Results 1 to 23 of 23
  1. I had used Devine to do a download over night. It had finished and then I went to Rename My TV Series to rename and then the computer froze. I pressed CTRL ALT DELETE and it didn't seem to work. I went away for about a minute and when I came back the screen was completely black. I pressed in the power button and it still remained black. Then I unplugged the power adapter and then I unplugged it for a longer time.
    I am hoping I have not lost Windows and everything I have on this hard drive. On the main screen of this Aptio Setup AMI it says near the bottom:
    SATA Information:
    Serial ATA port 1 empty
    I need some help as no matter what I choose it brings me right back to this Aptio Setup AMI.
  2. No matter what I select it seems to be stuck at this. Maybe the hard drive failed. Nothing positive seems to be able to be found via a Google search. I really enjoyed this Mini PC. I hate that I have probably lost everything that was on the 1 TB SSD drive. It is terribly depressing.
  3. It is a NVME 1 TB hard drive. I hope I can put it in an enclosure and get the files off it. It says no NVME device found. So it looks like it is dead. This had destroyed my confidence in Mini PCs.
  4. I hope this helps ..
    Initial Assessment
    Your computer appears to be stuck in BIOS/UEFI firmware setup,
    which suggests a potential boot device detection problem.
    The "SATA Information: Serial ATA port 1 empty" message is particularly concerning.
    Possible Scenarios
    1. Hard Drive Disconnection
    2. Drive Failure
    3. BIOS/UEFI Configuration Issue
    4. Potential Motherboard Problem
    Diagnostic Steps
    Physical Inspection
    1. Verify hard drive connections:
    - Ensure SATA cable is firmly connected
    - Check power cable connection
    - Try alternate SATA ports on motherboard
    - If possible, reseat the hard drive
    BIOS/UEFI Checks
    1. Enter BIOS/UEFI Setup (by pressing F2, Del, or F12 during startup)
    2. Navigate to:
    - Storage Configuration
    - Boot Order
    - SATA Controller Settings
    Potential Recovery Actions
    - If drive is detected: Verify boot order
    - If drive is not detected:
    - Try different SATA cable
    - Test hard drive on another computer
    - Consider professional data recovery
    Immediate Recommendations
    1. Do not panic about data loss yet
    2. Carefully check physical connections
    3. If comfortable, try removing and reinserting hard drive
    4. Consider professional diagnostic if above steps fail
    Mar 2008
    Have you a live environment you can boot from, Hirens (Windows) or a live Linux USB?
    What do see on the screen when you turn it on? Messages from The bios/post?
    Windows logo?
  6. Thanks guys for your posts. I took the cover off and it is 1 TB NVME drive. I unscrewed the screw holding it pulled it out and put it back in.
    It takes quite sometime when turning it on to finally get to this Aptio Setup AMI screen. The GMTEK logo flashes briefly on the screen and this is all I get.
    Nothing seems to work. You have an option to save settings and exit and you do that and you are immediatley right back to this screen.
    It looks like a failed NVME hard drive.
  7. Looks like I bought it just about 5 months ago. I set it up on June 20th, 2025. Maybe I can buy a enclosure to test the drive and hopefully get the files off of. Maybe the company will send me a new NVME 1 TB hard drive. If I get though this I am going to transfer everything off that hard drive or a new one every day and never trust it is not going to fail. I have my Beelink mini pc that is in my Mom's room that I set up for her to watch video files off of.
    With having to buy heating oil soon as the new season starts I was not wanting to outlay money for stuff such as this. I better sign into Amazon Canada and contact the company and see what they say. Maybe they have some advice to get it going again.
    Jul 2008
    Old Dominion
    Good luck. They boast a 1 year "warranty".
  9. I went to my Amazon Canada account and signed in. I don't think I will be able to get GMTEK to do anything for me. I won't buy another one. I do want to check that NVME drive with an enclosure so advice to what to get would be nice.
    I guess I will buy another Beelink and be vigilant about backing everything up every day. My ISP will be happy as I won't be using much of my bandwidth for awhile. I am sad about it all.
    It says to email them in China. I hate spending out money for a new one but I don't have the heart to take back the one I let Mom use and I think I will buy a spare one after awhile as well. I also have to buy more hard drives to back up what I have on my portable hard drives as they can go bad as well.
    I think I will buy a new NVME hard drive for the GMTEK one too at some point but getting Windows 11 on it I would need help with that as well. I better get a usb stick to boot Windows off that in the event that would help.
  10. Thank you everyone for your posts. This has happened to other people according to Reddit:
    https://www.reddit.com/r/MiniPCs/comments/1lbgpc2/gmktec_g3_plus_nvme_drive_failed_after_5_months/
    So I must move on spend the money and get another Windows 11 computer. This time I will make sure I clone the NVME boot drive and send stuff to external hard drives every day. It was a wonderful computer while it lasted. I hope I learn from this and I become better prepared in the future.
    It hurts to spend the money setting my savings plan back a bit. But live and learn and be grateful for terrific places such as this. I don't think I will buy GMTek again in the future. Well I better stop whining and move on with my day.
  11. Well Tom ..
    At least you can take some confront from the fact that the holiday season is upon us
    and it is an opportune time to purchase electronics at a discount.
    Good luck retrieving your data and an early holiday greetings from all of us ..
  12. Thank you and seasons greetings to everyone as well. Looks like I will get another Beelink with lower specs than the GMTEK. I think I will wait until next week and see if there is a price drop. There is no guarantee the Beelink will last but my first one is still going after nearly two years. My Windows 7 Desktop is still going after 12 years. I had it shut off for a whole month because I had switched most everything over to the GMTEK mini pc. It did work well up until now but it is what it is. Though these freeze ups have happened out to the blue looks like I should have took that as a sign something was about to fail. At least there is the GST rebate check coming in January to help out.
  13. I'm a Super Moderator johns0's Avatar
    canada
    I had a similar problem and found it was a faulty cpu power supply cable,replaced it and it works fine now.The cable wasn't a main power line,just a 4 pin plugin.
  14. Thank you for this information.
  15. I finally made a USB Boot Drive with Microsoft Windows 11 and used Rufus to set that up. Unfortunately it is not booting it just seems to be stalling. It saddens me greatly. I did sign into Amazon Canada and went looking through my orders and found when I ordered it and it is about five months to the day since I set it up that this happened. I clicked on something about the seller as I thought I should contact them. Amazon sent me an email saying we noticed you want to contact the seller is there a problem. Maybe I should do a review and they say people get action from the Company as they watch the comments. I would have to do it in a way as I don't want my real name out on the internet. I better write an email to the Company and see if they can do something for me. I will get that NVME enclosure first and see if this NVME to can be accessed.
    I have been using my Beelink Mini PC and I looked back to when I ordered it and it is about three years old. Anyway I have been racking my memory thinking what files I had on the GMTEK Mini PC and downloading those files again and it feels good to do that. I did have some private documents on the hard drive and am not all that anxious to send that NVME to the company in case that data could be accessed. It was stuff like copies of various bills nothing with a credit card number on it.
    I am hoping if I was to put the NVME in an enclosure to get all the files off of it. The good thing is the Beelink is still working and I got Avast Free Anti Virus for Windows 7 on my Windows 7 Desktop so I an use those two computers.
  16. Originally Posted by davexnet View Post
    Thank you telling me about this program. It is certainly worth a try. Someone at the GMKtek has gotten back to me and instructed me to remove one ram stick and try and repeat the process with the other. She also asked me to look in the advanced part of the bios program to check the NVME and I wrote her that the NVME doesn't show up. Also the Ram shows up on the main tab of their bios showing I have 16 GB or Ram.
    I have a general question I have done a lot of downloading to that NVME drive which was 1 TB and then I transferred those files off periodically to a USB 3 external hard drive. Is that hard on a NVME drive? It amazes me how they have 1 TB in such a slim little hard drive. Thanks in advance for any further guidance.
  17. I got a new message from the Company and I am to take out the NVME and see if it boots without it. That probably will indicate the NVME is damaged. I am to take some screenshots and I can send the NVME back to the Company and thankfully they have a warehouse here in Ontario. They will send me a new NVME drive that hopefully means I can use the computer again. I will definitely get everything I download off the computer right away in the future and not store sensitive documents on it anymore. I need to learn a lesson from all this.
    I have that enclosure coming and I do want to see if the NVME is accessable so I can get stuff off it. But if it is truly dead do I have to worry it can be repaired and my documents accessed by someone at the Company?
  18. I sent the bios pictures showing no NVME device showing and I am to send the SSD to the Company and they will send me a replacement and do a secure data erasure for the hard drive I send back. I am just waiting for Amazon to send me the enclosure I sent for so I can see if I can access my data and get it off the SSD. I was told that even if I could access the drive that is most likely in bad shape and to send it back. I am happy the Company is standing behind their product and that they have a warehouse in this province. It has been a wonderful machine up until this happening.
  19. I put the NVME in the enclosure and Windows 11 could not access it. I am sending it back to the Company today. My old Windows 7 computer may now have went on the blink after 13 years of working. It is quite cool in the house the temperature dropped during the night. Well anyway she won't boot and it is beeping. I have read that could be a failure of ram or some other failure. It was working fine last night when I shut it down. I will buy a enclosure for that drive and hopefully it is recognized. I already moved most files off that computer anyway.
    Jul 2009
    It's possible that the temperature change has caused the memory to work it's way out of the socket. Try removing and reinstalling the memory. Also check here https://www.computerhope.com/beep.htm for the beep codes.
  21. Originally Posted by zing269 View Post
    Some good news I took the ram out and put it back in and the CMOS battery and turned it on without hooked to a monitor and it started up without a beep. I have to get a monitor and the keyboard and mouse hooked back up to it but it looks very promising. This is a real blessing but I am going to remove all my files just in case. It had tons of dust inside and I took the vaccume cleaner and got that out.
    The strange this is my television that I was using as a monitor I had to put in my Mom's bedroom as her television went black screen with super faint picture and has become useless.
    But things are promising.
    As for the NVME it is on its way to GMKTec and they are going to send me a new NVME with Windows 11 Pro on it. So hopefully when I get that new NVME I will have my GMKTec Mini PC working again. I am going to have to get myself a monitor or TV but there is a second had shop up Town and maybe I can get a replacement TV there.
    I am kind of walking on a cloud as even though I haven't been using my old Desktop all that much anymore it has been a stalwart all these years since the summer of 2012 and I am happy she still has some life left in her yet.
  22. I am happy to report that I got my replacement NVME SSD 1 TB hard drive. I had to set up a Microsoft Account but also set up a local account as soon as I could. It is working fine so far but I have to get my programs reinstalled and configure Windows 11 more to my liking. Thank you everyone for your advice and hopefully I will be wise and back stuff and prepare for something like this again in the future. I am glad the Company stood behind the hard drive.
