Results 1 to 16 of 16
    Jul 2014
    France
    So this concerns iPhone footage. Now I'd previously successfully used material of this kind to integrate with camcorder footage but ALWAYS with a transcode to constant frame rate before putting it into the timeline. This is the first time where I've directly loaded the source mov files into the editor.
    So my general workflow is to edit a 720p30 project>lagarith export>handbrake 30p 'production' archive and 30p or 60p reduced 'user' files. Worked without any problems til now. In this case I wanted to convert the final step to 60p in avisynth/vdub using John Meyer's genial little interpolation script. It went fine with Mediainfo showing a 60p constant frame rate. But when I went to try to mux in a secondary audio and a short subtitle with mkvmerge the resulting file registered as 60p VFR. I could live with this in a pinch, except for the fact that whereas the original encode was pretty smooth the remux came out with very noticeable judder. To my eyes the judder isn't a result of added/dropped frames. This happens even if I do a simple in/out in mkvtoolnix without adding anything to the mux. I've been using v10 or more recently v66 of Bunkus' app.
    As a workaround I attempted to add an srt using the ffmpeg command: -i input.mkv -subtitles.srt -map 0 -map 1 -c copy output.mkv, but it either throws an error as to not recognizing the output extension or, upon a second try, letting me know there's a timestamp problem and if I don't fix it I'll have problems down the line.
    What's going on and what to do? I've included a couple of short clips. Thanks in advance.
  2. This is because the videostream (16.915s) is shorter than the audiostream (17.400s).
    You can remux it with clever FFmpeg-GUI and it remains constant framerate.
  3. More info, diff between the two files ..
    Item premux.mkv postmux.mkv
    "duration": "17.400000" "17.331000" [format level]
    "duration": "17.400000" Null [v stream level]
    "duration_ts": 17400 Null [v stream level]
    "bit_rate": "4825157" "4826674"
    "is_avc": "false" "true"
    "nal_length": "0" "4"
    "r_frame_rate": "60/1" "1000/17"
    "avg_frame_rate": "60/1" "1000/17"
    Pre-mux.mkv ffmpeg error msg:
    Command failed with exit code 4294967274: "C:\Portable\PortableApps\LosslessCut\resources\ff mpeg.exe" -hide_banner -i "C:\T\Amidst 60p premux.mkv" -map_metadata 0 -map 0 -ignore_unknown -c copy -y "C:\T\Amidst 60p premux-reformatted.mkv"
    Input #0, matroska,webm, from 'C:\T\Amidst 60p premux.mkv':\r
    Metadata:\r
    encoder : libebml-0.7.5 & libmatroska-0.7.7\r
    creation_time : 2025-11-30T11:15:20.000000Z\r
    Duration: 00:00:17.40, start: 0.000000, bitrate: 4825 kb/s\r
    Stream #0:0(eng): Video: h264 (High) (h264 / 0x34363268), yuv420p(progressive), 1280x720 [SAR 1:1 DAR 16:9], 60 fps, 60 tbr, 1k tbn (default)\r
    Stream #0:1(eng): Audio: mp3 (mp3float) (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 224 kb/s (default)\r
    Stream mapping:\r
    Stream #0:0 -> #0:0 (copy)\r
    Stream #0:1 -> #0:1 (copy)\r
    Output #0, matroska, to 'C:\T\Amidst 60p premux-reformatted.mkv':\r
    Metadata:\r
    encoder : Lavf62.3.100\r
    Stream #0:0(eng): Video: h264 (High) (h264 / 0x34363268), yuv420p(progressive), 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 60 fps, 60 tbr, 1k tbn (default)\r
    Stream #0:1(eng): Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 224 kb/s (default)\r
    Press [q] to stop, [?] for help\r
    [matroska @ 00000199d4fe27c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly\r
    [matroska @ 00000199d4fe27c0] Can't write packet with unknown timestamp\r
    [vost#0:0/copy @ 00000199d722ed80] Error submitting a packet to the muxer: Invalid argument\r
    Last message repeated 1 times\r
    [out#0/matroska @ 00000199d503bd80] Error muxing a packet\r
    [out#0/matroska @ 00000199d503bd80] Task finished with error code: -22 (Invalid argument)\r
    [out#0/matroska @ 00000199d503bd80] Terminating thread with return code -22 (Invalid argument)\r
    [out#0/matroska @ 00000199d503bd80] video:1KiB audio:13KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: unknown\r
    frame= 1 fps=0.0 q=-1.0 Lsize= 14KiB time=00:00:00.04 bitrate=2334.9kbits/s speed=4.96x elapsed=0:00:00.00 \r
    Conversion failed!
    Timestamp error in video file. Use modified FFmpeg command:
    ffmpeg -hide_banner -i "C:\T\Amidst 60p premux.mkv" -map_metadata 0 -map 0 -ignore_unknown -c copy -fflags +genpts -y "C:\T\Amidst 60p premux-reformatted.mkv"
    Added `-fflags +genpts` to generate missing timestamps. Helps resolve packet timestamp errors.
    If unsuccessful, verify file integrity or consider re-encoding.
    Edit#1
    @ProWo
    FYI,
    Although the 'Amidst 60p premux.mkv' generates errors in some programs, including ffmpeg, & losslesscut,
    it passes Clever 'scan for errors' fine without any issues displayed !!
    Any room for improvement here?
    Last edited by videoAI; 30th Nov 2025 at 10:39. Reason: Clever scan for errors note to @ProWo
    Jul 2014
    France
    Thanks very much guys. The time stamps business does seem to be at the heart of the problem. However, since I first posted I finally managed to attack the problem from a different angle--from within mkvtoolnix itself. And the solution was there along. Simply 'forcing' the default fps to 60p in the timecodes box removes most of the judder and sets mediainfo back to 60p. Other problem areas in the larger video were vastly improved as well. As for the muxing of the 30p source encode, if I plug in a setting of 24/1001 the remux punches out a smooth as silk clip that I wasn't even able to reproduce while editing. Lol. Curiously, entering 30p gives a slightly inferior result. Now, that leaves the question of whether to check the 'fix bitstream timing info' box. Some follow-up research seems to reveal that this function is 'destructive'. However, NOT using that function gives the same or better results as just entering 60p, 24/1001, etc. Does anyone know when and why this bitstream fix is to be used or not? As to the audio desync issue, maybe this won't be a problem since 99% of the audio was never interleaved with the video. Further testing will tell. However, is the lesson to be learned here that to avoid such issues always transcode VFR material to constant before going down the editing road? Oh, and not to sound more newbish than I am...but how do I open/read a json file?
    EDIT: In the end the mkvtoolnix route does a decent if imperfect job for the 60p files with audio in sync. But the 24/1001 idea clearly throws the audio out in left-field somewhere. Doh! And with the others I'm always losing at least 1 second at the end of my 20min video. So back to the drawing board.
  5. I believe your source video is using a time base of 1000. 60 FPS can't be represented exactly in 1/1000ths of a second. It has to alternate between 17 milliseconds (twice) and 16 milliseconds (once), averaging 16.666... milliseconds (exactly 60 fps). So the source is inherently variable frame rate, even though it's flagged as constant frame rate. The remux is doing what it should -- flagging the video as the VFR it is. If you want a true 60 fps CFR video you need to use a time base that is an integer multiple of 60: 60, 120, 180, 6000, 60000...
  6. Notepad ..
    Originally Posted by Sumsaris View Post
    How do I open/read a json file?
    Aug 2018
    Wrocław
    If you want to do this type of work long-term, switching to AviSynth would be your best bet. It will solve most, if not all, of your problems.
    Jul 2014
    France
    @videoai
    Or with WinRAR. Doh! It was a sleepy Sunday. Thanks
    @jagabo
    Would this perhaps offer a partial explanation as to why my 50p videos don't exhibit such 'variableness'? Also, put in other terms, maybe this touches on the distinction between reading what's on the outside of the 'envelope' as opposed to what's inside. Not always the same (insofar as Mediainfo goes)?
    @rgr
    I did switch, some years ago. The two uploaded clips were made under an avisynth script authored in part by J Meyer.
    But the punch-line is elsewhere. After searching further afield I discovered today that other video files made weeks or months ago were showing similar symptoms of massive judder on pan sequences that were never there before. What gives? So I decided to shunt these clips over to my Sony Bravia which is three years older than my 10 year old Asus laptop, yet presto all the pans and zooms smoothed out like butter. Which meant to my chagrin that there was certainly either a hardware or software issue on my end. So to make the short story shorter I crossed my fingers and did a windows restore 10 days back and all returned to normal. I still don't have a clue what caused this. I had been dealing with an intermittent tearing problem and maybe pushed some buttons I shouldn't have. But anyway.... That said when y'all viewed those two little snippets did you actually ever detect any motion difference between them on your end?
    So thanks for the feedback and promise not to bother you til after Christmas.
  9. On my 60 Hz monitor they both played smoothly. The CFR/VFR issue here shouldn't make any difference in playback.
    Jul 2014
    France
    Yeah, jagabo, I figured as much. With my restored system now (I suspect my problem stemmed from pushing a button that let Haali get into the equation) the only combo that gives satisfactory playback on BOTH the computer and TV is the 60p VFR I uploaded. I can't get a decent 30p/29.97 encode that doesn't shimmer wildly in detailed pan scenes on the TV only. Maybe this is because of the superiority of the madvr renderer over the plain vanilla Sony tool. It'd be so much simpler if Apple gave you the option to do CFR. At least I've learned now to turn everything else OFF on the Iphone when shooting video to reduce the variability to a minimum. Or so I delude myself....
    Aug 2018
    Wrocław
    @rgr
    Can you upload the original 720p30 file?
    Jul 2014
    France
    @rgr
    Sorry for the delay in getting back to you. Life, etc got in the way. Ok, I'm uploading two additional clippets (not particularly glorious) but which serve to depict the gamut of the problem. When all is said and done, clearly the optimal solution is to punch out what Apple put in--namely 29.97 VBR. But easier said than done. The most basic question has to be: when my 11-versions old Pinnacle Studio exports its lagarith lossless file, what am I actually getting? Again, mediainfo tells me its 29.97 CBR. But can I believe it? What is insidious here is that if I load these mov files into mkvtoolnix after a simple in/out the VBR mov now becomes CBR mkv--the opposite of my experience noted above! Also from viewing all this on a Sony TV via a media box I seem to be able to make a distinction between a 'judder' problem and a 'shimmer' problem. 'Judder' is what I get if I output to 30p and 'shimmer' is generally the result of a 29.97 export. Shimmer = that mess of a mesh in the stucco wall and in the vibrating vegetation (roof tiles are another classic manifestation of this). Another oddity: of the very first six filmed sequences I shot on the IPhone 13 Pro, four register as constant frame rate and the other two variable. The four CBR in question all are without motion (neither subject nor camera), whereas the two VBR involve a subject crossing the plane of view (notably the plane sequence). Coincidence? Why? So do play with these and any light you can shed on the matter will make Christmas that much more pleasant. Thanks
    Aug 2018
    Wrocław
    Sorry for the late reply, life & memory
    1. All three videos are practically 30fps CFR. There are drops to 29.99fps, but they're minor.
    2. All videos run smoothly. I'm uploading my test conversion to 59.94fps (60000/1001) - it's also smooth, unless I'm missing something? (All I can see is that the RIFE 73 model used isn't great).
    3. I don't know what you're trying to achieve, but converting to CFR through Pinnacle doesn't seem like the optimal way to go. Why would you need it?
    4. It's CFR, not CBR, and VFR, not VBR. CBR and VBR refer to different things (bitrate).
    Edit: file reupload.
  14. Originally Posted by videoAI View Post
    @ProWo
    FYI,
    The errors exists only with the mkv muxer.
    Streamcopy to other containers (mp4,mov,avi) passes without errors.
    The error scan used in clever FFmpeg-GUI is using the null muxer and doesn't give any error.
    Aug 2018
    Wrocław
    I checked the file "Amidst 60p premux.mkv". Those wandering textures on the wall are a result of frame interpolation (you can try using a different model).
    Aug 2018
    Wrocław
    judder, shimmer
    I also see some stabilization and upscaling was used. This "floating" image is probably due to one of these two factors.
