properties of one of the built-in BGVs, according to MediaInfo:
    General
    Complete name                            : C:\Users\USERNAME\Videos\VIDEOD-01.mpg
    Format                                   : MPEG Video
    Format version                           : Version 2
    File size                                : 502 MiB
    Duration                                 : 13 min 57 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 5 029 kb/s
    Frame rate                               : 29.970 FPS
    FileExtension_Invalid                    : mpgv mpv mp1v m1v mp2v m2v
    Video
    Format                                   : MPEG Video
    Format profile                           : Main@Main
    Format settings                          : BVOP
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Default
    Format settings, GOP                     : M=3, N=15
    Bit rate mode                            : Variable
    Bit rate                                 : 5 029 kb/s
    Maximum bit rate                         : 7 000 kb/s
    Width                                    : 720 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 29.970 (30000/1001) FPS
    Standard                                 : NTSC
    Bits/(Pixel*Frame)                       : 0.486
    Time code of first frame                 : 00:00:00;00
    GOP, Open/Closed                         : Open
    GOP, Open/Closed of first frame          : Closed
    Stream size                              : 502 MiB (100%)
    What can I do to make my own BGVs work properly? What are the recommended tools to use? Freeware software is preferred.
