Results 1 to 10 of 10
    Nov 2025
    Unites States of America
    This is my first post here and very little new about encoding, so apologies if I'm doing anything wrong.
    When I was ripping some anime content from dvds I had for a while but when checking the quality, I noticed this type of color bleeding.
    [Attachment 89730 - Click to enlarge]
    The image shows that around the characters body you can see actually see color bleeding coming from the bottom.
    I don't know too much about fixing color bleeding, which is why I'm posting on this forum for advice.
    Here's a Sample/Test file: https://drive.google.com/file/d/14YrcX2dX9SsD6wFtipcssibQGoZJJ0Ad/view?usp=drive_link )
    If anyone knows a way to fix this issue, please reply
    Thank you for reading this thread.
    NOTE: (I have both avisynth and vapoursynth x64)
  2. In AviSynth you can use something like ChromaShiftSP(y=2) to shift the chroma up by two scan lines.
    [Attachment 89747 - Click to enlarge]
    A little sharpening might help too, MergeChroma(last, aWarpSharp2(depth=10)).
  3. For the vertical shift, I prefer 1.3 over 2.
    Depending on your hardware, you could use Vapoursynth, do the ColorShift and additionally apply BasicVSR++ for cleanup:
    just shifted with y=1.3 :
    Cu Selur
    Nov 2025
    That looks really good, but i do i download the chromashiftsp filter file?
    Nov 2025
    Cu Selur
    the color bleeding fix looks perfect too, but i prefer to keep the quality (some details on the background is lost)
    and how do i also download that ColorShift filter file as well?
  6. Originally Posted by themon-master View Post
    http://www.avisynth.nl/index.php/ChromaShiftSP
    Nov 2025
    thanks, but i do i use the script? i use staxrip to preivew the scripts and its showing me this error
    [Attachment 89824 - Click to enlarge]
  8. Put ChromaShiftSP.AVSI in AviSynth's Plugins folder(s). It should autoload from there.
    Or you can copy all the text from the AVSI and post it into the script you're using.
    Nov 2025
    Yea, which Plugin folder are you talking about? the one that goes in AVS folder in the Apps folder?
    or the Plugin folder in the Settings folder?
  10. I don't use StaxRip so I don't know how it has things set up. Normally AviSynth has a plugins folder in the folder in which it was installed. Something like "C:\Program Files\AviSynth\Plugins". AviSynth+ may have both Plugins+ and Plugs64+ folders. You can always import the AVSI from anywhere with LoadPlugin("X:\path\to\ChromaShiftSP.AVSI") in your script.
    You can probably just put a copy in all the plugins folders that StaxRip created.
