if i had 2 mpegs of the same film<part 1+2>and put them on to the same cd will the the 2 mpegs become one file
No, one will play after the other but they will not be joined.
use a program like vcdcutter if you want to join them. You can find it on the tools page of this site. -
errrr...i'm assuming you're gonna burn the .mpgs as (S)VCD w/ nero? sincerely, hope you don't plan on burning them as regular data cds...
anywayz, when you use the (S)VCD template in nero, you can add as many .mpg files on each cd-r as you like, as long as total is under 800 MB or 80 min CD-R and 750 MB for 74 min CD-R....they will end up being avseq01.dat (or avseq01.mpg for SVCD) and aveseq02.dat (or avseq02.mpg for SVCD)....so 2 separate files w/ a 5 sec delay in between (dvd player will pause 5 secs at the end of file 1 before automatically playing file 2)
to answer your question, no...the two mpg files won't become 1 big file....however, you can join them together into 1 big file (just make sure there are no audio sync problems after you make the join)
Question about how to replace internal hard drive
By jimdagys in forum ComputerReplies: 2Last Post: 21st Apr 2008, 12:22 -
DV-400 External Hard Drive Question
By vashwood in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Dec 2007, 20:44 -
Hard disc imagaing question?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 26th Nov 2007, 18:48 -
Hard drive imaging question.
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Aug 2007, 19:37 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 12:34
